  1. Oct 24, 2022 at 7:42 PM
    empty_lord
    Indiana, Chicagoland
    05 rollover special
    OH kelford makes 268/254 cams. and i may be able to get a dealio on them.. SO maybe next year i'll do some cams now that i know the ECM can be played with enough. 2uz with some chop anyone?
    txagg, dbittle, bmf4069 and 4 others like this.
  2. Oct 24, 2022 at 7:49 PM
    KingSequioa007
    KingSequioa007 Dreaming of URD S/C
    San Diego, CA
    07 Sequoia SR5
    Current mods: AFE Cold air intake, AFE TB Spacer,JBA Long tube headers, DD full cat back race exhaust, pedal commander pedal controller, URD MAF Calibrator tuned by Mike @ Autowave, DD 12 hole 320CC injectors, R9K ECU reflash,Solid Off road mounts. Future upgrades: 4.8 gears and LSD, ,long travel kit.
    No Dyno?
  3. Oct 24, 2022 at 7:51 PM
    empty_lord
    05 rollover special
    no. logging with techstream. theres power to be made for sure. but to do that. he'd rather have me make a patch harness for a haltech, tune the haltech, then put those numbers into the stock ecu.. reflashing the old ecu is a SERIOUS hassle
  4. Oct 24, 2022 at 7:51 PM
    KingSequioa007
    San Diego, CA
    07 Sequoia SR5
    Kelford really, Never would have imagined. I know XAT makes a set also, but never seen numbers on a 2UZ. Does Kelford have any R&D on these 2UZ cams?
    5N0W808 likes this.
  5. Oct 24, 2022 at 7:51 PM
    empty_lord
    05 rollover special
    kelford makes them for xat
  6. Oct 24, 2022 at 7:52 PM
    KingSequioa007
    San Diego, CA
    07 Sequoia SR5
    Yea Toyota really locked those ECUs down. I worked at Toyota R&D for a bit and the engineers would confirm with me how locked down they were.
  7. Oct 24, 2022 at 7:53 PM
    KingSequioa007
    San Diego, CA
    07 Sequoia SR5
    Ah, makes more sense now.
  8. Oct 24, 2022 at 7:53 PM
    empty_lord
    05 rollover special
    every reflash he has to solder 1 wire on. cannot leave it soldered on. also has a pin out soldered on now. that can stay on. its interesting to see done
  9. Oct 24, 2022 at 7:54 PM
    empty_lord
    05 rollover special
    the ecu board is the same as a 2006 avalon though. fun fact.. different surface mounts. but the main controllers are the same. just a few more things attached for the V8 stuff
    KingSequioa007 likes this.
  10. Oct 24, 2022 at 7:55 PM
    Cajunman007
    Cajunman007 New Member
    Shane
    Lafayette, LA
    02 Tundra Access Cab 4x4 4.7
    I will definitely look into that. Thanks for the heads up. I have no leaks currently, but will consider.
  11. Oct 25, 2022 at 6:00 AM
    KingSequioa007
    San Diego, CA
    07 Sequoia SR5
    Nice. I'm still debating buying a 3rd spare ECU and sending it in to DAP for a tune. I've definitely lost a bit of power in changing to bigger tires, although the butt dyno feels the same lol.
    5N0W808 likes this.
  12. Oct 25, 2022 at 7:29 AM
    des2mtn
    SW
    2004 Black DC Limited 4x4
    Tonto cover
    Got around to installing my replacement camper shell parts. Latches just fine now! :yes:
    The catch brackets are insanely worn out and you can see why one of them wasn't catching.
    Also the hinges have been upgraded to a two-bolt design. From the factory, there is only one bolt and the other hole has a plastic nub that goes through. The plastic nub on both my hinges were worn so only the one bolt was securing the window.
    805Tundra, RUSTYNUTS, abcinv and 6 others like this.
