DIY: Rear Differential Breather Mod
Discussion in '2nd Gen Tundras (2007-2013)' started by csuviper, May 25, 2016.
  1. Jun 21, 2021 at 3:10 PM
    #241
    BeachTundra19
    BeachTundra19 New Member
    Zak
    2019 Tundra Platinum "Silver Sky Metallic"
    None Yet
  2. Jun 26, 2021 at 8:31 PM
    #242
    CTundraForMe
    CTundraForMe New Member
  3. Jul 12, 2021 at 9:07 PM
    #243
    Ltizzle
    Ltizzle New Member
  4. Jul 12, 2021 at 9:37 PM
    #244
    JeffMac
    JeffMac 2 Words, 1 Finger
    Jeff
    South Florida
    2015 Black Tundra OVTUNE
    Suspension: Bilstein 6150 Front Max Setting CB Shim 2x Driver 1x Passenger Bilstein 5160 Rear CB +3 Shackles Firestone Airbags w/ Daystar Craddles Engine: OVTUNE - 87 w/ Torque Modifier SABM w/ K&N Filter TB Coolant Bypass Fumoto Drain Plug Wheels/Tires: ProComp Bandidos 0mm Offset Nitto Exo Grappler AWT 285/70/18 Exterior: TRD Pro Grille Spyder Headlights/Taillights Ecoological Bumpershellz LED everything Tinted windows Bakflip MX4 Tonneau Cover K-Source Tow Mirrors Interior: Pioneer AVH-W4500NEX Radio 2x 10” Pioneer Subwoofers 1200W Pioneer Mono Amp 2000W Pioneer 4 Channel Amp
    That has a plastic hose and wont withstand elements or off-roading for long. Transmission and front diff breathers are stock in the engine bay.
  5. Jul 14, 2021 at 9:01 AM
    #245
    Army_of_One
    Army_of_One New Member
    2019 MGM 4X4 CrewMax, 2005 Cement 4x4 Double Cab
    OEM+
    I did both my 3rd and 1st gen. I used the Toyota Union, 10ft of trans cooler hose, and an oil/water separator from Harbor Freight. It went smoothly and is pretty straight forward. The kits I see with less than 10ft of hose, I would be nervous about it making it to the tail light.
    Krewcial and ToyoD like this.
  6. Jul 14, 2021 at 11:23 AM
    #246
    Bikeric
    Bikeric New Member
    Eric
    2007 DC 5.7
    Blown Engine.....
    Mater[QUOTED] likes this.
  7. Jul 15, 2021 at 6:30 PM
    #247
    ejes
    ejes New Member
    2020 1794 Tundra / 2023 4Runner TRD PRO
  8. Sep 9, 2021 at 4:51 PM
    #248
    raymond_hb
    raymond_hb New Member
    Oakland, CA
    07 Tundra Limited 2WD
    I have the stock breather on my tundra I read on the first page someone had checked it my question is, do I just remove the breather and do anything inside that hole or just remove it and let it be? I’m just asking in case I need to check mine considering that I don’t think the previous owner checked it or myself. Thanks in advance everyone
  9. Sep 10, 2021 at 6:10 PM
    #249
    Army_of_One
    OEM+
    You just need to make sure it can move. If it doesn't twist or move up and down slightly, it is clogged.
    raymond_hb[QUOTED] likes this.
  10. Sep 30, 2021 at 4:54 PM
    #250
    Spyker
    Spyker I’m a dude,playin a dude,disguised as another dude
    Removed because my question was answered on page 7
  11. Sep 30, 2021 at 8:07 PM
    #251
    Spyker
    The only question I have, if the engine bay has the 2 vents going into it from the front diff and transfer case, why can’t we just run an OEM Toyota front breather on the rear.
    Or does the rear for some reason mandate the OEM one way valve?
  12. Sep 30, 2021 at 8:26 PM
    #252
    NueveTundra
    NueveTundra Mod list in Bio
    Planet Earth
    07, Black Tundra SR5 CrewMax
    Exterior: Toytec ultimate 3" lift level, Total Chaos Uniball UCA's, Total Chaos Cam Tab Gusset kit, AcanII smoked headlights, AcanII smoke Tail lights (2.5 gen style), DV8 front winch bumper , Badlands 12k winch with Apex Synthetic, White AUTMATCH Shackles 3/4" D Ring Shackle, Apex Winch shackle, Trail Ridge mirrors ,Icon Rebound Pro 17"x8.5" +25, Cooper Discovery STT Pro 285/70R17, PowerStop drilled n slotted rotors W/Carbon pads, Rigid flood flush mounts rear bumper , WeatherTec rain guards , OEM black side badges , Rigid Amber Radiance Pods. Energy Suspension Red Rack and Pinion Bushings, EAG front mesh Grille, RCI HighLift bed mounts. Rough Country DS2 Steps, A.R.E OverLand Canopy with Ascend basket, Stickers: ToyTec lifts windshield banner, Red Strange Music window sticker(back cab), White Strange Music sticker(back canopy), White Rigid sticker x2 (canopy sides), white Official BigFoot Research Team (Back Canopy) Interior: Alpine double din touch iLX-650 , JL C5-653's (front) JL C1-650x (rear) , JL JX400 4 channel amp , JL JX500 mono amp , 2 JL 12" subs , WeatherTec floor mats, Kenwood F/R Dash Cams, Black steering wheel emblem overlay, Tekonsha P3 Brake controller, ToyTec "Fresh" Scent coilover air freshener, Under the Hood: Koyo all aluminum radiator, Mishimoto red silicon hoses , XS Power 3000 amp battery , LAlectric 300 amp Alternator , K&N replacement filter. Online LED store accessories Fuse/relay box. (Identified) Dirty Deeds 8" Cat back exhaust with DD resonator delete/axel over converted into dump. Coming soon:
    You guys are making me want to go look at mine , the original owner did this mod , but I have no idea how they did it. Will have to inspect and fix if need be.
