Oil leaking from main bell housing AGAIN!
Discussion in '2.5 Gen Tundras (2014-2021)' started by MatthewPTguy, Jun 30, 2016.
  1. Nov 5, 2020 at 12:59 PM
    #61
    MatthewPTguy
    MatthewPTguy [OP] Not a new member
    Eugene, Oregon
    2017 Tundra 5.7 DC TRD MGM
    Borla dual cat back exhaust system, K&N replacement air filter, Headlight Revolution 40" Stealth LED light bar, Headlight Revolution LED fog light replacement bulbs, Line X bed liner, de-badge
    If you decide to have it done, make sure the tech checks the depth of the “ pins” that aligns some plate on there. Sometimes they are not set deep enough at the factory and cause this leak. That was the case with mine.
  2. Nov 5, 2020 at 1:08 PM
    #62
    HulkSmurf14
    2014 Tundra Limited
    Tastefully enhanced...
    Thank you for the heads up! After reading through several of these posts, I suppose I never considered the dowel pins to be out of spec...that's simple mechanic-ing 101 I assumed...regardless, I'm having my Indy Shop taking a look and am scheduled to drop off in a couple weeks...I'll be sure to mention the dowel pins to them!
    What's your assumption on a potential cost if it is only a Rear Main Seal? Was my assumption accurate?
  3. Nov 5, 2020 at 4:04 PM
    #63
    Ruggybuggy
    Ruggybuggy Seasoned Veteran
    Dave
    NW ON, CANADA
    2016 Tundra OR
    It's not that they are not set in deep enough. Toyota got a bad batch of pins that were slightly too long and cause the rear main oil seal plate to not seal properly.
  4. Nov 5, 2020 at 6:10 PM
    #64
    Roborob70
    Roborob70 New Member
    Robert
    18 Toyota Tundra TRD
    Sounds like you bought a ford, You sure it says toyota on it?
    TTund16 likes this.
  5. Nov 6, 2020 at 7:37 AM
    #65
    Sumo91
    Sumo91 Busy with projects
    TN
    2014 MGM Tundra Platinum 4x4
    Nothing a cutting wheel can't take care of :thumbsup:
    HulkSmurf14 likes this.
  6. Nov 6, 2020 at 7:47 AM
    #66
    Ruggybuggy
    Dave
    NW ON, CANADA
    2016 Tundra OR
    Yes sir, you don't have to take very much off so bench grid a bit off. Toyota has rectified the issue and the replacements are correct.
    Sumo91[QUOTED] likes this.
  7. Nov 6, 2020 at 9:39 AM
    #67
    Sumo91
    TN
    Aren't there oil tubes on the back of the engine? Or are they coolant tubes? If they're for oil I could see them being a culprit as well IMG_3175.jpg
  8. Nov 6, 2020 at 10:15 AM
    #68
    Ruggybuggy
    Dave
    NW ON, CANADA
    2016 Tundra OR
    If your taking about the silver tubes they are for the air injection.
  9. Nov 6, 2020 at 10:17 AM
    #69
    Sumo91
    TN
    I didn't know that! Thanks for the clarification
  10. Nov 6, 2020 at 6:35 PM
    #70
    Mad Max
    Mad Max New Member
    Max
    2021 Tundra Limited
    Some of the weepage concern is overblown in my opinion. If there are no drips on driveway, I wouldn't touch it. It's a lip seal, not a double mechanical seal. Last thing I would want is to create a problem when they tear everything apart.
    MatthewPTguy[OP] likes this.
  11. Nov 6, 2020 at 6:46 PM
    #71
    Ruggybuggy
    Dave
    NW ON, CANADA
    2016 Tundra OR
    He has a 2014 and I can't recall what year the dowel pins were a problem but it was for only one year. It's possible that if the plate is leaking because of the dowel pins Toyota would cover the repair. I would definitely check with the dealer.
  12. Nov 6, 2020 at 6:57 PM
    #72
    HulkSmurf14
    2014 Tundra Limited
    Yeah, I haven't had a leak since owning my 2014...after a recent oil change, I started noticing drips in garage floor...crawled under to tighten something and noticed it was the fresh oil all over the bell housing underneath...shouldn't be cam towers as that was addressed early in its life and the exhaust shields are still shiny and clean...just started and was wiped down...I'll look again in a few days as it will be a week since it was discovered...if nothing is showing, great, if there is still weeping, boo...no matter what, it will be looked at and addressed as I use the truck daily for towing and getting to work...fingers are still crossed!
    Ruggybuggy likes this.
  13. Nov 7, 2020 at 8:17 AM
    #73
    MatthewPTguy
    Eugene, Oregon
    Mine was covered under warranty so I have no idea on cost. Sorry
    HulkSmurf14[QUOTED] likes this.
  14. Nov 7, 2020 at 8:20 AM
    #74
    MatthewPTguy
    Eugene, Oregon
    I struggled with that thought as well when I had my problem...
