Power steering fluid - Dex 3?
Discussion in '2.5 Gen Tundras (2014-2021)' started by Charliebrn, Sep 22, 2022.
  1. Sep 22, 2022 at 8:05 AM
    Charliebrn
    Charliebrn [OP] New Member
    NW Ohio
    2017 DC Limited 4x4 Tundra
    Tyger Folding Tonneau cover Polished stainless running boards LED interior lighting VLED Footwell Kit LED Bed lighting
    So I want to refresh my power steering fluid. The manual calls for Dextron II or III. The only thing I can find is DextronVI, which it says is recommended for Dex II and III.
    the fluid is red, but what looks like is in the truck is the normal brown. Is this right? It could be that the PS fluid is original and discolored… and my manual specifically calls for D3. I found an old bottle of D3 in my barn, it’s also red, so the color hasn’t changed over the years…
    Help!
    thanks!!!
  2. Sep 22, 2022 at 9:35 AM
    pursuit2550
    pursuit2550 New Member
    Trans fluid is hydraulic fluid with a red dye to help identify its impurities. As for your question, I would say that if you can’t find what it calls for then buy OEM fluid. Maybe someone has used something else. I am also interested in this.
  3. Sep 22, 2022 at 9:38 AM
    pursuit2550
    Just checked and Amazon, among other have dex 3.
  4. Sep 22, 2022 at 9:43 AM
    Winning8
    Winning8 New Member
    Da Bay Area
    2019 MGM DC 4x4 SR5
    It’s just dexron 2 or 3 atf, any auto parts store should have it….like all atf it turn brown when used.
  5. Sep 22, 2022 at 10:23 AM
    Charliebrn
    NW Ohio
    All I could find locally was the Valvoline synthetic Dex VI; but the bottle also says that it is also for Dex II and III applications.
    anyone know a reason I shouldn’t use it?
    BTW: thanks for all the responses!
  6. Sep 22, 2022 at 11:00 AM
    Winning8
    Winning8 New Member
    Da Bay Area
    2019 MGM DC 4x4 SR5
    Should be good, dexron is backwards compatible.
    Hoff likes this.
  7. Sep 22, 2022 at 12:11 PM
    Wahayes
    Will
    2017 tundra limited *sold*
    Brown = old. Time to change
  8. Sep 22, 2022 at 6:22 PM
    Joe333x
    Joe333x Member
    Boston
    2019 Tundra CrewMax Platinum
    bulldog93 and AZBoatHauler like this.
  9. Sep 22, 2022 at 7:25 PM
    Okiebug
    Okiebug New Member
    I just did mine a couple of months ago and was able to locate dex iii at O'Reillys. I believe it was valvoline in a blue 1 qt bottle.
  10. Sep 22, 2022 at 7:28 PM
    MadMaxCanon
    MadMaxCanon New Member
    '21 CM SR5 4x4 6 seater
    Too many, but not enough....
    Can I baster out what's in the reservoir and replace with new every few oil changes, like a drain and fill sorta?
  11. Sep 22, 2022 at 7:33 PM
    Joe333x
    Joe333x Member
    Boston
    Yes you can do that. Or if you want to flush it just empty the reservoir unhook the return hose and put it into a bottle, block off the outlet on the reservoir, fill it then turn the wheel left and right with the truck in accessory mode and keep refilling the reservoir until its all good fluid. Need to have the wheels off the ground to do it.
  12. Sep 23, 2022 at 4:01 AM
    MadMaxCanon
    I like the baster drain and fill since I can do the brake fluid too.
    bulldog93 and coldcanuk like this.
  13. Sep 23, 2022 at 6:20 AM
    Okiebug
    Okiebug New Member
    I tried the baster way but couldn't get the fluid clear. There was too much grime in the reservoir so after doing it about a dozen times I tried this method
    https://www.tundras.com/threads/power-steering-flush-how-to.85254/
    Much better results and isn't hard to do at all.
  14. Sep 23, 2022 at 9:39 AM
    Joe333x
    Joe333x Member
    Boston
    Brake fluid doesn't really circulate so while doing just the reservoir is better than nothing at all you're still leaving the fluid in the lines that's going to be the dirtiest. The power steering fluid does circulate but doing the flush method is really super easy and will yields better results.
    bulldog93 and snivilous like this.
  15. Sep 23, 2022 at 11:36 AM
    MadMaxCanon
    Makes sense, maybe I'll just do it to buy time since these 2 fluids are my least favorite to flush lol
  16. Sep 23, 2022 at 6:31 PM
    737fixer
    737fixer New Member
    I will never understand how this bit of information keeps being repeated over and over. Brake fluid will 1000% completely mix every last miniscule drop in your entire braking system. Every 3rd grade fluid mechanics law confirms this. It's too bad the old brake fluid dyes weren't still used to show people actually how quickly this occurs. This was a fun little experiment in shop class in the 70's to show this exact scenario. Literally if you drained and filled your reservoir and never ever ever ever drove you truck again the fluid would mix COMPLETELY although very slowly. The fact that your hydraulic brake system is under extreme pressure when being used a thousand times per month means the fluid is mixing incredibly fast. Just an extra piece of info: when you take your car/truck to 90% of dealers and they sell you the "your brake fluid has gone bad" package they only drain and fill the reservoir. Fluids mix, this is not up for debate. If you put a drop of food coloring in a gallon jug of water within 5 minutes the entire jug will be a solid color. If the same jug was .001" diameter and a mile long the color would again be uniform but simply in a longer amount of time. Add a repeating 0-90bar pump to one end and the time is reduced immensely. I am not trying to be rude but I feel very often when something gets repeated over and over again on multiple forums it somehow becomes true. The earth is not flat and fluids mix. Not something that is debatable since the 1st, 5th, 14th and/or 16th century depending on who you want to give credit to.