  13. Oct 1, 2021 at 3:53 AM
    #253
    Spyker
    I like the idea of the mod, and it makes sense to me, the only thing I’m questioning is, should I run the OEM 2 way breather in the rear (same part as the fronts), or run the 1 way valve that was already in the rear.
    Guess I’m wondering why they use a 2 way breather for the front, and a 1 way for the rear?
  14. Oct 1, 2021 at 3:59 AM
    #254
    Army_of_One
    OEM+
    They used a 2 way up front because the breather has been lifted up out of the way. If they did a 2 way in the rear it would suck in water as soon as it got submerged.
  15. Oct 1, 2021 at 4:46 AM
    #255
    Spyker
    Okay, that makes sense, good point, so if I do this mod and lift it up out of the way, installing a 2 way breather, same as the front should be all I need then?
    I saw guys installing filters and what not, but it made me wonder because the fronts don’t have filters, so are we really worried about a little dirty air getting in there (and I’m sure it would be very very little, if any dirty air)?
    When I removed my OEM rear valve it let in a lot of air, so it makes me wonder if putting in that two way valve would put less stress on the seals so that the diff pressure will remain equalized with the ambient pressure.
  16. Oct 1, 2021 at 4:50 AM
    #256
    Spyker
    And yes, I have read all 10 pages :thumbsup:
  17. Oct 1, 2021 at 5:30 AM
    #257
    Spyker
    Yeah that seems to be the overall consensus. Use of a Filter in order to allow for equalization of the differential pressure.
  18. Oct 1, 2021 at 8:54 AM
    #258
    Army_of_One
    OEM+
    A two way breather will equalize the diff pressure as well. I did a filter because of all dust inside of the brake light cavity. It's right behind/above the rear tire and i drive through dust alot.
  19. Oct 1, 2021 at 2:50 PM
    #259
    Spyker
    What kind of filter did you use? A ‘fuel’ filter, or an actual air filter meant to catch large dust?
  20. Oct 1, 2021 at 3:41 PM
    #260
    Army_of_One
    OEM+
    I used a water separator for air compressor line. It's post #273, up a couple of posts.
    Gunship Guy likes this.
  21. Feb 6, 2022 at 8:13 AM
    #261
    PomDad
    PomDad we having snacks?
    Conrad
    Atlanta
    2021 Cement Limited
    Thinking of doing this soon - any chance you remember the bolt size for this?
    1794TX[QUOTED] likes this.
  22. Feb 6, 2022 at 8:30 AM
    #262
    1794TX
    Steven
    N.TX
    '20 1794
    Apologies, I don't. Knowing me, I found the hose clamp and bolt floating around in a box full of junk and spare parts in the garage. IIRC, that little flange provides access to both sides, so if you don't have the exact size that fits, something smaller with a nut on it should work fine. Good luck.
    PomDad[QUOTED] likes this.
  23. Feb 6, 2022 at 8:35 AM
    #263
    texasrho83
    texasrho83 Old Member
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    I did this a while back but didn't run it up to behind the taillight. I also didn't put a breather cap on the hose. Didn't figure it was necessary.
  24. Feb 6, 2022 at 8:52 AM
    #264
    1794TX
    Steven
    N.TX
    '20 1794
    Probably not strictly necessary, but some kind of filter is cheap insurance to help keep debris out of your diff. Especially if you didn't run the breather extension to a place that gets less dust or dirt, like behind the tail light; and also if you don't change your diff fluid more than every 5 or 6 years.
  25. Feb 6, 2022 at 8:59 AM
    #265
    texasrho83
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    Yeah I plan to get some longer hose and run it to the taillight
  26. Aug 5, 2022 at 5:20 PM
    #266
    drew.c.114
    drew.c.114 New Member
    Andrew
    Gilbert, AZ
    2021 Trail Edition
    About how much slack did y’all leave for the fuel line to accommodate for the rear axel’s travel?
  27. Aug 5, 2022 at 5:54 PM
    #267
    COTundie
    COTundie Whoa Black Betty
    Trey
    Black 5.7 DC TRD 4x4
    Pretty things
    I just mimicked what the brake line was doing and haven't had any issue.
    Actually had some pretty good flex going on earlier today and all is well!
    drew.c.114 likes this.
  28. Aug 5, 2022 at 5:56 PM
    #268
    drew.c.114
    Andrew
    Gilbert, AZ
    2021 Trail Edition
    Smart… thanks man!
  29. Aug 5, 2022 at 5:57 PM
    #269
    COTundie
    Trey
    Pretty things
    No problem. It woulda made sense once you were under there.
    drew.c.114[QUOTED] likes this.
  30. Sep 3, 2022 at 4:57 PM
    #270
    ToyoD
    ToyoD New Member
    Drew
    2021 SR5 DC
    Build page link in signature
    I did mine today and FYI it’s a M6x1 (standard thread pitch). A 16mm length one fit perfectly for me with the hose clamp, regular, and lock washer with just a little thread sticking out of the top when tight. Great spot to put a thread, thanks Toyota
    851BCF95-43B7-4AE1-98FD-D6A3FD93D65B.jpg CFCCBA70-5CA3-4CB0-804A-E9B2555686CF.jpg C424D72F-6876-4A51-B2B6-FD054A74C086.jpg 84C7B5AF-BB28-4FC9-A380-3777B9BE20F7.jpg
    And thanks to everyone on this thread for their input. This community is awesome at sharing info!
