  1. Oct 9, 2022 at 7:43 PM
    APalmTree
    APalmTree Sometimes helpful
    Brandon
    SW Washington
    A few... Definitely more than 2
    So, my initial impressions were pretty close. The new suspension is very close to a brand new stock TRD Offroad suspension. It is not really any softer or stiffer at low speeds which is not necessarily a bad thing, but at higher speeds, it eats bumps much better and is much more controlled. I don't have any particular notes about the rear other than it deals with loads better than stock with less sag but it still feels much like stock. Overall I'm quite happy.
    And today I wired in a recessed power strip to the back of the center console that connects to my inverter in the bed. The power strip almost fit into the stock hole but I had to do a little massaging to make it fit. I also relocated and kept the factory 12v outlet next to my remote inverter switch just because I could.
  2. Oct 10, 2022 at 7:10 AM
    FilchedToyoResto
    FilchedToyoResto New Member
    I am looking to do something exactly like this, would you mind sharing where you got yours?
    Thanks.
  3. Oct 10, 2022 at 7:37 AM
    APalmTree
    Brandon
    SW Washington
  4. Oct 11, 2022 at 3:12 PM
    mike diamond
    mike diamond New Member
    Michael
    2007 toyotaTundraLimited
    20 inch wheels
    Cleaned her out after fishing trip in Wyoming
    PhotoNerd likes this.
  5. Oct 12, 2022 at 6:50 PM
    Hotwire
    Hotwire New Member
    Montana
    2008 Tundra SR5 double cab
    I trimmed the rear seatback brackets in my DC today to better access where I will mount my amp and sub.
  6. Oct 13, 2022 at 5:50 AM
    Ohannon7
    Ohannon7 New Member
    Central Fl
    2013 5.7 4WD CM Bench-Seat Silver
    6” Pro Comp 37’s Custom audio and interior Off road capability is current focus
    I bought these red BBS stickers & was planning to put them on the lips or center caps but sold the wheels instead. I think it would look good on your beautiful wheels but to each their own.
    Mountun Goat and WVI like this.
  7. Oct 13, 2022 at 8:49 AM
    Bendarrrr
    Bendarrrr New Member
    Baltimore
    2012 TRD off road magnetic grey
    5100’s all 4 corners with Eibach coils and 1-1/2 “ Icon AAL in the rear.
    Anyone out there have Eibach coils on 5100’s??
  8. Oct 13, 2022 at 5:49 PM
    texasrho83
    texasrho83 Old Member
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    This is more like a kudos to Crutchfield post but a few weeks ago I ordered a Maestro harness adapter praying it was the right one to connect to the Kenwood DDX9906XR:
    It wasn't.
    So I posted a review on Crutchfield's site to say that it didn't fit warning others to shy away from it.
    Today I got a package from Crutchfield that happened to be another adapter that I didn't order. I pulled up my account on the site and saw this:
    I tried it out on the radio and it's a perfect fit. Well, damn I thought customer service was dead. At Crutchfield it certainly isn't. They've gotta customer for life.
  9. Oct 13, 2022 at 10:37 PM
    BoysandHisToys
    BoysandHisToys New Member
    Central Virginia
    2013 Tundra Crewmax Limited
    They’ve always done really well.
    a couple years back they doubled their size of call center and customer service center. They’re just down the road from my work.
  10. Oct 13, 2022 at 11:13 PM
    joseph_womack
    joseph_womack @ 4x4bound
    Joe
    Louisiana
    2007 RCLB, 4WD, 4.7L V8
    Doesn't quite fit the question but I'm about to put Eibach coils on 6112s
    Which coils are you referring to for on the 5100s?
  11. Oct 13, 2022 at 11:36 PM
    Sleeper16plat
    Sleeper16plat New Member
    Near Vancouver
    2016 Silver Platinum
    TRD Rear Sway Bar Bilstein 6112/5160 Pop Lock, Kenwood MX 1057 XR, Pioneer amp/speakers/subs, Tech12Volt dual sub box
    my thought was: Frost? It's only Oct...oh right, November is just around the corner.
  12. Oct 13, 2022 at 11:41 PM
    Sleeper16plat
    Near Vancouver
    I just put this one on. I don't know if it increased the range, but it definitely works. Nice clean look. the factory antenna was bent and always coming loose. Probably from going through car washes.
  13. Oct 14, 2022 at 3:38 AM
    texasrho83
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    :worthless:
  14. Oct 14, 2022 at 4:40 AM
    Bendarrrr
    Baltimore
    Here’s the link.
    I’m just trying to find someone that has done this and has some advice. Like which clip/ setting , did they use a shim on the drivers side etc. I wish I had the budget for the 6112 set up.
    joseph_womack[QUOTED] likes this.
