General Supercharger Thread
  1. Oct 15, 2022 at 2:45 PM
    #3661
    reywcms
    reywcms New Member
    Rey
    Beaverton,Oregon
    2017 Tundra Platnium
    Too many mods to come
    Interesting you saw no change.
  2. Oct 15, 2022 at 2:46 PM
    #3662
    reywcms
    reywcms New Member
    Rey
    Beaverton,Oregon
    Probably since your Iat temp is monitored differently than ours only through the maf.
  3. Oct 15, 2022 at 2:56 PM
    #3663
    nobodyintexas
    nobodyintexas What?
    South of Houston
    S/C'd 2020 White 1794 Tundra
    This is my guess too
    however, you maggies probably have the same delta
    My contention is the intercooler fluid is heat soaked after say 20 minutes
    the only way to cool it is to move more air over it
    Stop lights did the same, the delta increased past 30 degrees at a long light
    then back down after a mile or so
    In short the only major affect to IAT is speed
  4. Oct 15, 2022 at 3:27 PM
    #3664
    Silver17
    Eastern PA
    2017 TRD 4x4 Harrop SC
    Would be sweet to rig up one of those CO2 intercooler sprayers, and find a way to make it only spray above a particular throttle percentage. No idea if that would even be possible though.
  5. Oct 15, 2022 at 4:32 PM
    #3665
    snivilous
    SW UT
    300k+ Supercharged 2008
    Just run nitrous and then you'll get cooling directly into the combustion chamber instead of the round about way of cooling the intercooler.
    Honestly doing a simple water drip (like a swamp cooler) would probably do a lot and be super simple.
  6. Oct 15, 2022 at 4:40 PM
    #3666
    Silver17
    Eastern PA
    I have thought of a water sprayer/mister or something similar before. It would have to be distilled water as to not get calcium buildup all over the intercooler, but it would probably help a lot. For the most part, it think cooling the intercooler loop is a waste of effort.
  7. Oct 15, 2022 at 6:18 PM
    #3667
    M3Tundra-JK
    M3Tundra-JK New Member
    Scott
    2005 GX470
    A large pusher fan may be in order if you also have a trans cooler up front.
    My E46 M3 has an OEM pusher fan in front of everything, and I converted the crank puller fan to electric
  8. Oct 15, 2022 at 11:23 PM
    #3668
    Gungho
    Gungho New Member
    Michael
    2019 Tundra TRD Pro
    As per @nobodyintexas suggestion. Just ordered a stage 2 harrop for my 2019 stock tires and trd wheels at 36000 miles. Wish me luck :). Crossing my fingers No bad wiring harnesses. Went with d3 pulley, 650s and tuning package.
    omgboost, reywcms, mZiggy and 2 others like this.
  9. Oct 16, 2022 at 4:20 AM
    #3669
    nobodyintexas
    nobodyintexas What?
    South of Houston
    I pondered an electric fan in front that would only come on <1000 rpms.
    My thought was to cool the I/C at stop lights.
    but...not enough juice for the squeeze.
    now -I'm just gonna run this b1tch till the wheels come off.
    reywcms likes this.
  10. Oct 16, 2022 at 4:28 AM
    #3670
    nobodyintexas
    nobodyintexas What?
    South of Houston
    Question for the hive....
    I run stock 1794 wheels/tires - 20's.
    32 inches tall.
    the question -
    If I put wheels/tires on that were ~28.5 inches tall...would that simulate 5.29 gears? or ~3400rpm
    or am I thinking wrong?
    @Saltyhero13 's chart
  11. Oct 16, 2022 at 5:28 AM
    #3671
    Silver17
    Eastern PA
    Going by this calculator I think it would be closer to a 4.88, if I did that right.
    That said it would essentially be the same resulting ratio as someone with 35s running 5.29 gears.
  12. Oct 16, 2022 at 5:53 AM
    #3672
    Black@Blue19
    Black@Blue19 Old Salt
    Ken
    SE Texas
    These would let massive amounts of heat rise out!
  13. Oct 16, 2022 at 7:09 AM
    #3673
    ZPhilip
    ZPhilip Custom title here
    Philip
    West Chester, PA
    If I’m reading that chart right, you would have to go down to less than a 28” (like around 25”) diameter tire to effectively get your 5.29 gear ratio. But I like think you would just spin tires like crazy.
    Saltyhero13 likes this.
  14. Oct 16, 2022 at 8:36 AM
    #3674
    Saltyhero13
    Saltyhero13 Throbbing Member
    The chart is telling you how to get into a specific band i.e. power vs efficiency by changing tire or gears.
    The calculator is telling what gear ratio is need to restore your current ratio. That's the only additional information its is really adding. I would be less concerned about effective ratios and more interested in which efficiency/power band I'm in.
