Newb installation thread- Pioneer DMH-WT8600NEX into a 2018 SR5 Entune Non-JBL
Discussion in 'Audio & Video' started by panicman, Dec 28, 2021.
  1. Sep 3, 2022 at 11:22 AM
    #241
    texasrho83
    texasrho83 Old Member
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    Looks like the mics the field reporters wear :rofl:
  2. Sep 3, 2022 at 11:39 AM
    #242
    e30cabrio
    West Valley, Phoenix, Az.
    Boosted 2013 Sequoia TRD FAUX
    I bet associating it with allllll my accounts will be the hardest part of the set up. (plan on doing it in my livingroom on my TV)
    lol
    Thanks again for the great idea!
    texasrho83 likes this.
  3. Sep 3, 2022 at 11:49 AM
    #243
    texasrho83
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    Nope. Sign in with your existing account info and it will plop all your apps on the home screen for you
    e30cabrio[QUOTED] likes this.
  4. Sep 3, 2022 at 12:05 PM
    #244
    e30cabrio
    I did not remember it had a ROKU account, that's 2x in 1 day you made my day!
    :D
  5. Sep 3, 2022 at 12:08 PM
    #245
    texasrho83
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    :hattip:
  6. Sep 3, 2022 at 2:51 PM
    #246
    texasrho83
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    The tailgate handle/camera came in
  7. Sep 3, 2022 at 3:04 PM
    #247
    Get on it lol. I called the shop but he was closing early today and will be back on Tuesday. I should have went earlier but had a headache lol.
  8. Sep 3, 2022 at 3:25 PM
    #248
    texasrho83
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    The camera will bolt in but the connections are different. The 2.5 gen is 6 pin and the 2nd gen is 4.
  9. Sep 3, 2022 at 10:10 PM
    #249
    RainMan_PNW
    Casey
    Clark County, WA
    2021 Lunar Rock TRD Pro CM
    That’s not a 2nd Gen connector - that’s an aftermarket connector. You’ll have to get an adapter, and no idea where
  10. Sep 3, 2022 at 10:13 PM
    #250
    texasrho83
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    Yeah I've been researching. I need a pin diagram for my 2016 then maybe figure out what the aftermarket harness wires do to possibly source a corresponding terminal or splice into the stock terminal/harness
  11. Sep 3, 2022 at 10:29 PM
    #251
    RainMan_PNW
    Casey
    Clark County, WA
    I happen to know where you can find that diagram…
    ;):thumbsup:
  12. Sep 4, 2022 at 6:12 AM
    #252
    texasrho83
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    I looked thru the diagrams in the diagrams thread but there's 15 fajillion and I got tired :rofl:
  13. Sep 4, 2022 at 8:24 AM
    #253
    RainMan_PNW
    Casey
    Clark County, WA
    I’ll hunt it down and post it here for you
  14. Sep 4, 2022 at 8:36 AM
    #254
    e30cabrio
  15. Sep 4, 2022 at 8:39 AM
    #255
    texasrho83
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
  16. Sep 4, 2022 at 8:41 AM
    #256
    RainMan_PNW
    Casey
    Clark County, WA
    This is the camera itself. XR1 is the connector at the tailgate and X1 is the connector on the camera.
    1lowlife likes this.
  17. Sep 4, 2022 at 8:46 AM
    #257
    texasrho83
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    Thanks man. The 6 pin terminal. Any pin labeling for that?
  18. Sep 4, 2022 at 8:50 AM
    #258
    RainMan_PNW
    Casey
    Clark County, WA
  19. Sep 4, 2022 at 8:53 AM
    #259
    RainMan_PNW
    Casey
    Clark County, WA
    The numbers listed on the diagram in the blue box for the camera are the terminals at that connector.
    1= CURT (must be a second ground, because it splices to pin 5)
    2= CV- (video negative)
    3= CV+ (video positive)
    4= (empty)
    5= CGND (ground)
    6= CB+ (power)
  20. Sep 4, 2022 at 9:05 AM
    #260
    texasrho83
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    Ah so it's basically a 5 pin. The aftermarket terminal is 4 pin. I bet I can mess around and get the corresponding wires spliced where they need to go. Thanks Casey
  21. Sep 4, 2022 at 9:06 AM
    #261
    texasrho83
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    I'm thinking I could cut the 4 pin male terminal off then splice into the OEM wiring
  22. Sep 4, 2022 at 9:08 AM
    #262
    TRDFerguson
    Jake
    Southeast Greater Basin, AZ
    2018 MGM CrüeMax
    I'm guessing Pin 1 is the guidelines... Aftermarket cameras have a loop that I believe is a grounded line that you cut to remove them. I might de-pin that one and see what happens, since I've been looking at this for a while.
  23. Sep 4, 2022 at 9:11 AM
    #263
    texasrho83
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    You're right. Came across that in my hours of searching. Do you not want the lines?
  24. Sep 4, 2022 at 9:14 AM
    #264
    TRDFerguson
    Jake
    2018 MGM CrüeMax
    My Kenwood has adjustable lines, so I was wanting to use those and dial things in a little more than the factory ones. It’s more of a curiosity thing than something that I need to do
    1lowlife and texasrho83[QUOTED] like this.
  25. Sep 4, 2022 at 9:49 AM
    #265
    1lowlife
    1lowlife New Member
    DADA
    THE GREAT STATE OF TEXAS
    2014 MGM DC SR5
    I think most decent after-market HUs parking lines can be turned off.
    Some of them have a predictive(?) like my wife's Cadillac that move with the steering wheel.
    Not sure if there is any way to cancel the OEM parking lines..
    As @TRDFerguson stated, my Kenwood also has adjustable lines.
    I like them better than the OEM, but I haven't found a way to turn them off.
    My camera works ok, I wouldn't mind a clearer picture though.
    I had issues with it not working correctly a couple of years ago and it seemed to fix itself..
    It would sometimes give me a blank screen but still had the text warming on it.
    5for5eed_05322b5b2ba635257ea0a6e392184abe9182da10.jpgtxs7udm7_40afa80ca2b85ac884683e15112f18e4b1d0e34b.jpg
  26. Sep 4, 2022 at 10:15 AM
    #266
    e30cabrio
    My 9906 has the lines removable in one of the Maestro menus I think.
  27. Sep 4, 2022 at 10:19 AM
    #267
    TRDFerguson
    Jake
    2018 MGM CrüeMax
    You’re saying the Maestro can disable the OEM lines? I haven’t seen that on my 9707s but I’ll go poke around some more.
  28. Sep 4, 2022 at 10:27 AM
    #268
    e30cabrio
  29. Sep 4, 2022 at 10:40 AM
    #269
    TRDFerguson
    Jake
    2018 MGM CrüeMax
    Found the setting (that’s god-awful where it’s buried…) but it didn’t change the OEM guide lines. I’m guessing it’s hard-set in the camera like aftermarket ones, with the CURT wire controlling it. Going to mess with it later if I have time.
  30. Sep 4, 2022 at 11:07 AM
    #270
    e30cabrio
    Agreed, Maestro's menus defy common sense. Every time I flash my unit I have to muddle to rescan the PIDS to get my transmission temp gauge back.
    Not looking forward to doing it after the replacement to the 1057.
    Sorry it didn't help.
