n0rth's Platinum build
Discussion in '2.5 Gen Builds (2014-2021)' started by n0rth, Aug 13, 2022.
  1. Aug 13, 2022 at 10:16 PM
    n0rth
    n0rth [OP] New Member
    J.W.
    2019 Tundra Crewmax
    Current Mods 12/16/23
    5.29 Revolution Gears
    Eaton eLockers front and rear
    Solid Offroad motor mounts
    OME Lift 613 Coils, Dakar rears w/add-a-leaf
    TRD Rock Warrior Wheels 37x12.50R17 Kanati Trail Hogs
    Ironman Pro Forge UCA's
    SOB Fabrication Bumpers
    Comeup Seal Slim 12.5RS winch
    Switch-Pros
    Baja Designs lights
    Valhalla Shields
    Previous Mods
    OME Lift 613 Coils, Dakar rear Leafs
    TRD Rock Warrior Wheels 35x10.50R17 Kenda Klever RT's
    Valhalla Shields
    Purchased a 2019 Platinum on 7/31/22 to replace my 2007 Limited. It was a one owner dealer serviced truck with 80K on the odometer. At this point I'm primarily swapping parts over from the 2007 I plan on keeping the suspension, wheels, tires, RTT/bedrack and Valhalla's from the 2007. I had just freshened up the OME suspension and put new 35x10.50's Kenda Klevers on the rock warrior wheels less than 7K miles ago.
    Picking it up and driving back
    2007 Tundra Limited
    Test fitting wheels going with the RW's with a 1" spacer up front.
    Pulled the running boards
    Went for a bike ride this morning
    Then spent the afternoon swapping the rear suspension
    Hopefully finish up the rear suspension tomorrow.
  2. Aug 13, 2022 at 10:22 PM
    Blang805
    Blang805 New Member
    Central Coast California
    2010 CrewMax Platinum 4x4
    Build in Signature
    Looks good.
    Keep the pictures coming :thumbsup:
    wyoboypt and n0rth[OP] like this.
  3. Aug 14, 2022 at 6:42 PM
    n0rth
    J.W.
    2019 Tundra Crewmax
    Finished up the rear suspension today, soaked the u-bolts in the parts washer overnight. I'll order new u-bolts and a OME add-a-leaf, it's going to need it for the high clearance rear bumper that's planned in the near future. Any thoughts on U-bolt flip kits did it on my old tacoma but I also relocated all the shock mounts and towers.
    I had read that the OME springs and shackles rub on some exhaust systems, at full droop w/o shocks I was getting contact with shocks and under it's own weight I don't see any issues.
    Shot of it in the driveway, hopefully I can swap the front out on Tuesday and get it in for an alignment and the wheel sensors swapped on Wednesday at a friends shop.
    Random pic of the Land Cruiser and Norton
  4. Aug 17, 2022 at 9:03 PM
    n0rth
    J.W.
    2019 Tundra Crewmax
    Spent the last 2 days swapping the front suspension over, Tundra parts are definitely beefier than my last Tacoma.
    Curious how the 813 coils will feel without a bumper and winch, we do have a front bumper planned but it'll be a while until we can start working on it with @STravis . I currently have 2 winches to choose from the Warn M1200 that's in the ARB on the 2007 or I have a Warn Series 15 in a box that I'm thinking may be a little overkill.
    On it's wheels again...
    I was able to come up with 3 spares tires and a jack stand to leave the old truck on. Rock Warrior wheels with 35x10.50R17 Kenda Klevers are cleaned up and in the bed for tomorrow's alignment and wheel sensor swap. Ordered 4- 1" Bora spacers and picked up a set of new TRD spline lug nuts and locks.
    It sure is a lot easier when parts come out of the box and go on the truck vs swapping parts from truck to truck but sometimes you just gotta make it work.
  5. Aug 18, 2022 at 7:45 PM
    n0rth
    J.W.
    2019 Tundra Crewmax
    Alignment done, wheel sensors swapped Rock Warrior wheels w/35x10.50R17 Kenda Klever RT on OME 613's and Dakar leafs rear.
    I found a solution for the NLA Rock Warrior center caps and it's a KMC wheel center cap T174K85-S2, I need to order some larger stickers but these worked to cover the KMC logo.
    So I've still got more to do but this will work for now.
  6. Aug 20, 2022 at 7:58 PM
    n0rth
    J.W.
    2019 Tundra Crewmax
    Updated first post with some pictures from this afternoon.
  7. Aug 21, 2022 at 10:02 AM
    n0rth
    J.W.
    2019 Tundra Crewmax
    Went out this morning after breakfast. The 613 Springs are really stiff, looking forward to adding some weight with a bumper and winch.
    Dakar rears seem to be working just fine.
  8. Aug 21, 2022 at 7:02 PM
    68 RS/SS
    68 RS/SS New Member
    MIke
    New Hampshire
    2020 TRD Sport DC
    I vote another arb bumper on this truck
    koditten and n0rth[OP] like this.
  9. Sep 19, 2022 at 9:13 PM
    n0rth
    J.W.
    2019 Tundra Crewmax
    Installed a set of Ironman Pro Forge UCA'S this evening going for an alignment in the morning.
    Bora 1" spacers added front and rear a few weeks ago.
    Jonnynewton909 likes this.
  10. Sep 19, 2022 at 9:58 PM
    Toe404
    Toe404 just a poser
    Tomas
    Concord ,CA
    '21 Cavalry TRD Sport CM
    Looks great so far :thumbsup:
    n0rth[OP] likes this.
  11. Sep 20, 2022 at 6:07 PM
    n0rth
    J.W.
    2019 Tundra Crewmax
    Really dig the way these look.
