5100s on order
Discussion in 'Suspension' started by groovetank, Sep 12, 2022.
  1. Sep 12, 2022 at 6:24 AM
    groovetank
    groovetank [OP] New Member
    Brad
    Hey guy new here. Just ordered a set of 5100s for my 2019 TRD Sport. I have stock 20 inch rims with k02s on. In order to get the truck near level where would you recommend I set them? Mid or top setting. Pic is of before. Once I get some input, and receive the 5100s I post after. Also will it affect TSS sensors? Thanks
  2. Sep 12, 2022 at 6:26 AM
    vtl
    vtl New Member
    Boston 'burbs
    2019 Red SR5 DC 4x4
    Mid.
  3. Sep 12, 2022 at 6:31 AM
    groovetank
    Brad
    Awesome thanks for the quick reply. Any idea how big I can go tire size on mid? Cheers.
  4. Sep 12, 2022 at 6:38 AM
    vtl
    vtl New Member
    Boston 'burbs
    2019 Red SR5 DC 4x4
    34" on any setting unless cab mount chop mod is done. I run 33" w/o chop. Mid setting in front, +1" shackles in rear. It looked more of less level before I installed a semi-hidden bumper and a winch, but going in top setting would be too harsh ride for me.
    Probably will upgrade 5100s to Fox/King. They start OK in the morning, but heat-saturate in about an hour of relatively mild driving on log roads.
  5. Sep 12, 2022 at 6:40 AM
    vtl
    vtl New Member
    Boston 'burbs
    2019 Red SR5 DC 4x4
    Best pic I have w/o stepping out in a rain.
  6. Sep 12, 2022 at 6:50 AM
    groovetank
    Brad
    Sounds great!!! No problems with your sensors going off at all? I guess an alignment is definitely a must after the 5100s as well. Hopefully all will be good. Definitely will look great, and better off road when it’s done.
  7. Sep 12, 2022 at 6:56 AM
    vtl
    vtl New Member
    Boston 'burbs
    2019 Red SR5 DC 4x4
    What sensors are you talking about? ABS? No problems with wire length at all, even with truck's frame sitting on a rock and wheel fully dropped down.
    Yes, any height adjustment requires at least a toe correction. Ideally, caster as well, but I guess it stays in the permitted range on alignment rack, so technicians don't bother. Even though visually the caster is not that good (wheels are set in V shape).
  8. Sep 12, 2022 at 7:14 AM
    groovetank
    Brad
    Awesome!!! The sensors I’m talking about are the Toyota safety sense ones. The camera in the grill, and parking sensors. Some have a problem I hear, but I think that’s a major lift. Thanks again
  9. Sep 12, 2022 at 7:18 AM
    Welcome from NY.
    Middle setting.
    No issues with the TSS sensor.
  10. Sep 12, 2022 at 7:19 AM
    vtl
    vtl New Member
    Boston 'burbs
    2019 Red SR5 DC 4x4
    No problems with radar in front grille and camera under windshield. I don't have parking sensors.
  11. Sep 12, 2022 at 7:41 AM
    groovetank
    Brad
    Brilliant!!!
