  1. Oct 4, 2022 at 6:52 PM
    I got it from Overland Equipped. Another member on here told me to try them as he had one in his Tacoma. It shipped fast too. It's designed so that the screws don't interfere with the fuse markings on the inside of the lid. I bought my Blue Sea stuff from Amazon since it was cheaper than the marine store. Overland does sell it as well.
    https://overlandequipped.com/collec...use-block-bracket-for-2007-2021-toyota-tundra
  2. Oct 4, 2022 at 7:00 PM
    300BLK
    300BLK New Member
    2014 Tundra SR5 - Black
    That's really nice. I might just get that too. I was going to try my hand at bending a bracket myself, so depends on how much i mess that up :D I have the same Blue Sea block you're using and i'm also adding winch disconnect.
  3. Oct 4, 2022 at 7:09 PM
    Abos
    Abos Long live 5.7L V8
    2014 SR5 Crewmax
    I felt the exact same way. I bought one this past winter, used it for a few days and then took it out and returned it. Just not worth $300. If I want to have a touchy gas pedal, I can just push the tow/haul button.
  4. Oct 4, 2022 at 11:01 PM
    Rangergillikin
    Rangergillikin New Member
    Alabama
    2021 magnetic grey TRD Pro Crew Max.
    TracRac bed rack, Retrax bedcover, Anytime forward facing camera, Rago dash mounting plate, changed all lights to LED with 1200lumen reverse light, added LED above tag reverse light, rear bumper step, Go Rhino step sides, CCM Cat Security Shield, tool mounts on bed rails, added tie down pad eye on bed rails.
    Thanks. I saw Tundra234’s setup after I posted mine and thought that would have saved me a few days. That’s a nice looking set up. I love mine but it took a few days to build. Working with stainless can be a pain in the ass. I got my BlueSea hardware off Amazon also. I built a tray for mine today and got it permanently mounted. Love how it turned out and I love that I can remove the fuse cover box without having to take anything loose. Now I need to buy more lights.
    Tundra234[QUOTED] likes this.
  5. Oct 5, 2022 at 2:08 AM
    Eborseti22
    Eborseti22 New Member
    Evan
    2020 Toyota Tundra TRD Offroad
    Yea I had platisipped my Tacoma rear number when I had it. Lasted me over 4 years before I could see any chrome through it. But of course that was the back of the truck. I’d be really curious to see how long you ca go on the front with the dip and bed liner!
    dip is easy to remove, ever try to take anything like yours off? Or touch it up?
  6. Oct 5, 2022 at 6:02 AM
    joey2018
    joey2018 New Member
    I think it’s the angle of the pic. It still has a very slight rake to it but not much. If you look at the top pick it looks pretty level.
  7. Oct 5, 2022 at 6:08 AM
    kyle112006
    kyle112006 New Member
    Kyle
    If this is still available im interested
  8. Oct 5, 2022 at 6:29 AM
    It's not the full kit as pictured. Just the 3 knobs and I purchased them from him.
  9. Oct 5, 2022 at 8:51 AM
    Jaypown
    Jaypown New Member
    Justin
    Rubber City
    Just rolled over to my 3yr lease mileage limit with 14 days to go. With the new leasing so high, decided to buy it out and keep it for quite some time.
    Now time to buy new tires, rotors/pads, and get an alignment.
  10. Oct 5, 2022 at 12:21 PM
    Tripleconpanna
    2021 TRD PRO CM; 2008 SR5 CM
    I'm normally not a fan of red trucks, but that color is bada$$!!!!
    Ryuu[QUOTED] and Taco-Spike like this.
  11. Oct 5, 2022 at 2:00 PM
    Ryuu
    Ryuu Hwat!?
    Oscar
    SouthEast, TX
    2017 TRD PRO Barcelona Red
    a few
    Thanks! :fistbump:
  12. Oct 5, 2022 at 2:05 PM
    WFD473
    WFD473 Long Live The V8
    Northeast Illinois
    2014 MGM SR5 CM 4x4
    Those look like Rock Warrior wheels. If so, are you running spacers? Like others have said, looks awesome!!
    Ryuu[QUOTED] likes this.
  13. Oct 5, 2022 at 2:19 PM
    Ryuu
    Ryuu Hwat!?
    Oscar
    SouthEast, TX
    a few
    Yes they’re RW wheels and yea running 1.75” BORA spacers, I’m around a +5.5offset with them. Thanks!
    WFD473[QUOTED] likes this.
  14. Oct 5, 2022 at 3:15 PM
    2020Platinum
    2020Platinum www.youtube.com/NitroZ18Fishing
    Patrick
    Northeast PA
    2022 TRD Pro (Lunar Rock)
    A lot. See my channel for all installs/mods!
    thanks for the support and checking out the videos!…hope you’re liking them!
