Cruzer's Re-Build for the Rubicon
Discussion in '2.5 Gen Builds (2014-2021)' started by Cruzer, Dec 8, 2020.
  1. Aug 29, 2022 at 8:41 AM
    #841
    Punisher29073
    Punisher29073 New Member
    White Knoll, SC
    2019 Tundra TRD Pro
    Clearance lights, Light bar in front bumper, Ditch lights, CB Radio, AGM Battery, SLEE Sliders,
    Glad to be of service! Thank you for Guinea pigging so much of this for all of us. Hope to run across yall on a trail one day.
    tundra_20, eccracer104 and Cruzer[OP] like this.
  2. Aug 30, 2022 at 12:05 PM
    #842
    Cruzer
    Cruzer [OP] Wheeling Full Size
    Cruz
    Sunnyvale, CA
    The Kanati Mudhog MT 39x12.50r17 tires that I won at the T2S raffle back in April is finally shipping! Still waiting for the wheels though. And I'm still waiting on the 40" Mickey Thompson Baja Pro XS tires that I ordered back in March.....baby steps.
    Will use these as my street tires.
  3. Sep 1, 2022 at 1:04 PM
    #843
    Cruzer
    Cruz
    Sunnyvale, CA
    Getting stuffy in here:
  4. Sep 1, 2022 at 1:08 PM
    #844
    SAGE63
    San Diego County
    Where does the food er...alchol...fit
    How many tires you got in there?
    Cruzer[QUOTED][OP] likes this.
  5. Sep 1, 2022 at 1:16 PM
    #845
    des2mtn
    On the Scenery, Looking at the Road
    2004 Black DC Limited 4x4
    Tonto cover
    I'm wondering how he sleeps because apparently his driver's seat is his bed.
  6. Sep 1, 2022 at 2:22 PM
    #846
    helidave
    helidave Hellacopter
    flagstaff
    2015 DC 4x4
    If you drink enough you can sleep pretty much anywhere.
  7. Sep 1, 2022 at 2:49 PM
    #847
    Trdwillie14
    Trdwillie14 New Member
    Billy
    2014 trd off road
    2.5 fox 2.5 ads triple bypass T/C uppers Nfab front bumper Westin rear Bajas Rci skids All pro sliders Icon rxt leafs Stt pros Method 701s 37 Mickey Thompson
    Does discount tires see you coming and tries to just close the roll up doors at this point
  8. Sep 7, 2022 at 11:25 AM
    #848
    Cruzer
    Cruz
    Sunnyvale, CA
    Sooooooo. I took apart my spare front diff, did a size comparison and test fit with the bearings and fits perfectly! :yes:
    The side by side comparison shows the Tundra intermediate shaft + collar + (broken) stub shaft. Will try to install it this weekend :)
    BOSSARU, n0rth, bulldog93 and 8 others like this.
  9. Sep 7, 2022 at 11:45 AM
    #849
    Mater
    Mater New Member
    SD
    2016 MGM Platinum
    This is intense; and awesome :popcorn:
    Are you going to look into a way to de-couple the CVs from the hubs so that they can rotate freely? Maybe reach out to warn and see if they’ll make you some custom manual hubs :thumbsup:
    eccracer104 likes this.
  10. Sep 7, 2022 at 12:42 PM
    #850
    Cruzer
    Cruz
    Sunnyvale, CA
    I just emailed this site to see if they'd make one. I doubt it though. I highly doubt ARB will do it either cuz there's just no demand for it.
    https://therammaninc.com/products/TOYOTA-LOCKING-HUBS-427
    Mater[QUOTED] likes this.
  11. Sep 7, 2022 at 12:57 PM
    #851
    Mater
    Mater New Member
    SD
    2016 MGM Platinum
    Only thing I can think of is reaching out to Joe Pie on YouTube and see if he’d be interested in making a set as his next project on his YouTube channel. The guys work is incredible and no doubt he could do it
  12. Sep 7, 2022 at 1:03 PM
    #852
    snivilous
    snivilous snivspeedshop.com
    SW UT
    300k+ Supercharged 2008
    That seems like a step backwards to go to manual hubs? What's the logic, remove the actuator in the diff (good) but now add two other failure points? And manual hubs seem notorious for sucking ass. I'd be amazed if you saw a 0.5mpg difference, I'd run that shaft and not change anything else and keep it bulletproof.
    BOSSARU, n0rth, Hbjeff and 4 others like this.
  13. Sep 7, 2022 at 1:06 PM
    #853
    Mater
    Mater New Member
    SD
    2016 MGM Platinum
    Are the clutches in the front diff (I assume they use clutches) designed to be run 24/7 like that or would they wear out faster? Guess there’s only one way to find out..
