Studs too short on new aftermarket wheels
Discussion in 'Wheels & Tires' started by LilRed, Apr 17, 2020.
  1. Oct 24, 2020 at 7:11 PM
    Jimes
    Jimes New Member
    Bay Area, California
    2015 toyota tundra trd pro
    I called Dorman to see if they would make some but they said $1100 for 10 to custom make some. No thanks. This is awesome that you tried them and they worked out.
  2. Oct 24, 2020 at 7:16 PM
    Jimes
    Jimes New Member
    Just ordered them. We’ll see how long it takes. Did the cheapest shipping. $157 total for 10. Thanks for the info and for being the guinea pig.
  3. Oct 24, 2020 at 9:29 PM
    GravityGear
    Aurora, CO
    Iconix come in M14?
  4. Oct 24, 2020 at 9:46 PM
    Jimes
    Jimes New Member
    Sure do. I bought them when I bought my gram lights wheels. Wanted to keep them from getting all messed up from the lug nuts. Now that I’m getting those studs I can finally use these guys. 1B00BB59-4DF7-4926-BD99-95B8BA24C08E.jpg
    GravityGear[QUOTED] likes this.
  5. Oct 24, 2020 at 9:47 PM
    GravityGear
    Aurora, CO
    interesting. I've never seen them in M14. Last I checked, Mackin was only importing M12 for cars.
  6. Oct 24, 2020 at 10:02 PM
    Jimes
    Jimes New Member
    Evasive Motorsports is where I got them from.
  7. Oct 25, 2020 at 5:22 AM
    Mrf1987
    Mrf1987 New Member
    2020 Trd sport tundra
    Awesome man! Im glad I could be a guinea pig for you all, thats better than what my wife calls me. It only took about 5 days for me to get the lugs from japan. Honestly I was shocked at the speed. Gram lights you say? Bringing me back to my import days haha
  8. Oct 25, 2020 at 8:21 AM
    GravityGear
    Aurora, CO
    Mrf1987[QUOTED] likes this.
  9. Oct 25, 2020 at 2:42 PM
    Jimes
    Jimes New Member
    Pictures don’t do them justice, but they make them for our trucks. 57 trans x is what they are called. Come in 18x9 with either 0 or +25 offset. Also come in black or bronze. Weigh about 23 lbs. this is what they look like on my truck. 90A07C7E-BE3F-48F8-B131-C6815CE2D871.jpgCDA45425-5E72-4906-901D-20C09B94FACE.jpg35FDF21F-EF79-4433-80B1-760D6A85DE66.jpg
    MVRCA, NewImprovedRon, excelw and 8 others like this.
  10. Oct 25, 2020 at 2:46 PM
    Mrf1987
    Mrf1987 New Member
    That’s awesome man! Good looking wheels for sure
    Jimes[QUOTED] likes this.
  11. Oct 25, 2020 at 2:48 PM
    GravityGear
    Aurora, CO
    I considered getting Rays, but my wheels end up haggard from off-roading. I would feel so bad wrecking nice wheels.
  12. Oct 25, 2020 at 3:12 PM
    Jimes
    Jimes New Member
    So far they only got some pinstripes from wheeling. I don’t drive fast when Offroad especially when driving over rocky terrain. Once they get damaged enough I’m going to get them powder coated in hyper blue which I think will be awesome. Unfortunately yellow stuff brake pads keep my wheels mostly black. I got them for their strength, weight and looks. Since I’m on 37s the extra 10lbs made a difference compared to my method grids that were 33lbs.
  13. Nov 30, 2020 at 12:05 AM
    Jsena
    Jay
    Las Vegas, NV
    A Bad Bissshhhh
    What is original wheel stud measurement? 1of my rear driver side studs snapped off. Need to replace it.. cheers :cheers:
  14. Feb 14, 2022 at 10:25 AM
    Tundra200
    Tundra200 New Member
    Patrick
    2008 LandCruiser
    4" lift, Tundra suspension, Brakes, and gears, 35" Falken MTs, 20" BBS Tundra wheels
    i bought a set of these based on this recommendation and the 10 studs I received were 16mm Knurl. now I'm back to looking for a working solution. I'm leaning toward the KYO-EI SBLC. just not looking forward to the shipping time.
  15. Feb 14, 2022 at 10:43 AM
    Mrf1987
    Mrf1987 New Member
    Took less than a week for me to receive them but that was pre Covid
  16. Oct 13, 2022 at 7:28 PM
    _steezysr5
    _steezysr5 New Member
    Instagram _steezyse Eibach pro lift stage 1 3.5/1.5 Rough country shims/block Methods nv305 double black 18x9 +25 Bfg ko2 35 12.5 Alpharex pro series headlights/taillights Lasfit ls plus series led Armordillo Hood Grille Insert with Led Lights Bakflip mx4 tri fold tonneau cover 5 inch iboard running board Pedal commander RCI Transmission and catalytic converter shield Nameplate overlays 5% tint all around Titan wheel spacer 1 inch Weather mats by 3dmatsusa Rydonair 7 inch Gplus third brake light Paint-matched hood bulge, grille surround, front and rear bumper overlays from Ecoological (midnight black metallic) Mbrp dual rear exit exhaust (mimics trd exhaust sound) yet to install, currently just a muffler delete
    I looked up the part number clicked on the link from Amazon and Walmart it’s saying it don’t fit tundra.. also shows that part number is for a dodge? Ignore it? If you say those worked I’d believe you more.
