  1. Oct 18, 2022 at 12:46 PM
    1794TX
    Steven
    N.TX
    '20 1794
    Can you see inside that thing? What are the chances I could drill a hole in it to install a camera where that red circle is? Is there enough room?
  2. Oct 18, 2022 at 12:48 PM
    1794TX
    Steven
    N.TX
    '20 1794
    TWSS
    DZ_ and Tripleconpanna like this.
  3. Oct 18, 2022 at 1:15 PM
    Millwood21
    Millwood21 New Member
    Jade
    2017 Platinum
    When I get home from work Ill snap a pic of the inside and send it to you. They put antenna mount on top in the center so I'm guessing there should be enough room. But ill def check for you.
    RobertD and 1794TX[QUOTED] like this.
  4. Oct 18, 2022 at 2:00 PM
    justcuz
    justcuz 2.5 Gen Member
    Looked at all the ash from forest fires close byEC046AA1-7F47-4E35-ABCD-6EACEF116699.jpgFB9BEA42-7C58-43D9-9B7B-C9FB1370D6C6.jpg
  5. Oct 18, 2022 at 2:10 PM
    Tripleconpanna
    2021 TRD PRO CM; 2008 SR5 CM
    Not sure i'm believing that statement in its entirety….
    :spy:
  6. Oct 18, 2022 at 4:22 PM
    GCanuck
    GCanuck Member since 2020
    Gary
    BC,Canada
    2020 Tundra DC MGM TRD Sport
    TRD Swaybars. Line-X bed liner. Toyota Tri-fold Tonneau. N-fab side bars. TRD cold air. AMP bed extender. Rough Country Level kit. BFG A/T K02. RCI Skids. OEM Tow mirrors. TRD exhaust
    Ya. I got it as well. Pisses me off as I just washed the truck! Left some on the Rav4 couple years ago and it pitted the paint.
  7. Oct 18, 2022 at 4:26 PM
    Toe404
    Toe404 just a poser
    Tomas
    Concord ,CA
    '21 Cavalry TRD Sport CM
    at least a little ash is all you have to deal with, rather than just being one of those unfortunate people whose house is nothing but a pile of ash.
    mgm16trdpro, RainMan_PNW and cartage1 like this.
  8. Oct 18, 2022 at 4:27 PM
    Velocity72
    Velocity72 New Member
    Upstate SC
    2021 Platinum
    Now a member of RAS club. Was set to haul two 2x12 U-Haul loads 300 miles and wanted to get the RAS springs 61CF9593-7EB6-427A-A80D-8E8EEA62E538.jpg installed before the two trips. Really like them. Rear end feels planted. Tongue weight was probably 400+ pounds, and not much squat at all. I had adjusted them to the 25% increase over stock, not the 40%.
  9. Oct 18, 2022 at 4:51 PM
    RusPro21
    RusPro21 Pro is gone! But I’m still here.
    Don
    Pa.
    2021 Pro!! Nitto’s Tyger blades, Arc audio!
    Had my audio place who I have been dealing with for a very long time order me the Kenwood 1057 to go with my arc audio system. Wanted the 10.1 screen and even better sound.
    Jcmf52 and Dawoofles like this.
  10. Oct 19, 2022 at 6:25 AM
    Eborseti22
    Eborseti22 New Member
    Evan
    2020 Toyota Tundra TRD Offroad
    Sharp looking truck - what lift are you running? Didn't think you needed one to run that size tire, but the set up looks great.
  11. Oct 19, 2022 at 6:31 AM
    frichco228
    frichco228 Valued Member
    Frank
    Virginia
    2016 Crewmax 4WD, TRD Offroad
    Thanks! It is the Eibach Pro Truck 2.0 setup, the threaded, adjustable on the truck ones, not the ones with clip settings like 5100s. I have it set at 2 inches lift in front and then run RAS in the rear which gives an inch lift. Tires are 275/70-18s (33.4 tall) and you are correct, that size fits stock trucks and I ran that size before the suspension changes.
  12. Oct 19, 2022 at 12:04 PM
    helidave
    helidave Hellacopter
    flagstaff
    2015 DC 4x4
    Made a mount to keep my jack secure from flopping around in the bed. IMG_20221019_115229666.jpg IMG_20221019_115404104.jpg
    Henry1jg, vtl, Velocity72 and 21 others like this.
  13. Oct 19, 2022 at 12:45 PM
    1lowlife
    DADA
    THE GREAT STATE OF TEXAS
    2014 MGM DC SR5
    Sorry if I missed it, where did you get the mount?
    TIA..
  14. Oct 19, 2022 at 1:00 PM
    1lowlife
    DADA
    2014 MGM DC SR5
    I installed my Amp bed step yesterday.
    I got it for Xmas, but Toyota had my truck from November to July.
    Having my casual OCD issues, my first thought would be to use the bumper part that came with the step.
    But being I've taken all that off before, I can't remember why, I decided to do the "cut the existing bracket" method.
    OEM bed step install without changing out the bracket | Toyota Tundra Forum (tundras.com)
    I laid out and made a pattern of what the Amp bracket looked like.
    Compared that to the existing one so I knew what to cut.
    I first tried my jigsaw, epic fail, and then the Sawzall.
    Dulled the sharp cut edges with my Dremel and painted the cut.
    It saved A LOT of time not taking the rear bumper apart.
    I would have liked the step to be more even/level with the angle of the bumper, but oh well..
    It certainly does make getting in and out of the bed easier, especially with bone-on-bone knees.
    nhw544, GELCW, GAknight and 8 others like this.