  14. Sep 7, 2022 at 1:09 PM
    #854
    Cruzer
    Cruz
    Sunnyvale, CA
    I like the vote of confidence :cool: Won't the tires wear out faster though?
    Mater likes this.
  15. Sep 7, 2022 at 1:17 PM
    #855
    snivilous
    SW UT
    The diff is constantly spinning in the stock form anyways. The only thing that the coupler that Cruzer is deleting does, is allow that stub portion to spin so that the driveshaft doesn't spin. The diff and spiders are still spinning because the opposite (non-disconnecting side) is always connected to the diff, just where the motion is going is now isolated because one side has a much lower inertia than the driveshaft.
    Why? They aren't connected anymore than they usually are. By removing the stock coupler, all you're doing now is making it so the front driveshaft is always spinning. It's disconnected from the tcase so it's not locked to the rear driveshaft so nothing will bind up. Maybe a poor comparison but it's the same way (some) UTVs and buggies are done, where everything is spinning in 2WD you just don't have the front end binding up with the tcase until you lock the tcase into 4WD. Handling (and by extension tire wear) are not any different in those situations than if the diff was completely removed.
    The only thing the stock setup really does is "saves" the u-joints in the front driveshaft and eliminates the energy needed to accelerate the front driveshaft.
  16. Sep 7, 2022 at 1:31 PM
    #856
    Cruzer
    Cruz
    Sunnyvale, CA
    I'll take your word for it. I always thought that when turning, the inside tire had to rotate slower than the outer tire, where in my case they will both rotate at the same rate.
    For some reason My Cousin Vinny popped into my head :rofl:
    https://www.youtube.com/watch?v=W7YoxrKa4f0
    ATV25 likes this.
  17. Sep 7, 2022 at 1:46 PM
    #857
    snivilous
    SW UT
    Well the first part of your thought process is correct :D Excuse if I insult your intelligence, but to get us on the same page: The driveshaft inputs torque and rpm to the front diff, which is then divided between the tires. You can have two tires spinning at the same rate, or one stopped and the other spinning twice as fast. That is the case with any open diff, regardless of 4wd. Where you see binding occur is because the input speed (driveshaft) of the front and rear diffs are different as you take a turn because the rear tires do not follow the lines of the front tires. And that there is the key difference between AWD and 4WD. In an AWD vehicle there is an open differential in the tcase (or whatever is outputting power from the transmission) and that open diff tcase (like a Sequoia, some 4Runners, etc) is what allows power to go to all four tires even when driving onroad and not bind up. In a turn, all four tires are spinning at their own unique speed. As you start locking up differentials, you start getting increasing levels of binding.
    So if you lock the tcase (ie make it a normal 4wd/2wd tcase like the Tundra has) you're now creating binding between the front and rear driveshafts. The tires connected to the diffs can spin independently, but the cumulative speed of the front end and the rear end wants to be different and is being forced to be the same---ie binding. Lock up the front and rear diff? Same thing to a more pronounced effect as you know. Now to get to the point I'm trying to make, is that if you install the land cruiser shaft and leave the hubs engaged, that is effectively like an AWD vehicle except that the front driveshaft has no power going to it! Thus no binding occurring. And actually to take that one step further, the people who have done AWD conversions (@Wynnded comes to mind) with a Sequoia tcase, they are running with the front diff in "4WD" all the time to get the AWD effect. The only difference is you (Cruzer) do not have an AWD tcase which allows differential speed between the front and rear driveshaft. So as long as you're in 2WD, the driveshafts and diffs are effectively like an AWD just with no power going to the front. Kick it into 4WD and now you will have your usual level of binding from 4WD.
    Does that make sense? Don't take my word for it, understand it or point out if I'm wrong :D
  18. Sep 7, 2022 at 2:12 PM
    #858
    Cruzer
    Cruz
    Sunnyvale, CA
    I totally understand about the TC and binding issues in 4wd. I think I'm just overthinking things cuz if the AWD conversions (and other AWD yotas) are not having any problems with tire wear, then neither should I. I think I'm in a good place now :D
    :hattip:
  19. Sep 7, 2022 at 2:35 PM
    #859
    Front_Range_Pro
    Front_Range_Pro EEF Brand Ambassador
    Vail, Colorado
    2022 Lunar Rock TRD Pro
    What a hideous truck!
    Naaah. I’m just playin’. Truck is badass! :burnrubber:
    Cruzer[OP] likes this.
  20. Sep 7, 2022 at 7:53 PM
    #860
    snivilous
    SW UT
    Any progress on the doubler?