    GELCW and 713Tundra[QUOTED] like this.
  15. Oct 5, 2022 at 6:30 PM
    Bergy24
    Bergy24 New Member
    After 5 days of rain, went to wipe down my truck, only to find a screw in the right rear tire. I was going to have my son take it to his shop to fix since the screw is in the center of the tread, but then I remembered I had the Tire and wheel warranty with Toyota. Pulled the PRO wheel/tire off the truck and put on the oem TRD OR wheel/tire real quick and then took it to my local dealer. The dealer won’t fix the tire under the warranty I have. They will only replace it which is fine with me. My only concern is that the rest of the tires will have slightly less tread. Thinking of pulling the spare and swapping it so I have 2 new tires, thoughts? I did confirm the warranty has no limit. The advisor said I could have 100 tires replaced and never pay out of pocket,(as long as there’s at least 3/32 and not damaged due to being under inflated) I didn’t take the time yet to check my other 3 tires to see if they have a screw too.
    Hopefully they don’t damage the PRO wheel and balance it correctly. Took detailed pictures of the both sides of the wheel before I left it with them.
    Tripleconpanna likes this.
  16. Oct 5, 2022 at 6:50 PM
    TrashcanBand
    TrashcanBand New Member
    CenTex
    Tundra
    $7 plug kit at the auto parts store plus about 10 minutes. Unless you need an air compressor too…. Then it’ll be a little more. What better time to invest?
    RainMan_PNW and Blowdart like this.
  17. Oct 5, 2022 at 6:56 PM
    Bergy24
    Bergy24 New Member
    I could have gone that route, but why not use my warranty and get a new tire?
  18. Oct 5, 2022 at 7:16 PM
    Bakershack
    Kelly
    Spanish Fort, AL
    2020 SSM 1794 4x4
    It's a conspiracy. I had to go back to the office this evening because I forgot something that couldn't wait until tomorrow. About 1/4 mile before I turned in, I heard the all-too-familiar bump bump bump that indicated something was in one of my tires. I drove into the plant, parked, and saw 1/2 inch of a screw sticking out. The tire wasn't noticeably losing air but I didn't want to risk the 25 minute drive home with it in there, so I changed it. Dang that sucks!
  19. Oct 5, 2022 at 7:34 PM
    texasrho83
    texasrho83 Old Member
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    Joined the dash pad geezer club today
  20. Oct 5, 2022 at 8:05 PM
    :thumbsup:
    Taco-Spike likes this.
  21. Oct 6, 2022 at 4:41 AM
    Jaypown
    Jaypown New Member
    Justin
    Rubber City
    How are they attached...if they are. If not, I'm curious if driving down the highway the wind will make it shift and move around.
  22. Oct 6, 2022 at 4:46 AM
    texasrho83
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    Velcro
    Jaypown[QUOTED] likes this.
  23. Oct 6, 2022 at 4:56 AM
    Spyker
    Spyker I’m a dude,playin a dude,disguised as another dude
    Are there any benefits to a dash pad, I’m just curious, because I do kind of like the look.
  24. Oct 6, 2022 at 5:13 AM
    Prevent dash glare and dash protection if you park in the sun primarily.
    Spyker[QUOTED] and texasrho83 like this.
  25. Oct 6, 2022 at 5:20 AM
    texasrho83
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    x2
    I use dash protectant but wanted to try this. Especially since we are big on sun here
  26. Oct 6, 2022 at 5:38 AM
    RusPro21
    RusPro21 Pro is gone! But I’m still here.
    Don
    Pa.
    2021 Pro!! Nitto’s Tyger blades, Arc audio!
    I’m going this route instead of using my weather tech sun shade. More convenient and still looks good.
    texasrho83 likes this.
  27. Oct 6, 2022 at 5:39 AM
    Cthulhu
    I think that looks awesome. Now you got me thinking...I have the Rago modular dash mount. Wonder if I got this pad, if I could cut the fabric to accommodate the dash mount mounting holes, then put the dash mount on top of the pad. The pad fabric would then minimize the gaps between the dash mount and the dash that exist now, and also provide extra securement points for the pad other than the velcro...
    :monocle:
  28. Oct 6, 2022 at 5:39 AM
    Same here. I use 303. Not to jack the thread, but I saw a cool decal the other day. "Get off my ass or I'll deploy your airbag".
    mr0351, Vr0ck, NewImprovedRon and 5 others like this.
  29. Oct 6, 2022 at 5:47 AM
    texasrho83
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    They're completely customizable that way. In fact the instructions say that if there's a sensor they didn't cut for, take some sharp scissors and get to cuttin
    Cthulhu[QUOTED] likes this.
  30. Oct 6, 2022 at 5:49 AM
    Cthulhu
    Thanks! What fabric did you buy?