  15. Oct 16, 2022 at 9:00 AM
    #3675
    snivilous
    SW UT
    As Silver said, 32/28.5 * 4.3 = 4.83 which would be the effective gearing. By comparison 32/26*4.3 = 5.29, so a 26" diameter tire has the same force applied to the ground as a 5.29 does with a 32".
    reywcms and Silver17 like this.
  16. Oct 16, 2022 at 9:36 AM
    #3676
    M3Tundra-JK
    Scott
    2005 GX470
    Just another gear/tire/driveshaft chart I used when ordering for my JK
  17. Oct 16, 2022 at 9:48 AM
    #3677
    Silver17
    Eastern PA
    I believe there is a breaking point where lower gearing actually translates to a slower truck when you have a certain amount of wheel horsepower to weight ratio, also depending on tire size. I was playing with a gear calculator for the best 1/4 mile times given my truck size and weight. I’ll include the link. It said my ideal ratio with 32.5” tires, 500whp, and 6500 lbs is 4.38 so guess I’m staying stock. https://www.motivegear.com/wp-content/uploads/calculator/drag-performance-calculator.html
  18. Oct 16, 2022 at 12:03 PM
    #3678
    e30cabrio
    West Valley, Phoenix, Az.
    Boosted 2013 Sequoia TRD FAUX
    What is a reasonable price for a used TRD set up? Seller asking 6k, I'm thinking that is steep considering it has to be sent out to be rebuilt or one risks killing it seeing as there is no way to know what condition/how much stress miles it had.
    TRD supercharger kit used original 7psi pulley Comes with majority of the components minus what’s listed below: *no belt, buy a gates green *No tune, you have options VFtuner and HPtuners *No in-tank fuel pump which you should already upgrade to a prospeed kit.
    Also he says at full asking engine harness is incuded. What harness is that & is it needed?
  19. Oct 16, 2022 at 12:08 PM
    #3679
    nobodyintexas
    nobodyintexas What?
    South of Houston
    buy a new kit...you will live a happier life.
  20. Oct 16, 2022 at 12:27 PM
    #3680
    reywcms
    reywcms New Member
    Rey
    Beaverton,Oregon
    I bought my blower used and bought the fit kit new. And still came in cheaper. At that price I’d buy new
    snivilous[OP] and M3Tundra-JK like this.
  21. Oct 16, 2022 at 12:36 PM
    #3681
    e30cabrio
    What did you pay? Did you need to rebuild the blower?
    I'd think 3k is the most that is reasonable used. What is the harness? Does it come with a new kit?
    snivilous[OP] likes this.
  22. Oct 16, 2022 at 12:37 PM
    #3682
    M3Tundra-JK
    Scott
    2005 GX470
    Def get a new kit over that. Rebuild is going to be $2k minimum. New blower and kit is only $7500. I paid $3500 for my new trd blower assembly
    e30cabrio, snivilous[OP] and reywcms like this.
  23. Oct 16, 2022 at 12:49 PM
    #3683
    reywcms
    reywcms New Member
    Rey
    Beaverton,Oregon
    My used blower was freshly rebuilt and never reinstalled. I’m into mine $5.5k I think. Not including upgrades that I added.
  24. Oct 16, 2022 at 1:16 PM
    #3684
    Black@Blue19
    Ken
    SE Texas
    You can buy new for just a bit more and know exactly what you will have!:)
  25. Oct 16, 2022 at 1:47 PM
    #3685
    snivilous
    SW UT
    I paid $3k for mine, minus the tune, fuel pump, and the oil cooler lines. $6k is insane, once you add in the shit it's missing it's the same price as new.
    For the record a blower rebuild from SCOL is $1250 iirc, assuming the rotors themselves are fine which unless you sucked something in they should be.
    mustang67408, HulkSmurf14 and reywcms like this.
  26. Oct 16, 2022 at 2:17 PM
    #3686
    e30cabrio
    Which would be clearly visible I assume?
    I'm thinking I'll offer 2k & see what happens.
  27. Oct 16, 2022 at 5:20 PM
    #3687
    snivilous
    SW UT
    I'd think so, mine ingested a rock or a socket and had visible marks on the rotors. My rotors also became mistimed which might explain the wear on the edges. New rotors are an additional $1250. For the record this was of my doing, the blower was fine when I recieved it used and this was a few years later.
  28. Oct 16, 2022 at 5:43 PM
    #3688
    e30cabrio
    Thanks, I'll hold out for new. I have the weird Whipple recurring dream. Can't find anyone that can provide input.
  29. Oct 16, 2022 at 7:58 PM
    #3689
    M3Tundra-JK
    Scott
    2005 GX470
    That's way cheaper than they quoted me for a Tacoma S/C rebuild
  30. Oct 16, 2022 at 8:09 PM
    #3690
    snivilous
    SW UT
    Just checked my quote, and granted this was nearly 2 years ago but it was $1350 for the basic rebuild/gaskets, and excluding shipping.
