Timing Belt on 05 Tundra 4.7 2UZ-FE
Discussion in '1st Gen Tundras (2000-2006)' started by Andrewb5, Sep 13, 2022.
  1. Sep 13, 2022 at 11:12 PM
    Andrewb5
    Andrewb5 [OP] New Member
    2005 Tundra Double Cab
    I've been having a stutter from the engine while idling in gear and have replaced plugs & coils to no avail. I did some research and have come to the conclusion that my timing belt could have slipped. I would think this to be unlikely but I am approaching 250k miles and to my knowledge the timing belt has never been replaced. I've bought the Gates TCKWP298 timing belt kit and will be working on it this weekend. I'll only have 2 days home from college to get the entire job done. Does anyone have any pointers? And is it possible to change the timing belt without removing the A/C compressor? I'm also not certain about lining the belt up. I know the mark on each pulley should line up with the I mark, but I've seen some people line up the marks on the belt with whichever letter is to the side of the I, while others line them up with the same I mark as the pulley. Anyone have any insight on this? Thanks in advance.
  2. Sep 13, 2022 at 11:42 PM
    NickB_01TRD
    KY
    01 Tundra V8 4X4 AC SR5 TRD
    I would say bare minimum you wouldn't want to rush this job. Toyota dealers can do it for somewhere around $1000
    You can pull one of the plastic covers back on the driver or passenger side (driver is easier) and check the belts condition. How long have you had the truck? If that belt breaks it could turn that engine into a paperweight.
  3. Sep 14, 2022 at 5:25 AM
    Can't recommend watching the process from start to finish so you know what you're in for. The 1st of these videos is one of my favorites giving a lot of the warnings/issues to be aware of. The 2nd video is another one that other folks around here like from a Toyo mech. Either way, if you suspect the belt has never been changed, you're gambling with the life of your vehicle every time you start it up. It takes 5 minutes and a 10mm ratched to loosen the bolts enough to pull back either of the timing covers to check the belt for cracks. Toyota recommends changing every 9yrs or 90k miles, whichever is first. I think 10yrs/100k is plenty fine and some guys have made it as long as you w/o changing for sure, but others have had their engine grenade via old belts snapping and jumping before 175k miles. It's all a crapshoot.
    https://www.youtube.com/watch?v=HPpzLJwoxng
    https://www.youtube.com/watch?v=Z46cM-Bw1rI
  4. Sep 14, 2022 at 2:00 PM
    Kimosabe
    Kimosabe Slacker
    Sun Valley, Idaho
    06 Tundra DC TRD 4WD
    Can we get these input in the info dump thread, or add them to some sticky post that references repairs?
    FrenchToasty and shifty`[QUOTED] like this.
  5. Sep 14, 2022 at 2:10 PM
    Kimosabe
    Kimosabe Slacker
    Sun Valley, Idaho
    I agree with the above. Take a look at the belt and see what kind of shape it is in. That will tell you what your in for. It might be an easier situation to fix.
    Speaking of, have you changed the air filter? Throttle body cleaner? MAF cleaner? A can or two of Seafoam in the tank?
    If you haven't done this before, watch the videos and do your research beforehand so you don't break everything down and then realize your missing something like the belt tensioner and get stuck. Or you can have the dealer do it and take that bit of stress off your plate. Might be worth it in the short-run.
    I haven't done the TB on the tundra, but after doing it on my 4runner I would recommend buying/renting the specialty tools that are recommended. If you need the truck back up and running, don't assume you can just get by without the proper tools.
  6. Sep 14, 2022 at 2:26 PM
    We'd started chatting through that several months back, but I don't know where we ever landed. It maybe started with a poll, and then went nowhere after?
    Ultimately, I think we need someone in the 1st Gen forum with moderation power, but only over the 1st Gen subforum itself, I think. Someone that can talk with all of the regulars here, make choices on what to stick or unstick, and work on a few "global info" threads. Ever since Pinay left, we get stuff done when asked, but I think we need some dedicated support, even if just for a couple of months.
    Not to mention, while you'll likely pay several hundred more having the dealer (or a trusted Toyota-specific shop for maybe a few hundred more) do the work, you'd get the side benefit of walking away knowing a professional that's probably done it before finished up the work, and you've got some recourse if anything is effed up.
    Aerindel and Kimosabe[QUOTED] like this.
  7. Sep 14, 2022 at 8:47 PM
    NickB_01TRD
    KY
    I'd vote you in for that in a heartbeat @shifty`
  8. Sep 14, 2022 at 9:01 PM
    Winning8
    Winning8 New Member
    Da Bay Area
    2019 MGM DC 4x4 SR5
    I would just let some professional do the job, if op haven’t done a timing belt job b4.
    shifty` likes this.
  9. Sep 14, 2022 at 10:00 PM
    Aerindel
    Aerindel New Member
    Montana
    A 19 year old neighbor kid did it for me, its been working perfectly so it can't be that hard, no offense to the neighbor kid.
  10. Sep 15, 2022 at 7:05 AM
    des2mtn
    SW
    2004 Black DC Limited 4x4
    Tonto cover
    Plan for three days, take a day and a half maybe two full days. I hadn't done a TB before, but it took me the better part of a day and a half taking my time and replacing other stuff in there.
