General Supercharger Thread
  1. Oct 4, 2022 at 11:01 AM
    #3451
    Warreng
    Warreng New Member
    People on here say change sc oil (trd) at 100k miles, magnesum says it never needs to be done.
    What are peoples thoughts?
    I understand u can draw the old oil out with a syringe? (Did this on my gen3 4runner sc but not sure about this one)
  2. Oct 4, 2022 at 11:04 AM
    #3452
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    Toyota also promotes lifetime transmission fluid.... My opinion would be to just change the oil. I have no opinion on the syringe, I haven't looked into it. I only have about 10k on my unit.
    Additional opinion: Chances are that the coupler won't last 100K, kill two birds with one stone and do both at the same time.
    snivilous[OP] and HulkSmurf14 like this.
  3. Oct 4, 2022 at 12:30 PM
    #3453
    snivilous
    SW UT
    300k+ Supercharged 2008
    I don't recall there being a way to change the fluid through the front though, I think the only oil access port is through the rear of the blower. (Assuming you were talking about just pulling the nose cone and not the entire blower off)
    The REAL way to do it, is buy a Sniv Modular Supercharger Pulley, remove the entire blower, do the oil and the coupler and the pulley in one go and reinstall :D
  4. Oct 4, 2022 at 12:34 PM
    #3454
    HulkSmurf14
    2014 Tundra Limited
    Tastefully enhanced...
    Here, here!
  5. Oct 4, 2022 at 12:36 PM
    #3455
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    2017 Tundra Platnium
    Too many mods to come
    Then proceed to help our harrop brothers on the side of the road lol
  6. Oct 4, 2022 at 12:45 PM
    #3456
    HonorNotInner
    HonorNotInner I speak the 3rd most eyetalian
    Alex
    Fort Worth
    Added money to it.
    I’ll have to start keeping snacks in the truck for when I get stranded lol
  7. Oct 4, 2022 at 12:45 PM
    #3457
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    Ya, I was thinking in terms of removing the whole dang thing. You know, make a day of it...
    snivilous[QUOTED][OP] likes this.
  8. Oct 4, 2022 at 1:12 PM
    #3458
    M3Tundra-JK
    M3Tundra-JK New Member
    Scott
    2005 GX470
    Just tell me where to send my money!
  9. Oct 4, 2022 at 1:18 PM
    #3459
    Silver17
    Eastern PA
    2017 TRD 4x4 Harrop SC
    Man, in that case I better find some more local magnuson friends on the east coast. You guys will eat through 3 couplers on your trek across the US to help me out. I’ll have fashioned all new wiring harnesses for myself out of roadside debris by the time you arrive.
    On a serious note, and only 10% to poke fun…I would be curious about pieces of the worn couplers falling into the oil (it’s inside the same cavity) and getting ground up further by the rotor gears and getting into the bearings. I’ve only ever seen 1 blower have the bearings actually totally fail though and subsequently take out the engine. Point being, if anyone notices coupler noise I’d get it changed out, as well as the oil ASAP.
    reywcms[QUOTED] likes this.
  10. Oct 4, 2022 at 1:25 PM
    #3460
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    LOL.
    Silver17[QUOTED] likes this.
  11. Oct 4, 2022 at 1:59 PM
    #3461
    snivilous
    SW UT
    Few corrections :D . The coupler is completely isolated from the oil. When you remove the nose cone there's just this cavity where the coupler is chilling and nothing else really, just a hollow compartment. Even in the event that the coupler completely disintegrates (which usually it becomes "loose" and is less of a press fit than normal) then the would have to leave the cavity they sit in and would enter the rotor area. The oil is at the back of the blower, presumably just to lubricate the alignment gears, and is separate from everything else. Plus the coupler is just plastic, maybe fiber reinforced, so it's not doing much even if it gets caught.
    I'm just giving you shit, but just so everyone else understands and doesn't get scared: a loud coupler is not remotely what I'd call a big issue. It should (eventually) be addressed, but all that a failed coupler results in is increased backlash between the rotors and the pulley resulting in it making noise as the coupler develops slop and kind of slaps back and forth. The oil is completely isolated from the rest of the unit, just as the coupler is fairly isolated from everything else too.
    EDIT This was incorrect: You essentially have three compartments, the timing gears/oil, the rotors/core, and the coupler/front casting/nose cone. All of which are sealed from everything else.
    EDIT Correction: The coupler is in the same compartment as the rotors, albeit in it's own cavity. In the event of catastrophic failure of the coupler it could result in being ingested into the engine. However that would involve the coupler cracking apart, which is not the failure mode of a "worn coupler".
    reywcms and HulkSmurf14 like this.
  12. Oct 4, 2022 at 2:07 PM
    #3462
    Silver17
    Eastern PA
    My intent wasn’t to scare anyone. I was truly being genuine in the suggestion. I’ve never seen the magnuson for these trucks apart, I was just going off the construction of this video that I had watched for a VMP unit in which it appears to be constructed with the coupler hanging out right above where the oil resides. The oil is common to the front and back of the blower as the gears on both ends rotate together with the gears meshed. I assumed they were all constructed similarly.
    https://m.youtube.com/watch?v=3NFfZaS1XBU
  13. Oct 4, 2022 at 2:09 PM
    #3463
    M3Tundra-JK
    Scott
    2005 GX470
    At least it's not a spring loaded coupler like the taco! My spring had deformed and was trying to poke out the side when I swapped to a solid coupler
    Not my pic
  14. Oct 4, 2022 at 2:13 PM
    #3464
    snivilous
    SW UT
    I updated my post since I did have one thing wrong...maybe (hopefully not more!). Been awhile since I pulled the nose cone so going off of SCOL photos:
    The coupler is in the front compartment which is isolated from the gears. Where I was wrong is that the coupler is not completely isolated from the rotors, since in the following picture I think that is the rotors you see which makes sense. So the coupler if it disintegrated would have the capability of getting to the rotors, however that would require the coupler breaking apart which is different from the failure mode of the holes wallowing out:
    The rotor assembly has the gears at the back, which in the following picture is the block at the bottom (or my assumption). The top shafts I assume slide into bearings, with the longer side then interfacing the coupler, point being that the oiled compartment (block on the bottom) is isolated from the coupler:
    Silver17[QUOTED] and reywcms like this.
