Should I order a new one or leave it off?
Discussion in '2.5 Gen Tundras (2014-2021)' started by Tifford, Sep 11, 2022.
  1. Sep 11, 2022 at 4:02 AM
    Tifford
    Tifford [OP] New Member
    Central New York
    2024 Tundra Double Cab (stock for now)
    Plastic part on front of hood. Does it do anything?
  2. Sep 11, 2022 at 4:07 AM
    The hood bulge? Would look pretty funky without it even tho it doesn't do anything....
    Tifford[OP] likes this.
  3. Sep 11, 2022 at 4:13 AM
    Retired...finally
    If it's one of those chincy stick on bulldog hood ornaments than yes, leave it off.
    Mr Badwrench likes this.
  4. Sep 11, 2022 at 5:37 AM
    This? It sounds like yours came off due to the clips. The older models had different clips and they were popping out causing the bulge to snap off. It is clipped at the top and bolted at the bottom. You would need a new bulge and it will have the newer designed clips.
  5. Sep 11, 2022 at 7:40 AM
    I_Am_Thee_Walrus
    I_Am_Thee_Walrus New Member
    ‘21 Tundra TRD Off-Road
    if it’s the Chrome “bulge”, a lot of people give them away so should be easy to find a replacement.
  6. Sep 11, 2022 at 5:01 PM
    Tifford
    Central New York
    Thanks everyone
  7. Sep 11, 2022 at 5:11 PM
    Weight reduction mod
    panicman and Tifford[OP] like this.
  8. Sep 12, 2022 at 8:20 PM
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    2017 Tundra Platnium
    Too many mods to come
  9. Sep 13, 2022 at 7:23 PM
    mav7021234
    mav7021234 New Member
    just bought a pack thank you for the link. you think itll fix the gap issue im having in the corners?
  10. Sep 13, 2022 at 7:49 PM
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    Should help a little but mine also does that in the corners at times then goes back in just the way they corner is on that
  11. Sep 13, 2022 at 8:54 PM
    Mr Badwrench
    Mr Badwrench New Member
    Stuff's terribly expensive now. Unless you can get one for shipping cost, leave it off. That's my vote.
  12. Sep 13, 2022 at 9:55 PM
    Tundyfundy
    Bay Area, CA
    Magnetic Grey DC SR5 4x4 2016
    SUSPENSION: Bilstein 6112 coilover (1.9") w/ Powder Coated Springs and Spring Perch (TRD Red), JBA Upper Control Arms, Bilstein 5160's w/Billet Aluminium Reservoir Brackets, +2 Coachbuilder Shackles, Diff Drop Kit, Carrier Bearing Drop Kit, Brakeline Extensions, ABS Extension, Poly Bushings for Leafs, Coachbuilder Shims (2 Each Side), Coachbuilder Bumpstop Extensions, TRD Rear Sway Bar, TRD Front Sway Bar, Air Lift 5000 airbags w jounce bumpers, Daystar Airbag Cradles WHEELS AND TIRES: BF Goodrich KO2's 275/70/r18, BORA wheel spacers 1.25", TRD Wheel Caps,TRD Valve Stem Caps, Spare Tire Lock PERFORMANCE: Bullydog GT Tuner(Performance Tune), TRD Intake, TRD Dual Exhaust (with Modified Exhaust Hangers for Levelling Tail Pipe),TRD Brake Pads, TRD Oil Cap (US), TRD Radiator Cap, TRD Oil Filter, Optima Yellow Top Battery,GP Battery Distribution Blocks, StopTech Slotted Cryo Treated Rotors, Goodridge G-Stop Steel Braided Brake Line Kit PROTECTION: PNP Engineering Type 4 Rock Sliders (With Full Dimple Plate) ,ADD Stealth Fighter Rear Bumper w Red/Blk Shackles and Custom Stomp Pad, TRD Skid Plate with ReadyLift Spacer Kit, Victory 4x4 LCA Skid Plates, JOMAX ABS Sensor Armor, Rear Diff Breather Mod, ARK splash guards INTERIOR: Husky Liners X-Act (Front and Full Coverage Rear and Front Weather Beater Trans Hump), Interior LED Bulbs, WheelSkins Genuine Leather Steering Wheel Cover(EuroPerf), Clazzio Genuine Leather Seat Covers(BLK/DRK GRYwith custom stitching and embroidered headrests), Clazzio Seat Heaters (Front and Rear), Entune Startup Screen MOD, Entune Off Screen Mod, Tinted Windows with Windshield Visor, AJT Key Fobs,Eagle Claws Floor Mat Clips, Bodyglove Visor Organizer,Custom