    G_unit3000, Weagle, reywcms and 2 others like this.
  17. Sep 23, 2022 at 6:51 PM
    Joe333x
    Joe333x Member
    Boston
    The dirt and sediment is going to stay in your brake lines closest to your calipers. If you've ever bled the brakes the fluid is darkest when you first open the bleeder and then as the clean fluid from the reservoir gets down the lines it gets cleaner. Then when you go to the next caliper even though now the fluid in the reservoir is clean the fluid in the rest of the lines is still going to be darker. Unlike the power steering fluid which has a return line into the reservoir, the brake fluid does not, so it does not circulate, anyone who has bled brakes understands this.
    Yes fluids mix, but dirt and sediment stay at the lowest points. If you have a bottle with dirt on the bottom and fill it half way with water, the dirt stays on the bottom. Then if you go ahead and fill the bottle the rest if the way, the water will mix with the other water, but the dirt is still on the bottom.
    G_unit3000 and Weagle like this.
  18. Sep 23, 2022 at 7:03 PM
    pursuit2550
    I use the brake fluid I take out as blinker fluid. It works perfect and I am recycling with is good for the environment, as per EPA guide lines.
  19. Sep 23, 2022 at 8:45 PM
    MadMaxCanon
    Just FYI Toyota of Miami is running a free shipping promo and a quart of Toyota dex 2 atf is 10 bucks a quart. Just bought 8 quarts for 83 bucks to my door and the great state of Florida didn't charge me tax.
    bulldog93 likes this.
  20. Sep 24, 2022 at 1:11 PM
    737fixer
    737fixer New Member
    Sorry to have highjacked your thread earlier on a brake fluid tangent. Toyota sells their own Dexron 3 Power Steering Fluid/Transmission Fluid part # 00718-ATF00. Old bottle said just Auto Transmission Fluid but now new bottle says Automatic Transmission Fluid & Power Steering Fluid. Both bottles have same part #. When your Toyota came from the factory the power steering fluid was typical oil golden color but the 00718-ATF00 is the standard ATF red color. Don't worry about that. NAPA also sells a Dexron 3 fluid at about half the cost which most people use. That bottle keeps changing it seems every year but I will include a picture of both the Toyota and the NAPA bottles.
  21. Sep 24, 2022 at 1:17 PM
    Joe333x
    Joe333x Member
    Boston
    Yup this is also what I used, took some photos of it.https://www.tundras.com/threads/power-steering-fluid-dex-3.113431/#post-2923488
  22. Sep 24, 2022 at 3:30 PM
    Charliebrn
    NW Ohio
    I used the Valvoline synthetic. I’ll let you know if it causes problems. Towing my camper 500+ miles up north and back. Should sort out any problems with it…
    ;p
  23. Sep 24, 2022 at 3:34 PM
    Charliebrn
    NW Ohio
    737 fixer: good call on the Toyota brand, I’ll buy a couple bottles and do anther change next oil change. Won’t be long, I’ll prob do one after I get back from the UP.
  24. Sep 24, 2022 at 3:36 PM
    omgboost
    omgboost The Accountant
    East Coast
    2012 Sequoia Platinum
    I've been using Valvoline Maxlife ATF as my power steering fluid and transmission fills. Have not had any issues over 40k miles.
    For power steering fluid, at every oil change, I use a suction gun to the reservoir and take everything out. Fill it to max, turn steering wheel all the way to the left and then right, suction fluid out another time and then fill to max.
    https://www.walmart.com/ip/Valvolin...smission-Fluid-ATF-1-QT/15125770?athbdg=L1600
    Rocko9999 and MadMaxCanon like this.
  25. Sep 26, 2022 at 11:46 AM
    e30cabrio
    West Valley, Phoenix, Az.
    Boosted 2013 Sequoia TRD FAUX
    I just looked at my reservoir. The fluid looks black through the container but is clear in the "dipstick" Upon closer inspection, the container is covered in "cracks" and looks like it is where the blackness is coming from, I'm ordering a container.
  26. Sep 27, 2022 at 12:11 PM
    e30cabrio
    Holy hell! retail is 17x.xx! WTF??
    I got a nice used one on eBay for 53 bux.
  27. Sep 27, 2022 at 12:20 PM
    Joe333x
    Joe333x Member
    Boston
    You could probably clean yours up after and resell it and get to money back. Some brake cleaner and a rag will probably get it clean.
  28. Sep 27, 2022 at 12:27 PM
    e30cabrio
    It looks like hell. Lots of tiny cracks. I could not give it away in good conscious.
    Joe333x likes this.
  29. Sep 27, 2022 at 1:49 PM
    Sumo91
    Sumo91 Busy with projects
    TN
    2014 MGM Tundra Platinum 4x4
    Dexron IV is backwards compatible with III. Use whatever flavor you like. The power steering system in these trucks aren't that picky. I use whatever ATF I have on the shelf (it's always dexron IV) and do a drain and fill on the reservoir when I think about it. Max life is a great choice and readily available.
    Just keep it changed every now and then with clean fluid and you shouldn't have any issues.
  30. Sep 27, 2022 at 1:55 PM
    pman9003
    pman9003 New Member
    2020 Platinum 4x4
    I haven't bought any to check, but this might be the mythical clear dex III the factory uses. In the southeast servicerite is the brand for a bunch of the Toyota fluids/products. I've had Toyota/Lexus vehicles serviced at dealers and they always refill with a clear steering fluid.
    https://www.ebay.com/itm/284484795141