  15. Oct 19, 2022 at 1:09 PM
    NAIVIAN
    NAIVIAN This is the way....
    Doug
    Spring, TX
    2021 Black SR5
    Quick questions to all the knowledgeable Tundra Gods:
    I have a front and rear dash cam that I am about to put in but I am not sure how to get the wire from the front cam to the rear cam. What ideas do you guys suggest so I can get this done soon.
    FYI I have a 2021 SR5 crew cab.
    TIA
  16. Oct 19, 2022 at 1:20 PM
    RobertD
    Robert
    DFW, Texas
    There are youtube videos that show this. You essentially just tuck the wires up into the headliner along either the driver or passenger side and work your way from the front to the back.
    cartage1 and NAIVIAN[QUOTED] like this.
  17. Oct 19, 2022 at 2:01 PM
    SwitchThrottle
    2021 Barcelona CrewMax
    Got the truck back from NH Oil coating. Won't have to worry about rust on my airbox. :rofl:
  18. Oct 19, 2022 at 2:32 PM
    SAGE63
    San Diego County
    Great Idea.
    helidave[QUOTED] likes this.
  19. Oct 19, 2022 at 2:36 PM
    Gfgneo
    Gfgneo New Member
    California
    2021 tundra platinum
    That would interfere with the side and pillar air bags i believe
    NAIVIAN likes this.
  20. Oct 19, 2022 at 3:14 PM
    NAIVIAN
    Doug
    Spring, TX
    2021 Black SR5
    Ahh, ok I did not know that there was you tube vids on this. Thanks.
  21. Oct 19, 2022 at 3:16 PM
    NAIVIAN
    Doug
    Spring, TX
    2021 Black SR5
    Ahhh, I didn't consider that. Any thoughts on how else do you think - Fish tape maybe?
  22. Oct 19, 2022 at 3:32 PM
    @NAIVIAN It does not interfere with them. There is plenty of room. That is how mine is routed.
  23. Oct 19, 2022 at 3:50 PM
    1lowlife
    DADA
    2014 MGM DC SR5
    As @Tundra234 stated;
    There is plenty of room around those airbags to tuck a wire or 5.
    I had to run a Bluetooth mic for my Kenwood HU and antenna wires for my alarm/remote start.
  24. Oct 19, 2022 at 4:11 PM
    Ckatz53
    Ckatz53 Newish
    MD
    www.fouroneodetailing.com
    Pinch weld mod complete. Cut, tacked a few of the sheets back together, sealed up with some black caulk. Once this dries I'll spray the cut and my horribly rusty BMC with some rust reformer then put two coats of some rubber undercoating on the pinch weld. Bolt the fender back up and heat gun the liner flat. May still get a light tap of the tire on the liner but I don't want to cut it up.
    20221019_174051.jpg 20221019_174517.jpg 20221019_180129.jpg 20221019_190936.jpg
    Edit: rust reformed and rubber coated.
  25. Oct 20, 2022 at 1:51 AM
    AZ Red Nek
    AZ Red Nek Native of the Valley, Bowl, Basin, ETC...
    Chuck
    2016 White SR5 Crew 4x4
    Hidden 1200# Waren winch, Baja Desgins lights, Switch Pro switch and controller, S&B air box and in bed tool box.
    :bowdown: :bowdown: to @james@tech12volts did something yesterday I should have done 4 years ago when I purchased my truck.20221019_172957.jpg
    Jl audio group buy. I contacted Mr Taylor and explained I was looking to upgrade my stereo and was wondering what was included in some of the group buys. I explained that the only social media I use is this forum. In an extremely short amount of time he emailed me a list of the different group buys. I placed my order, and then ended up with a work problem that happened to be scheduled on the same date as when the shipment was to arrive. I reached out to Mr Taylor to inquire about expedited shipping he replied quickly and with all the different options and related cost. I received everything on the 18th and discovered today that the sub knob was missing. I sent him a email which he responded to in under an hour. Then I received a email from the shipping company that I had a package coming next day air, followed by Mr Taylor's email that he left work to get it shipped out right away. Sorry this being so long but excellent customer service is hard to find. Oh and as far as the system sounds, we'll even with the stock HU it is amazing. The carpet color is off but I picked the wrong color when I ordered.
    TomC843, Henry1jg, GAknight and 16 others like this.
  26. Oct 20, 2022 at 3:17 AM
    Knox_Tundy
    Knox_Tundy New Member
    Knoxville, TN
    Finally gave her a bath yesterday.
    Old.Ski.Bum, GAknight, ajs4 and 17 others like this.
  27. Oct 20, 2022 at 6:34 AM
    Wrongside
    Wrongside New Member
    AB
    2016 Tundra
    Installed Diode Dynamics reverse lights. Pretty sure they’re brighter then my crappy 2016 headlights. Haha.
    Next up are the DD Elite Fogs.
    Ace96, Sean492 and bulldog93 like this.
  28. Oct 20, 2022 at 7:12 AM
    bmw345
    bmw345 New Member
    CT
    2018 Platinum Pro, Pro Fox's TRD Skid
    Looks slightly excessive!
    FrenchToasty and AZBoatHauler like this.
  29. Oct 20, 2022 at 7:49 AM
    Gfgneo
    Gfgneo New Member
    California
    IMHO that is the best color. I wish my platinum came in that color.
    WinterWarlock21 likes this.
  30. Oct 20, 2022 at 8:27 AM
    Eborseti22
    Evan
    Awesome. Thanks for the info - Like the set up!
    rdiddy5 likes this.