  17. Oct 13, 2022 at 7:33 PM
    _steezysr5
    Ran into the same problem. Attempted to install 1.5 spacer . And the nuts to secure the spacer only go half way into the oem studs. They look shorter than ones on my Camry.
  18. Oct 14, 2022 at 6:48 AM
    dgtulsaguy
    dgtulsaguy New Member
    18' 1794
    I've used Dorman 610-471 wheel studs for a few years now without issue. Just make sure service techs understand the studs are different up front if you ever take it in.
  19. Oct 14, 2022 at 7:25 AM
    Cruzer
    Cruzer Wheeling Full Size
    Cruz
    Sunnyvale, CA
    I’ve got the Dormans on all 4, makes life easier.
    dgtulsaguy[QUOTED] likes this.
  20. Oct 14, 2022 at 7:40 AM
    #50
    dgtulsaguy
    18' 1794
    Very true, my stock rear studs were long enough so I didn't bother with them.
  21. Oct 14, 2022 at 8:22 AM
    #51
    _steezysr5
    thanks, fellas! ordering them today
    NewImprovedRon and Cruzer like this.
  22. Oct 14, 2022 at 8:32 AM
    #52
    Cruzer
    Cruz
    Sunnyvale, CA
    Whatever you do... do not over torque them. Just watch the backside as you are seating them. Once the underside of the head contacts the hub it's good to go. Tightening it further than that you'll risk snapping them - while you are driving. I made that mistake.
  23. Oct 14, 2022 at 8:46 AM
    #53
    _steezysr5
    I'm aware I've changed the wheel studs before on my Camry..the shop did the overtightening I had a missing lug and snapped stud. why I prefer to diy don't wanna blame someone else but me lol. Thanks for the reminder!
    Cruzer[QUOTED] likes this.
  24. Oct 14, 2022 at 8:59 AM
    #54
    Vizsla
    Vizsla 2 = 2.5
    #54
    _steezysr5 and Cruzer like this.
  25. Oct 19, 2022 at 9:50 AM
    #55
    _steezysr5
    Got the extended wheel studs in the mail yesterday. Curious to know will extended nuts for the spacers do just fine on the stock wheel studs since it’s 8mm thread longer here’s what I’m looking at. Standard nuts for spacers is 21mm long as you see in the other options, the extended ones 29mm. Assuming the extended studs are the best if had to choose one but I’m trying to do the bare minimum not having to replace the studs. I know having both is the best and safest but would like to hear some opinions.
  26. Dec 22, 2022 at 7:10 AM
    #56
    jproy12
    jproy12 ¯\_ (ツ) _/¯
    JP
    Ottawa, Canada
    2023 Supersonic Red Platinum Hybrid
    #56
  27. Jun 19, 2023 at 4:50 AM
    #57
    dgenerate828
    dgenerate828 New Member
    Georgia
    2012 Tundra CM Grade
    Powder Coated Bumpers, 20" Mayhem Warrior Wheels, Front Grill, Step Bars, Evo1 Remote Start, Auto Up Window Module, Nitto 275-55-R20
    Thanks for the information! Bought the new studs and had them in hand from order date in 8 days ($112 for 10 lugs. Small price to pay for peace of mind with my wife and kids in the truck) Found out I had a stuck lugnut on my rear tire in the process so I luckily had 10 spares to replace it with. Glad I found that out on the lift and not on the side of the road. My Father in Law has a lift, Ball Joint remover, and experience which made this job a piece of cake even for a not-so-mechanically inclined person as myself! Everything worked great. Thanks again for the information!
  28. Jul 28, 2023 at 5:34 AM
    #58
    Wynn family fishing
    Wynn family fishing New Member
    Charlie
    2008 Crewmax 4x4 "Black Betty"
    6" lift
    Jimes, those Gram Lites look awesome! Are they the 0 offset? If so, did you run a spacer? I'm new to the forum... I just bought an 08 with a 6-in lift. It has some heavy, 20x12 rims that I want to replace. They are -44 offset also. Most of of the lighter, quality rims that I'm finding for our truck have a zero or positive offset. I definitely want to go narrower than what I have now of course, but considering where I'm starting I feel like going to a nine wide with zero offset would be extreme. Don't want to use spacers if I don't need to. Thank you for any advice. BTW, it currently has 35x12.50s. I plan to either stay with this or go with the metric equivalent of a 35 11.50.