  15. Oct 14, 2022 at 4:41 AM
    Bendarrrr
    Baltimore
    Sorry I didn’t know that was gonna post the actual page. Sorry guys
  16. Oct 14, 2022 at 4:44 AM
    Shanet421
    Shanet421 (Semi) New Member
    San Diego,CA
    I’m not sure they will work on the 5100s.
  17. Oct 14, 2022 at 9:21 AM
    Bendarrrr
    Baltimore
    joseph_womack likes this.
  18. Oct 14, 2022 at 10:27 AM
    Shanet421
    San Diego,CA
    This kit is for a Taco…just an fyi
  19. Oct 14, 2022 at 1:02 PM
    Bendarrrr
    Baltimore
    Not that I’m ordering that kit but good call I didn’t see that. Well I’ll either be ordering some Eibach struts or I’ll get lucky. Won’t be for another week or 2
  20. Oct 14, 2022 at 5:22 PM
    Windsor
    Homeless in Oregon
    2008 Tundra Crewmax 5.7L
    Some.
    I've already had frost up here on my current job/camp site.
  21. Oct 14, 2022 at 11:37 PM
    mike diamond
    Michael
    20 inch wheels
    Paid a guy $125 to wash and wax my truck Came out beautiful Tucson Area
  22. Oct 16, 2022 at 1:07 PM
    Shanet421
    San Diego,CA
  23. Oct 16, 2022 at 8:14 PM
    joseph_womack
    Joe
    Louisiana
    If I remember right, they should fit with each other, I had thought of the same idea when I still hat 5100s, I called around and the general consensus was that I shouldn't do it because the 5100s weren't setup to run the stiffer eibach coil
    So, for a budget friendly lift I bought the eibach coils and their pro truck lift shocks separately and put them together myself, overall they're pretty decent, I maxed them out on the 3rd clip and they do ride relatively smooth, not the greatest but a pretty good budget option
    - doesn't mean you can't run the 5100s and eibach coils, but if I remember right the ride will end up being rough, sacrificing lift for ride quality because of the stiffer coil
  24. Oct 16, 2022 at 9:26 PM
    B.Ross
    B.Ross New Member
    Southern Utah
    2012 TForce CrewMax 4wd
    Finally got the rear done.
    Icon RXT leaf pack option 3
    RC Vertex piggybacks
    Daystar cradles
    :cheers:
    2mchfun, D4x4TRD, Peeeheeuuu and 4 others like this.
  25. Oct 17, 2022 at 3:45 AM
    RepeatPete
    RepeatPete New Member
    Pete
    2008 Tundra SR5
    Pretty interested in how those RC vertex shocks are. Let us know once you get some time on them!
    B.Ross[QUOTED] likes this.
  26. Oct 17, 2022 at 4:27 AM
    Shanet421
    San Diego,CA
    All I see is a 46 gal transfer flow tank :bowdown:
  27. Oct 17, 2022 at 11:52 AM
    B.Ross
    B.Ross New Member
    Southern Utah
  28. Oct 17, 2022 at 7:33 PM
    Windsor
    Homeless in Oregon
    Some.
    Replaced the battery. Interstate with 3 yr warranty decided it was done at 3yr 1wk.
    Tire ship checked my filter a while back and jacked up the gasket. So, I found dust had gotten past. I ended up cleaning the carbon filter and the MAF which was dusty.
    When I was reinstalling the MAF, I noticed that even with it seated properly, it doesn't seal. The OE seal is visibly too small and allows dust to get by (the seal was light with dust all the way around).
    Anyone notice this before? I am thinking I will use some rtv to seal it.
  29. Oct 17, 2022 at 7:37 PM
    Retroboy1989
    Northern Utah
    I love it when shops mess with stuff I didn't ask them for... And do a crap job putting it back together.
    I once had a jiffy lube guy (it was just for an emissions test and Ill never go back) bring my air filter into the waiting room to show me it was clean. I calmly said "I know, I just replaced it a few weeks ago". That vehicle had 3 screws to secure the airbox lid that only lined up with patience. They cranked it down crooked with 2 of the screws.:mad: Fixed it myself and swore them off for good.
  30. Oct 17, 2022 at 7:44 PM
    Retroboy1989
    Northern Utah
    I worked at a tire shop in high school that only did wheel and tire work. Once a customer came in with a front wheel bearing flopping all over the place. We did the tire work and I took a second to knock the spindle cap off, remove the cotter pin, finger tighten the spindle nut and put it back together. The play was almost eliminated as it rolled out and we advised the customer that the bearings needed service. I felt like that was the right thing to do. Thoughts?