    Bag and label all the parts you take off and keep a clean work space. Yes, move the engine accessories out of the way (AC compressor, PS pump, alternator) and take the radiator out too. Buy or rent the tool to get the crank bolt out that holds the crank. Rent a harmonic balancer puller, yours might come off by hand.
    It seems daunting at first, but if you're semi-handy with tools you can DIY. Just do plenty of research before hand and watch the videos linked above repeatedly.
    shifty` likes this.
  11. Sep 15, 2022 at 8:12 AM
    Winning8
    Winning8 New Member
    Da Bay Area
    2019 MGM DC 4x4 SR5
    Shop only call for 4hrs for a timing belt w/ water pump job…1-2 days should be enough with beer breaks…lol
    matkes77 likes this.
  12. Sep 15, 2022 at 6:12 PM
    Bilgepump
    Bilgepump New Member
    '06 Sequoia Limited 4.7L VVT-i 2WD
    All Stock
    Here is a video by a Toyota mechanic doing a timing belt change on a 2006 Tundra 4.7......
    By far, the best video I have seen on replacement of timing belt.......
    Trust us.....use the "T" mark for putting belt on.....camshafts will not unload & shift on you.....
    I believe this guy has a very useful hint for getting belt on without frustration.......watch carefully 4:20 to 5:20 mark in video......turn off music in video...very irritating....
    we are also here to help you......a lot of us have been down this road many times and are very familiar with the timing belt process.
    https://www.youtube.com/watch?v=Z46cM-Bw1rI&t=378s
    Tundra2 likes this.
  13. Sep 15, 2022 at 7:04 PM
    Same as 2nd video in reply #3 above :rofl:
    I posted that with you in mind, fwiw.
    Tundra2 likes this.
  14. Sep 16, 2022 at 10:52 AM
    N84434
    N84434 In the Frozen Tundra
    Milwaukee WI.
    2001 Limited TRD
    OP went radio silent... Perhaps he realized this was a bit more than he wanted to bite off???
    Tundra2 likes this.
  15. Sep 16, 2022 at 12:10 PM
    Baller
    Baller New Member
    '05 Tundra SR5 DC
    Here's the post I started a bit ago. Like you said, it didn't end up going anywhere. I just updated the initial post to include the two videos posted here.
    https://www.tundras.com/threads/timing-belt-master-thread-sticky.107240/
    shifty`[QUOTED] likes this.
  16. Sep 19, 2022 at 7:04 AM
    Woodyxr
    Woodyxr New Member
    2004 DC, 2006 DC
    I just did mine over the weekend. I spent about 9 hours working time between Friday and Saturday. Biggest pains were the oem radiator hose clamps and the rear bolt on the AC compressor. Not a terrible job just lots of steps and time consuming.
    Teutonics, des2mtn and shifty` like this.
  17. Nov 26, 2022 at 4:55 AM
    Navy Jumper
    Navy Jumper Airborne Paratrooper
    2023 TRD PRO
    What's the back story behind this? I havent been active for a bit.
    Tundra2 likes this.
  18. Nov 26, 2022 at 6:17 AM
    I was never really clear on this one. Wrong person to ask, I guess.
    Tundra2 likes this.
  19. Nov 30, 2022 at 3:08 PM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    @Pinay was a moderator here that either had a First Gen Tundra, or just liked us as a group. I was never clear on that. Maybe her husband had one? Dunno for sure.
    All I know is that if we needed someone to sticky a thread for us, or to clean up "Bullshit" posts in a thread that became important, she was the one to ask. Here's a link to the 1st Gen Info sump where @FirstGenVol asked @Pinay to clean up our BS, and then the thread got stickied to keep everything in one place. She even made the 1st Gen lunchtable thread, but the "OP" of that was later changed to @NUDRAT by the current moderators.
    Long story short, @Pinay was a resource to us mainly because she did as we asked, and that she "hung around" us in our threads. Always blown away by someone being crafty, or knocking out a big repair, or doing a cool mod. In no way am I trying to knock the current moderators in anyway, but it's not the same. Not necessarily in a bad way, I don't know what I'm trying to say, and I'm rambling at this point.
    I'm not trying to knock anybody. I'm just trying to get the story across.
  20. Dec 21, 2024 at 6:16 AM
    jewelgoodboy
    jewelgoodboy New Member
    jimmy
    2006 toyota tundra v8 4x4
    Toyota of naples charged me $3500 first said $1800 then they doubled it saying because of 2 belts inside ,, MPG was a little over 15 MPG
    NOW 10 MPG or less
  21. Dec 21, 2024 at 6:32 AM
  22. Dec 21, 2024 at 6:56 AM
    Unless you post a picture of the work order/receipt, I'm not buying it. If they did that, you totally got ripped off, there's only one timing belt, and $1800 is roughly the "normal" cost.
    You need to go back to them and raise hell. Maybe watch a video on YouTube of "2006 tundra timing belt replacement" before you go so you can see the process and speak intelligently to it. They have to take the serpentine belt off to do the work, but that's a $50 belt, tops, and there's no avoiding taking it off when doing timing belt.
    But the *actual* reason they charged you that much will be in the receipt.
    Lesson learned: This is why you never take your truck to the stealership. Find a Toyota specialty shop. They won't do stupid shit like this to you.
  23. Dec 21, 2024 at 2:00 PM
    Desert Dog
    2001 SR5 AC 2WD 4.7l
    Yep, I would like to see that receipt.
    Elevatorguy and shifty`[QUOTED] like this.