Door Cup Inserts, Glass Break Sensor,AJT Radio Knobs, Custom Dior Cup Inserts EXTERIOR: Full Debadge, LED Brake Light Bulbs, LED Rear Turns, LED Reverse, LED Plate Lights, LED Cargo Lights, LED Third Brake Lights, LED Front Marker Lights, LED Fog Light Bulbs, Lamin-X Fog Light Covers (Amber),2018 OEM LED Headlights, iHacker harness, VLED Universal Puddle Lights, VLED Interior Footwell Lighting (Front and Rear),VLED Extreme Amber Fornt Turns, NSV Knight Rider Light bar, Baja Designs Sport Squadron Pods in Rear Bumper (Driving/wide), Painted Red Tow-hooks, Bed Rail System, Blind Spot Mirrors, Hitch-safe, Tail-gate lock, EAG Raptor Grille, Custom Grille Badge,Full Vinyl Wrap (Matte Black/Matte Pine Green Mettalic), Charvonia Designs Tie Bed Tie-Downs, Bull Ring Bed Rail Anchors, Line-X, Tundra Bed Mat, Bakflip F1 Bed Cover SOUND: Noico 80Mil Sound Deadening and Noico 170 Mil Thermal Insulation (All 4 Doors, Roof, Floors, Rear Panel, Dash). Hertz Uno K170's Component Speakers (Front Doors with Upgraded Sail Panels), Hertz Uno K170 Coaxial Speakers (Rear Doors), JBL C1-075ct Tweeters (Total 4) in Side Dash and Center Speaker, JBL Stadium 5 Amp w/Remote Bass Adjustment Knob and Amp Rack, 12" Infinity Reference Subwoofer in Custom Enclosure w/ “TUNDRA” Logo, Fast Rings Foam Speaker Rings System(4 Doors), Fix 86 DSP
    I spoke to someone about this gap. They said you can reduce it almost to zero if you have someone push the bulge snug against the hood while the other person cinches down the 10mm bolt that attaches the bulge to the hood, then repeat on the other side.
    mav7021234[QUOTED] likes this.
  13. Sep 13, 2022 at 9:59 PM
    mav7021234
    im gonna try this in the morning, its probably gonna keep me up at night just thinking about it lmao. my damn ocd...
    Tundyfundy[QUOTED] likes this.
  14. Sep 13, 2022 at 10:00 PM
    Tundyfundy
    Bay Area, CA
    :rofl: I tried it and it worked for the most part. Just remember nobody sees it besides you haha
    HulkSmurf14, 1lowlife and mav7021234 like this.
  15. Sep 14, 2022 at 4:24 AM
    Bradleybb
    Bradleybb New Member
    Georgia
    2021 CM TRD OR
    Transmission cooler TRD REAR SWAY RCI front skid
    Tighten the 10mm bolt fixed the gap on mine ,
    mav7021234 likes this.
  16. Sep 17, 2022 at 7:42 PM
    Tifford
    Central New York
    reywcms[QUOTED] likes this.
  17. Sep 17, 2022 at 7:43 PM
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    No worries!
  18. Sep 22, 2022 at 1:29 PM
    Tifford
    Central New York
    Got a new hood bulge off of Amazon for $105. It came with white clips which were loose. I had already ordered the green clips (thanks to Reywcms) put the green clips in and put on my truck. Looks much better now!!
    Rocko9999, reywcms and HulkSmurf14 like this.
  19. Sep 22, 2022 at 3:11 PM
    RNDABOUT
    RNDABOUT New Member
    17 Quicksand TRD Off-road
    I have lots of these I'll give to anyone, insomuch as they pay shipping. They do work. Mine hasn't popped since.
  20. Sep 22, 2022 at 5:23 PM
    Be careful tightening those bolts. Those mounting locations will snap off of the bulge.
    HulkSmurf14 likes this.
  21. Nov 18, 2022 at 3:30 PM
    RobertD
    Robert
    DFW, Texas
    Man, mine randomly came loose today out of nowhere. Will definitely be ordering a set of these.
    Thank you :hattip:
  22. Nov 22, 2022 at 10:48 AM
    RNDABOUT
    RNDABOUT New Member
    I have 30pieces available for free.
    RobertD[QUOTED] likes this.
  23. Nov 22, 2022 at 12:21 PM
    RobertD
    Robert
    DFW, Texas
    Appreciate it but my order from Amazon arrives tomorrow.
  24. Dec 14, 2022 at 9:23 AM
    Toney198
    Toney198 New Member
    2014 1794 4X4
    i just used these and they are night and day from the factory ones……
    reywcms[QUOTED] and RobertD like this.