  13. Oct 25, 2022 at 12:48 PM
    Mr.bee
    Mr.bee King Turdra
    '02 AC TRD
    If i were to source some rear shocks with springs on em, think i could go 50lb/in? 100lb/in? Need to box those braces before going crazy? Cause it could be easy to pull the shocks off if i needed to flex, while being stable enough to haul what i'll be haulin'
  14. Oct 25, 2022 at 1:13 PM
    Que? Rear shocks with springs on them?
  15. Oct 25, 2022 at 1:38 PM
    SC.Pro92
    SC.Pro92 New Member
    2022 Tundra TRD Pro? Lunar rock
    Ended up slimming the front bumper on my 06 double cab. Came back from work one night at UPS and someone backed a package car into the front of it. I tried my best for 2 weeks to ignore the ding and the missing paint and today was the last straw. Between the jigsaw and sander I went to town. Thought it would be relatively easy but trimming it made it to where there wasn’t a lot of points to attach to so the bottom was a little wobbly. So after 1000 zip ties I think we are in business. Probably not the best looking job out there but better than what I had I guess. It will serve the purpose until I decide to get that high dollar steel one. Haha
  16. Oct 25, 2022 at 1:38 PM
    Mr.bee
    Mr.bee King Turdra
    '02 AC TRD
  17. Oct 25, 2022 at 1:54 PM
    What is the advantage of those?
  18. Oct 25, 2022 at 2:57 PM
    Like an add a leaf, just spiral shaped.
    oscardog86, bmf4069 and RUSTYNUTS like this.
  19. Oct 25, 2022 at 2:59 PM
    danmurphymn
    danmurphymn New Member
    Minneapolis, MN
    Black 2004 DC TRD
    Asking the best minds...
    Which low dust brake pads are best? (preferably a brand from Rock Auto)
    And which spark plugs are best?
    Time for both...
    Tundra2 likes this.
  20. Oct 25, 2022 at 3:06 PM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
  21. Oct 25, 2022 at 3:13 PM
    Akebono are good pads
    txagg and NUDRAT like this.
  22. Oct 25, 2022 at 3:49 PM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    But a "bad" place to work. :rofl:
  23. Oct 25, 2022 at 4:19 PM
    alb1k
    Left Coast
    05 2WD DC w/ attitude
    It's good
    Took some vid today to see how things are moving. A few thoughts:
    1. You can see how axle warp/wrap works
    2. When I mounted to my bumper, noises were more metalic/direct - I should check my bolts
    3. When I mounted to the slider, I was surprised at how much the body mounts compress
    4. Trans mounts move quite a bit.
    https://youtu.be/oBfCHXvem_g
  24. Oct 25, 2022 at 4:22 PM
    Wrap it up!!!
    I’ve noticed a small vibe after my leafs were installed, thinking about shimming the carrier bearing, but yours looks just as “bad” as mine is perceived
    Tundra2 likes this.
  25. Oct 25, 2022 at 4:30 PM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    When you were editing... did you think it was weird to see yourself in the video and doing your "thing" with the truck?
  26. Oct 25, 2022 at 5:21 PM
    @alb1k I like how you don't have hard lines going into your calipers. Are those the banjo fittings that @Darkness would talk about?
  27. Oct 25, 2022 at 5:23 PM
    des2mtn
    SW
    Tonto cover
    He's even using the @roasted nuts guides!
    alb1k and FrenchToasty like this.
  28. Oct 25, 2022 at 5:29 PM
    alb1k
    Left Coast
    It's good
    I didn't even notice, lol
    Tundra2[QUOTED] and FrenchToasty like this.
  29. Oct 25, 2022 at 5:32 PM
    alb1k
    Left Coast
    It's good
    THose are the Solo motorsport extended (but not LT) lines. No crazy banjo, just a 90 deg at the caliper. I really like them. Getting a proper "s" so they don't contact anything they are not supposed to takes a touch of thought.
    FirstGenVol[QUOTED] and des2mtn like this.
  30. Oct 25, 2022 at 5:38 PM
    alb1k
    Left Coast
    It's good
    Ya, I have the carrier shimmed. Not sure it's needed. I'm sure it doesn't hurt anything.