  15. Nov 7, 2020 at 8:49 AM
    #75
    Ruggybuggy
    Dave
    NW ON, CANADA
    2016 Tundra OR
    Repair involves removing the transmission. Labor time is about 5 hours and about 30min to reseal the plate and replace the rear main seal. Take the shop rate times 5.5 hours and some charges for shop supplies and taxes.
    Maybe you'll get lucky and Toyota will cover it because it's a dowel pin issue.
    :thumbsup:
  16. Nov 7, 2020 at 9:04 AM
    #76
    HulkSmurf14
    2014 Tundra Limited
    Thanks for the insight and expectations...I'll ask them if it's the case!
    Ruggybuggy[QUOTED] likes this.
  17. Nov 8, 2020 at 5:21 PM
    #77
    Vector W8
    Vector W8 Old guy with a lot of expensive habits.
    2015 Platinum Super White Crewmax 4X4
    FFV, TRD Supercharger, Bullydog FFV Tune, 2014 Fit Kit, TRD Dual Exhaust, Sequoia Front Sway Bar, TRD Rear Sway Bar, TRD Skid Plate, TRD Pro Grill, 040 White Mirror Covers, 040 White Door Handles, Ready Lift 3"/2", Anzo 3rd Brake Light, Winjet LED Tail Lights, LED Fog Lights, LED Rock Lights, Axle Vent Mod, SDHQ Hidden Winch Mount, 12,000lb Winch. Storm Trooper Shift Knob. BMF BATL Wheels.
    I had the same issue at 50 miles with my 2015. Took it back to my dealer, they dropped the trans and pulled the rear main seal out, there is a aluminum casting that the seal is in. This casting is located by dowels. It was found that the dowels were not fully seated in the engine block which caused the casting to cock and not sit flush against the block. They had to tap the dowels in to the block to the spec. This allowed the rear main seal to sit flat and eliminated the ware due to the offset. The leak was eliminated. I have not had any problems since.
  18. Nov 8, 2020 at 6:51 PM
    #78
    HulkSmurf14
    2014 Tundra Limited
    Noted and thank you all for the suggestions and your experiences with such! I look forward to forgetting ever happened!
  19. Jul 10, 2021 at 7:14 AM
    #79
    twilite
    twilite New Member
    eric
    2010 Toyota sequoia
    i have the same isssue with my 2010 toyota sequoia. had the rear main seal replaced and it kept leaking. then they said it was the oil pan gasket they replaced it and its still leaking. the repairs were not by toyota it was another mechanic shop but now im going to take it to toyota to get diagnostics done. ive waisted 1200.00 so far. hopefully toyota can get it fixed..
  20. Jul 10, 2021 at 7:51 AM
    #80
    Mad Max
    Mad Max New Member
    Max
    2021 Tundra Limited
    Whoever did the oil pan slop job should find a job they may take pride in, they sure don't take any on working on cars.
    LarryDangerfield likes this.
  21. Jul 10, 2021 at 9:00 AM
    #81
    Roborob70
    Robert
    Come on man, do you realize what you're asking for???? Nobody gives a rats ass anymore. These damn kids don't even want to show up for work anymore, let alone give a shit about their "job performance". I guess that you and I along with a few others are expecting too much...Rant over
  22. Jul 10, 2021 at 1:47 PM
    #82
    HulkSmurf14
    2014 Tundra Limited
    It's not the RMS or oil pan gasket...it's an o-ring from a recirc that can only be accessed when engine is out away from bell housing...it's a simple repair but will cost $3k so I'm just living with it until I need something serious on my blown engine...oil.is cheap and so are rags...it is annoying but not worth the repair yet...
  23. Feb 18, 2022 at 11:42 PM
    #83
    Bmw635
    Bmw635 New Member
    S. Cal
    Could you elaborate more on this O-ring from a recirc?
    2008 Sequoia has 230k miles and it’s been leaking small but pouring out oil in my last 1000 miles tow of 5000 lbs trailer. I had the rear main seal replace and still leak then reseal the rear seal housing and tap in the dowels but still leak a lot. The oil was forming droplets along bottom of subframe after 30 miles drive. I am stump on where else it could leaks so much. How do I look for the oil pan seal leak or pan cracks as some others have mentioned? Any other ideas?
  24. Aug 29, 2022 at 9:21 AM
    #84
    ding4907
    ding4907 New Member
    My 2010 sequoia is having the same leakage
    My 2010 sequoia 255k is having similar leakage. There is a few drops on the floor sometimes. I’m wondering how much it cost to get it repaired.
    A dumb question: is this the leakage from engine oil or transmission fluid? The transmission oil hasn’t been changed. I guess it needs to be changed with a high mileage. Thanks!
  25. Sep 8, 2022 at 6:47 PM
    #85
    Bmw635
    Bmw635 New Member
    S. Cal
    It's engine oil as the rear plate on the block that holds the rear main seal is not tight against the block. The shop ground the dowel shorter then use FIGP to reseal. All is good for last 5k miles.