  12. Sep 21, 2022 at 9:07 AM
    TOYOTARIG
    TOYOTARIG New Member
    Ron
    Albuquerque, NM
    Hey J. W. where did you get your BORA spacers from?
  13. Sep 21, 2022 at 9:11 AM
    n0rth
    J.W.
    2019 Tundra Crewmax
    I went direct with Lenny at BORA https://www.motorsport-tech.com/ they shipped within 10 days.
    TOYOTARIG[QUOTED] likes this.
  14. Sep 22, 2022 at 8:59 PM
    n0rth
    J.W.
    2019 Tundra Crewmax
    Installed the 1/4" aluminum Valhalla plates this evening, bought them used from a member in AZ and had them on my 2007. I ordered a Valhalla front skid that I'm still waiting to ship.
    Jonnynewton909 and CaptRussia253 like this.
  15. Sep 23, 2022 at 2:26 PM
    CaptRussia253
    CaptRussia253 New Member
    Ruslan
    Clean build! Digging the 35x10.50. Thought it would look silly on the massive tundra but it fits the truck nicely.
  16. Sep 26, 2022 at 8:21 PM
    n0rth
    J.W.
    2019 Tundra Crewmax
    High clearance rear bumper installed today at SOB Fab with @STravis
    Dent Removal?
    Jonnynewton909, TOYOTARIG and STravis like this.
  17. Sep 26, 2022 at 8:31 PM
    n0rth
    J.W.
    2019 Tundra Crewmax
    More pics
    Dent removed...kinda
    Wiring
    Trimmed out
  18. Sep 27, 2022 at 5:14 AM
    CaptRussia253
    Ruslan
    That bumper looks badass. Now cut off that exhaust haha
  19. Oct 12, 2022 at 9:59 PM
    n0rth
    J.W.
    2019 Tundra Crewmax
    @STravis is working on a new front bumper for the Tundras, had a chance to hang out and see it taking form.
  20. Oct 13, 2022 at 9:14 AM
    Kappes03
    Kappes03 New Member
    2014 Tundra 1794 1996 Toyota Hilux Surf
    How are you liking those Pro Forge UCAs? Curious how long bushings and ball joints last being they are "maintenance free"
  21. Oct 13, 2022 at 6:03 PM
    n0rth
    J.W.
    2019 Tundra Crewmax
    So far they're great, inspecting the bushings and ball joints they look to be good quality so we'll see how they do over time. I really liked the way they looked and figured why not give them a try.
    Kappes03[QUOTED] likes this.
  22. Oct 25, 2022 at 4:50 PM
    n0rth
    J.W.
    2019 Tundra Crewmax
    Installed a set of Baja Designs S2 Sport Flush mounts using a Hotshot Offroad hitchpod harness and splitter huge thanks to Colton @memario1214 for getting me set up, awesome customer service and super easy install took less than 20 mins. Can't wait to set up the Baja Designs S2's, Squadrons and 30" S8 with a Switch Pros panel for the SOB front bumper that @STravis is currently building for the truck.
  23. Oct 26, 2022 at 2:50 PM
    n0rth
    J.W.
    2019 Tundra Crewmax
    We’ll be test fitting the new front bumper tomorrow.
    CaptRussia253 and STravis like this.
  24. Oct 26, 2022 at 4:06 PM
    STravis
    STravis SOB Fabrication
    Travis
    Ruidoso, NM
    17 TRD Pro CM, 08 Supercharged Single Cab
    This build is lame. Bumpers and suspension?? Where is the plasti dip? Have you even color matched anything?
  25. Oct 26, 2022 at 5:34 PM
    n0rth
    J.W.
    2019 Tundra Crewmax
    Super lame, I keep getting texts and emails that my Amazon account is locked I gave them all my info DOB, SS #, username, passwords etc. nothing yet but when they unlock it I’m going to get a case of plasti-dip, neon led’s, a bitchin 105.7” light bar it’s that long cause only half of it works when it shows up. I’m in the process of trading my RW wheels for some kick ass 29” rims with bald tires and less than an 1” of sidewall. I can’t wait to do this build right, the guy told me it wouldn’t be long until the account is unlocked but in the meantime I gave him my credit card and he said he would order all of it for me and have it drop shipped. Patiently waiting, gotta go my friend on craigslist is hitting me up about a Super charger and a mail order bride….
  26. Oct 26, 2022 at 6:49 PM
    n0rth
    J.W.
    2019 Tundra Crewmax
    More of the goods…lights and switch pros are from Hotshot Offroad, picked up the mounting plate from SDHQ.
    STravis and CaptRussia253 like this.
  27. Oct 26, 2022 at 6:59 PM
    n0rth
    J.W.
    2019 Tundra Crewmax
    ComeUp Seal Slim 12.5 RS, really like these winches after running them on my Land Cruisers.
    TOYOTARIG, CaptRussia253 and STravis like this.
  28. Oct 27, 2022 at 4:56 PM
    n0rth
    J.W.
    2019 Tundra Crewmax
    Test fit done, Travis is going to finish it up tomorrow and see about getting it to powder coat. I'm really digging how it turned out.
  29. Oct 27, 2022 at 5:09 PM
    n0rth
    J.W.
    2019 Tundra Crewmax
  30. Oct 29, 2022 at 11:33 AM
    Ckatz53
    Ckatz53 Newish
    MD
    www.fouroneodetailing.com
    Got a link to the decal you used to cover the KMCs? Noticed today one of my RW wheels is missing the center cap. Appears to be an overlay overtop of the base and the adhesive separated (they were refurbished by someone prior to me purchasing). Not spending $100 for a center cap so looking for ideas for replacements on all 4.