  21. Sep 7, 2022 at 8:35 PM
    #861
    Cruzer
    Cruz
    Sunnyvale, CA
    Funny you ask. I was going to ask you earlier if you knew of anyone who’s had warranty issues with the Atlas TCs.
    Last week I was in contact with AA asking them if they could make a 4 speed version of their Pro Series TC cuz they only sell it on their website as a 2 speed. The pro series is supposed to use stronger gear sets that should be able to handle higher horsepower and heavier vehicles. They said yes. I was so close to pulling the trigger but the only thing that stopped me was them saying that they would not warranty it because they’ve never installed one in a Tundra and because they don’t make an adapter for it. I was like WTF? So I put it on hold.
    I stopped looking at the NP205 because I found out that the only gear set available is a 1.96:1 and if I got a doubler I would only max out at 93:1, which in my opinion sucks. The Atlas gives me the option of 143:1 or 182:1, which should allow me to really crawl.
    Installing just a doubler would add over 15” of length, which would push the OEM TC into the gas tank AND the input shaft on the OEM TC is only 22 splines, which doesn’t inspire much confidence and has a high probability of breaking or stripping.
    TexasTundra27 likes this.
  22. Sep 8, 2022 at 4:16 AM
    #862
    TexasTundra27
    TexasTundra27 Moby Dick
    Mark
    2011 Tundra CM 4x4 5.7
    Icon stage 3, Icon billet UCAs, 5.29s, ARB lockers F+R, Coachbuilder +2s and shims, Rago fab ditch light brackets and bed stiffeners, Rago Fabrication sliders, ARE camper, 17x9 XDs and 37/12.5/17 stt pros, DT long tubes, xpipe with dual magnaflows, Full skids, TrailToys front and rear bumpers
    As long as your diff is unlocked, the tires will still spin independently like your rear axle. @snivilous is correct, only difference will be your driveshaft spinning.
  23. Sep 8, 2022 at 7:56 AM
    #863
    snivilous
    SW UT
    The only warranty that I'm aware of for the atlas is a manufacturing warranty, ie it'll work and not spontaneously explode. I think you'll be hard pressed to get any real warranty (like RCV style) for a tcase. The one nice thing is you should be able to swap out individual parts if you do break something, so it's not like the whole unit needs to be replaced. I wouldn't get wrapped around the warranty, and focus on a product meeting your needs since your options are limited.
    I also would be surprised if you have issues, you don't have a lot of horsepower and in the world of full size crawlers you're probably average weight wise. I think any tcase you end up with will be substantially stronger than the OEM unit.
  24. Sep 9, 2022 at 5:18 PM
    #864
    Cruzer
    Cruz
    Sunnyvale, CA
    I'll pull the trigger next week.
    Next thing I have to worry about is explaining why I have triple sticks to the :ballchain:
    You think I can hide it in the center console under the tray? :rofl: I've heard that it could sometimes be difficult to shift the Atlas. Wondering if I shorten the sticks to fit in the console will I lose the leverage needed to shift?
  25. Sep 9, 2022 at 5:24 PM
    #865
    Cruzer
    Cruz
    Sunnyvale, CA
    :monocle: maybe I can cut the sticks, thread both ends, and then use a coupler to reattach them when needed :yes:
    snivilous and eccracer104 like this.
  26. Sep 9, 2022 at 5:30 PM
    #866
    eccracer104
    eccracer104 Dirty Paws Off-Road
    San Diego, CA
    2011 Tundra 5.7 4x4 CM
    Hahaha that would be excellent!
  27. Sep 9, 2022 at 5:37 PM
    #867
    snivilous
    SW UT
    Or mount the levers parallel with the floor so you just pull straight up, then you could make a panel that sits on them so it just looks shallow :D
  28. Sep 9, 2022 at 5:39 PM
    #868
    Hightide
    chadington von banks
    Abalama
    Magic School Bus
    Mount them on the steering column like a 3 on the tree.:rolleyes:
  29. Sep 9, 2022 at 7:54 PM
    #869
    Cruzer
    Cruz
    Sunnyvale, CA
    She might notice that one :rofl:
    Hightide[QUOTED] and eccracer104 like this.
  30. Sep 10, 2022 at 1:57 PM
    #870
    Cruzer
    Cruz
    Sunnyvale, CA
    So the SAS :p went in, for the most part, without a hitch. The diff seal that the shaft came with went in too easily, which could come out just as easily. Fortunately, I had an OEM seal laying around that I used instead. Just have to wait til tomorrow for the gaskets to fully cure before I can add gear oil and take a test drive.
