Another set stolen Catalytic Converters
Discussion in '2.5 Gen Tundras (2014-2021)' started by Rabbit, Jul 18, 2022.
  1. Sep 5, 2022 at 8:50 AM
    #121
    Dawoofles
    Dawoofles New Member
    Santa’s Village
    2021 Cement Tundra SR5
    TRD rear sway bar, SS3 Max Amber Fog Lights, Carthartt Seat Covers, Morimoto LED interior lights, Ihacker LED Headlights swap, Driver Side Grab Handle, Husky Floor Liners, Weathertech full SunShade, Cat Back Stainless Works Dual Exhaust, OEM metal Oil Canister, Bed Mat, Deck Rail System, OCD Center Console, Full RCI skid Plates(Engine,Transmission, Cat Guard, and fuel tank), 12” Fi Car Audio Neo 3.5 Subwoofer, Gately Box, Rear seat delete, Sundown Audio Salt 2 Amp, Stereo Integrity front stage, Pioneer DVD/CD/wireless Apple CarPlay Receiver
    I wonder if this would work just as good as cat guards
    Mike59, aRabidLunatic and coldcanuk like this.
  2. Sep 5, 2022 at 9:39 AM
    #122
    TundraTx12
    TundraTx12 New Member
    2022 Tundra 4x2 SR5 CrewMax
    I’m sorry you had to go through this. The quick turnaround at the dealer was fortunate, though. Cost is about right (mine was also $7000 for my 2014 through the dealer.)
    Many if not most of us waited much longer at dealers to get OEM parts. (mine was 5 months).
    You will find answers to your cat coverage concern in other threads. Search for cat shield, valhalla’s shield, or the name of yours, etc. There is usually a solution for the rear cat coverage.
  3. Sep 5, 2022 at 8:04 PM
    #123
    j0hnnyblaz
    j0hnnyblaz New Member
    2020 Tundra Crewmax Limited 5.7
    Thanks for this post ! Have the same truck. Bought the same kit, and used the promo. You saved me $30 with the promo, and undoubtedly $5k+ with the kit. $600.50 out the door for all 4x Cats and 2x Rivet kits.
    Mike59 likes this.
  4. Sep 5, 2022 at 8:21 PM
    #124
    lowball
    lowball New Member
    LB
    2018 Silver Tundra TRD Off Road
    yes I felt very fortunate as the dealer said it was unbelievable to have them in stock at all. Just got lucky.
    I’ll do some searching for sure. Thanks for the reply.
  5. Sep 6, 2022 at 3:33 PM
    #125
    Avi8or
    Avi8or New Member
    Johann
    MO
    2020 Limited Crewmax
    Here are a couple of shots of the Millercat add on pieces to protect the rear cats.
    Mike59 likes this.
  6. Sep 13, 2022 at 12:05 PM
    #126
    j0hnnyblaz
    I installed the Miller CAT plates and rear shields today. Whole job too a little over an hour. I used a skateboard and block to float the plate into position. Then a clamp to jack the 2x 1/4-20 bolt holes into alignment on the read of the plate. Simple one-person job.
    Got everything loose fit. Used the Red Loctite and an impact gun on the security bolts. Really pleased with the protection. I ordered 2x Rivet Nut Tools. You only need 1x.
    My one recommendation is on the rivet nuts; make sure to take a look at the small channel in the rivet nut and make sure its flattened out and the nut is drawn in completely. It'll appear as a curved recess before the threads towards the head of the nut, originally. Once tightened, all you'll see is threads.
    2020 Tundra Crewmax 5.7L 4x4 Limited, all stock.
    upload_2022-9-13_15-1-58.jpgScreen Shot 2022-09-13 at 2.59.04 PM.jpgScreen Shot 2022-09-13 at 2.58.46 PM.jpg
    jessenavarro and Mike59 like this.
  7. Sep 13, 2022 at 12:09 PM
    #127
    j0hnnyblaz
    I have the same truck and got the same kit. Thank you ! I also didn't need to raise the transfer case. I used a box wrench on the drives side to tighten the bolt to the frame. I used a 1/4" socket with the security screwdriver fitting on the drivers side main panel rear small bolt as the transfer case was in the way. No need to move it though.
    MikeyRedFL likes this.
  8. Sep 13, 2022 at 2:29 PM
    #128
    MikeyRedFL
    MikeyRedFL New Member
    SWFL
    2021 Limited Crew Max 4x4
    I did the same thing around the Xfer case....worked perfectly.
  9. Sep 14, 2022 at 9:46 AM
    #129
    NoMoreGreen
    NoMoreGreen New Member
    Robert
    2020 Tundra
    I waited 6 months for mine.
    truck was loud. Very loud.
    j0hnnyblaz, aRabidLunatic and Mike59 like this.
  10. Sep 15, 2022 at 10:57 AM
    #130
    activereality
    activereality New Member
    2020 Tundra SR5 TSS Cavalry Blue
    MillerCats installed!
    Another MillerCat set on the way! (new member - 2020 SR5 TSS)
    j0hnnyblaz, Mike59 and MikeyRedFL like this.
  11. Sep 15, 2022 at 3:34 PM
    #131
    FrostyTundra22
    FrostyTundra22 No longer new member
    2020 Toyota Tundra 1794 Crewmax
    I just got MillerCat shields installed on my 2020 1794 Edition.
    Getting the rear cat installed soon.
    449EA995-E5E1-437F-BF45-409B3FE49CE1.jpg 2B095729-E74F-4983-A097-233C2BCC7B59.jpg
    MikeyRedFL, j0hnnyblaz and Mike59 like this.
  12. Sep 15, 2022 at 6:53 PM
    #132
    j0hnnyblaz
    This is why I got the MillerCat guards. Installed cost was about the same as my deductible. But I dont have to worry about waiting for cats. Unreal lead times right now.
    Mike59 and FrostyTundra22 like this.
