Puddle lights and under hood lights options.
Discussion in '2.5 Gen Tundras (2014-2021)' started by Rangergillikin, Oct 5, 2022.
  1. Oct 5, 2022 at 5:54 AM
    Rangergillikin
    Rangergillikin [OP] New Member
    Alabama
    2021 magnetic grey TRD Pro Crew Max.
    TracRac bed rack, Retrax bedcover, Anytime forward facing camera, Rago dash mounting plate, changed all lights to LED with 1200lumen reverse light, added LED above tag reverse light, rear bumper step, Go Rhino step sides, CCM Cat Security Shield, tool mounts on bed rails, added tie down pad eye on bed rails.
    I want to add rock lights or something under my step sides to use as puddle lights that will light up when I open my doors. Looking for light options. Also want to add a under the hood light. Ideas needed. Thanks
  2. Oct 5, 2022 at 6:00 AM
    RainMan_PNW
    Casey
    Clark County, WA
    2021 Lunar Rock TRD Pro CM
    Dunno on the puddle lights, but for the under hood light search @mattgecko on here
  3. Oct 5, 2022 at 6:19 AM
    Taco-Spike
    Two Trucks
  4. Oct 5, 2022 at 6:49 AM
  5. Oct 5, 2022 at 9:40 AM
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    2017 Tundra Platnium
    Too many mods to come
  6. Oct 5, 2022 at 9:59 AM
    1lowlife
    DADA
    THE GREAT STATE OF TEXAS
    2014 MGM DC SR5
  7. Oct 5, 2022 at 10:11 AM
    Ghost Rider
    Ian
    Cypress, Texas
    2021 White Tundra CM SR5
    Can you show if you have pictures of where you tapped into the driver's footwell LED?
    I dreaded wiring it to the dome light as it was said to be done....
  8. Oct 5, 2022 at 10:16 AM
    texasrho83
    texasrho83 Old Member
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    I stuck em in the old OEM style tow mirrors
    panicman and Taco-Spike like this.
  9. Oct 5, 2022 at 10:21 AM
    Taco-Spike
    Two Trucks
    You might not need to tap anything.
    Use the base bulb adapter and a Y splitter to connect to the puddle lights
    BASE ADAPTER 2 PIN FEMALE 74 (vleds.com)
    2 PIN WATERPROOF HARDWIRE Y ADAPTER (vleds.com)
    Literally plug and play (minus the drilling)
    That base adapter is used with the footwell lights
    Rangergillikin[OP] and Mater like this.
  10. Oct 5, 2022 at 10:25 AM
    Mater
    Mater New Member
    SD
    2016 MGM Platinum
    For puddle lights, I’d look for something that uses the OEM hole and mounting option and doesn’t use glue or some other adhesive to attach. I’ve had the drive brights for 3 years now and am very happy with them. Can’t find the link to them anymore , but it looks like morimoto offers something similar. Anyway, just my $.02
    https://www.morimotohid.com/Toyota-Tundra-07-20-XB-LED-Mirror-Lights_2?quantity=1
  11. Oct 5, 2022 at 10:30 AM
    1lowlife
    DADA
    2014 MGM DC SR5
    I did all this at the same time.
    Cut the bulb off and ran the puddle and footwell lights from that wire/circuit..
    All connections were soldered and heat-shrink wrapped.
    I don't really have a specific pic of that connection.
    I'd imagine it looks pretty much like this one from another project.
    This was when I tapped into the dash light dimmer circuit to install my blue console LEDs.
    Even being on the dimmer switch I had to put resitors inline to dim the LEDs down.
    I just wanted a very dim light on the console.