  15. Oct 4, 2022 at 2:18 PM
    #3465
    snivilous
    SW UT
    And to add after watching that video, that supercharger is using the rotors flipped around from how ours is. Their nose cone interfaces directly to the timing gears, so all of that is lubricated. However there is no oil pass through to the back of that supercharger shown, so the bearings that hold the far side (intake side, in both their case and our case) are not actively lubricated. Only the timing gears, and anything in it's vicinity.
  16. Oct 4, 2022 at 2:52 PM
    #3466
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    Went out and checked slack to all wires/plugs. Maf, TB, Cam phasers (Pops had an issue from being tight and went to limp mode and wouldn't fire). All good, but won't hurt to check yours.
    Silver17 likes this.
  17. Oct 4, 2022 at 3:00 PM
    #3467
    Silver17
    Eastern PA
    After watching the video I posted hopefully one could see my cause for concern for the scenario of the coupler failing on that particular design. I see from your posts it is a different design, so not all of the concerns are the same. Given the tolerances of the rotors I personally wouldn’t risk driving around at all with a worn coupler and the remote chance sending plastic pieces of any kind through the rotors spinning 10k+ RPM and then into my engine. Now if you’re done razzing me and editing your edits, I have wiring connectors to check on my Harrop. :rofl:
  18. Oct 4, 2022 at 3:03 PM
    #3468
    Silver17
    Eastern PA
    @nobodyintexas were you able to get your truck home ok? Then again I’m ahead in time zone here…maybe you haven’t left yet.
  19. Oct 4, 2022 at 3:32 PM
    #3469
    snivilous
    SW UT
    Don't worry, there's only an issue if you suck in a rock or a socket like I did. I wouldn't sweat the coupler :D
    Saltyhero13 and Silver17[QUOTED] like this.
  20. Oct 4, 2022 at 3:35 PM
    #3470
    nobodyintexas
    nobodyintexas What?
    South of Houston
    S/C'd 2020 White 1794 Tundra
    Nope
    was instructed not to start it again
    Could damage throttle position sensor or throttle body. Or both
    I’m in the square-tire f350 flatbed
    I should get the harness by Friday
    it still had all the codes when I scanned it before I left
    such is the life of the boosted
    And for those that thought about driving the plaid to work…the wife denied me
    I used to be the boss
  21. Oct 4, 2022 at 4:04 PM
    #3471
    Silver17
    Eastern PA
    Did Chris have anything more interesting to say about the harnesses?
  22. Oct 4, 2022 at 4:05 PM
    #3472
    snivilous
    SW UT
    Bro what
    Saltyhero13 and reywcms like this.
  23. Oct 4, 2022 at 4:14 PM
    #3473
    Silver17
    Eastern PA
    That must be Texan for rides like S**t! Lol. Also, here’s your chance to upgrade to the RCF TB @nobodyintexas. You just need to break that stock one first.
  24. Oct 4, 2022 at 4:17 PM
    #3474
    nobodyintexas
    nobodyintexas What?
    South of Houston
    It’s a rough riding bitch
    needs about 2000lbs on the bed to smooth out the ride
  25. Oct 4, 2022 at 4:18 PM
    #3475
    nobodyintexas
    nobodyintexas What?
    South of Houston
    No. It’s as if it was normal
    I told him my codes issues and he knew the culprit
    we’ll see
  26. Oct 4, 2022 at 4:39 PM
    #3476
    ZPhilip
    ZPhilip Custom title here
    Philip
    West Chester, PA
    How does a wiring harness cause these issues? Is the wire an incorrect gauge or do the connection(s) come apart and then the issues start?
    boringdriver and HulkSmurf14 like this.
  27. Oct 5, 2022 at 1:10 AM
    #3477
    nobodyintexas
    nobodyintexas What?
    South of Houston
    appears wire harness looses connection by coming apart. I'll test it when I take it off.
    vq35721, Wynnded and Saltyhero13 like this.
  28. Oct 5, 2022 at 6:28 AM
    #3478
    nobodyintexas
    nobodyintexas What?
    South of Houston
    This is kinda related to S/C's....
    I work in a service industry (O&G) and we make money and get more customers by keeping our present customers happy.
    with that said -
    In the last couple days I have had "issues" come up and I dealt with the vendors politely.
    These 2 vendors responded EXACTLY the way vendors should. reasonably & professionally.
    Kudo's to:
    Harrop -Chris
    Hot-Shot Offroad - @memario1214
    I'm thoroughly impressed with you guys.
    now back to our regularly scheduled programming.
    Wynnded, reywcms, vq35721 and 3 others like this.
  29. Oct 5, 2022 at 7:27 AM
    #3479
    memario1214
    Colton
    Missoula, MT
    '21 Limited MGM CrewMax
    We greatly appreciate your support, and I'm happy that we were able to help! Little bumps in the road ain't no thing! :cheers:
    I need me one of these whiny things... I miss mine since I got rid of the Taco.
  30. Oct 5, 2022 at 9:07 AM
    #3480
    Saltyhero13
    Saltyhero13 Throbbing Member
    Sh!t. I hope they get you up and running. When I was d!cking around with the intake I noticed some of the harnesses looked janky.