    2DABA097-0455-4FE1-A62E-D7EF79533D06_zps_bbe0f48d32c04536b1d1ea2d804b1f9a9d718c7a.jpg CF69CBCC-22B4-4355-AF0C-9605BEF29406_zps_15095c20d02bff9f38933ea73dcb6331b121664a.jpg
    0CFD616A-16FC-4FB1-9480-4EC3CCDC3038_zps_a0b4e1b479f88944c3976085a3e04afe0cb774e3.jpg
    0CC7FE06-9CF2-4CF6-9B00-0F18E8D6700B_zps_2cb6643b590fc4d930919ae1311db6beb776d922.jpg 59CA8D93-B9D8-4BF5-99BE-18C94846A26B_zps_4f70b11b5a9ee480292afff69ef0d0def08b5854.jpg
  12. Oct 5, 2022 at 10:31 AM
    Ghost Rider
    Ian
    Cypress, Texas
    Taco-Spike[QUOTED] likes this.
  13. Oct 5, 2022 at 10:33 AM
    1lowlife
    DADA
    2014 MGM DC SR5
    Lucky your Platinum had the hole and wiring.
    My SR5 I had to cut the hole and run all the wiring..:thumbsup:
    I've had the stick on VLEDs for years without a problem.
  14. Oct 5, 2022 at 10:34 AM
    1lowlife
    DADA
    2014 MGM DC SR5
    You can use the adpater @Taco-Spike posted or just cut it off.
    You might as well run/install some better footwell lights while you're doing your puddle lights..
    That little footwell light is worthless.
    It isn't very hard..
    Just buy decent quality LED strips that will stay stuck.
  15. Oct 5, 2022 at 10:43 AM
    Drixles1794
    Drixles1794 New Member
    2018 Black Tundra 1794
    I have these. They're very bright and they're plug and play under the mirrors if you have them currently.
  16. Oct 5, 2022 at 10:56 AM
    I run my puddle lights and footwell lights off of the adapter. Just splice the 2 together.
  17. Oct 5, 2022 at 10:59 AM
    1lowlife
    DADA
    2014 MGM DC SR5
    If you're going to have to splice the wires anyway, what is the point of the adapter?
    Why not just cut the bulb off?
    Even if you change the lights, you still have to cut and reconnect.
    Although I guess doing your wiring my be easier not being stuck under the dash..:D
    Tundra234[QUOTED] and Taco-Spike like this.
  18. Oct 5, 2022 at 11:02 AM
    Taco-Spike
    Two Trucks
    My option was not to tap / splice anything, just use that adapter as your source. Would be the easier option.
    1lowlife and texasrho83 like this.
  19. Oct 5, 2022 at 11:03 AM
    texasrho83
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    x2
  20. Oct 5, 2022 at 8:29 PM
    panicman
    Eric
    2018 SR5 CM TRDoffroad MGM
    I’ll have to look at the adapter and Y they have linked a little harder.
    I created that VLED thread for SR5 because there was nothing for SR5 at the time that showed how to drill out the housing and get power into the mirror. I piggy backed on the other thread (which had an aim of installing puddle lights on tow mirrors) quite a bit, including finding power, but be warned that the factory wiring looms differ year to year. For a 2018, you’d pull up the rocker plate at the driver door, pry the loom cover open, and look for a small pink wire. There are a couple that look identical. I used a posi tap, and tried a wire or two before landing on the correct one. Here are the pics from that thread:
  21. Oct 5, 2022 at 9:47 PM
    Rangergillikin
    Alabama
    Thanks for all the ideas. I see there are a few good options to think about. I looked under my mirrors and I see the circle where I guess they use to put light before. I’ll probably just drill it out like others have done. Thinking about getting the mattgecko lights for the bed. Those are nice looking. The KC work lights might be a good option for under hood. Thanks again for the ideas.
  22. Oct 7, 2022 at 5:43 PM
    SwitchThrottle
    2021 Barcelona CrewMax
    I've been in analysis paralysis on puddle lights in mirrors vs rock lights on frame. I'm pretty much sold on https://luxlightingsystems.com/collections/led-lighting-for-trucks.
    I like that they are ip68, magnet mounting, and made in America. They are $$$ though.
    The vleds kits are very tempting due to the plug and play aspect.
    :annoyed:
    Rangergillikin[OP] likes this.
  23. Oct 7, 2022 at 6:44 PM
    FYI the cutout dimensions needed for the Vleds universal light is 1.5 inch.
