  1. Aug 27, 2022 at 4:27 PM
    APalmTree
    APalmTree Sometimes helpful
    Brandon
    SW Washington
    A few... Definitely more than 2
    Not very hard at all really. I dropped the spare for some space underneath. Picked roughly where I thought it would work and traced the bracket that I pulled off. The purple is about where there is thin sheet metal behind the plastic. I started with a 2 in hole saw for the 7-pin half of the plug (which fits perfectly) and then used a combination of a Dremel and a grinder to remove the plastic and the last little corner of metal above the hole saw cut out. I got lucky and happened to place it perfectly to not have to grind any more of the metal above for the 4-pin half of the plugs. Then I just shoved it in there. I have heard from others that it is very loose only being clipped into the plastic but mine seems to be quite firmly in place with just the clip that secured it to the factory bracket and I would really have to yank on the plug to pull it out without disengaging the clip.
    Chrslefty, is348cm, Ohannon7 and 7 others like this.
  2. Aug 27, 2022 at 4:45 PM
    Red Sonja
    Red Sonja Mock Warrior
    Ben
    2007 Salsa Tundra LTD
    Bilstein 5100’s at top setting Eibach rears with Toytec 1.5” lift shackles 285/60 R20 Firestone Destination X/T 1.25” Spidertrax Spacers Custom 18” Magnaflow Exhaust(side middle exit) Vland LED headlights
    Thanks! Mine rusted off a while ago. I need a new plug set up like yours.
    APalmTree[QUOTED] likes this.
  3. Aug 27, 2022 at 11:32 PM
    FilchedToyoResto
    FilchedToyoResto New Member
    Ayy I'm working on the trailer plugs this weekend the previous owner for some reason decided to splice the wires?! It may need a new harness there seems to be corrosion running up the wire.
    D4x4TRD and WVI like this.
  4. Aug 28, 2022 at 6:41 AM
    PayItOff428
    PayItOff428 New Member
    Jake
    The United State of Texas
    2012 SR5 Double Cab 4X4
    Ordered New tires (35x12.5x17) and wheels (17x8.5 - 0 offset). They should be here next week. Will post a photo when they get installed. I looked and looked for a black wheel I liked but at the end of the day something kept telling me black wheels are getting tired so I went with my gut and purchased a machined looking wheel. Fingers crossed it will have that old school look which is what I am after.
  5. Aug 28, 2022 at 8:03 AM
    BlueCrushSC16
    BlueCrushSC16 New Member
    Charleston, SC
  6. Aug 28, 2022 at 1:05 PM
    SanDiegoSlovak
    SanDiegoSlovak Junior Woodchuck
    San Diego, CA
    2008 Double Cab SR5 4x4
    Eibach Pro Truck Coilover Stage 2, RCI skids (engine, transmission, rear diff), Demello Hybrid Sliders, Morimoto XB headlights
    Which part number did you use for the 7 pin / 4 pin component? Or was that your original one and you had only bent the previous bracket?
    I've been meaning to do something like this for a while. Only got as far as removing my busted bracket... :(
  7. Aug 28, 2022 at 3:38 PM
    APalmTree
    Brandon
    SW Washington
    That is the original plug that was on my truck. I bent the bracket that it sat in under the bumper on a rock or something while playing around offroad. That was a few months ago and I just got around to moving it up into the bumper.
  8. Aug 28, 2022 at 8:02 PM
    Patmaui
    Patmaui New Member
    Pat
    2012 Tundra 4.6L 4x4 work package
    285 65 18 RG 18 x 9 fuel vectors Icon stage 1 Outlaw exhaust S&B intake 10" Head unit
    Finally installed the icons that just got back from being serviced under warranty for a leak, along with some coachbuilder tie rod ends and total chaos uca's. Stop tempting me to upgrade other stuff now guys, just stahp.20220821_131448.jpg 20220828_144542.jpg 20220828_144530.jpg
  9. Aug 29, 2022 at 8:59 AM
    aelarson
    aelarson New Member
    AZ
    2011 SR5 Tundra (Silver Sky Metallic)
    Yikes...that looks like a rat nest. Very good that you're tackling that!
    WVI likes this.
  10. Aug 29, 2022 at 12:08 PM
    Windsor
    Homeless in Oregon
    2008 Tundra Crewmax 5.7L
    Some.
    Living up in the mountains, I deal with mice in my engine bay every now and then. I was using cayenne pepper on the ground around the tires with pretty good success. However, Saturday I found one had started to build a nest on top of my cabin filter. So, if I can't deter them from entering from the ground, I'll make it too unpleasant for them to enter.
    I took a dried out tree air freshener and soaked some peppermint oil into it. Then, I put it on top of the filter. To say the smell is strong would be an understatement. When I first open the doors I start the truck and turn the fan on to push the buildup of smell out.
    When driving with the fan on, it isn't too bad, but still is strong. Just crack the windows and I'm happy, it smells (and I can taste it in the air) like a brand new just opened pack of gum.
    I'll give it a couple days to see if it works. Then, I'll refresh the oil in the air freshener when I notice it getting weak. I keep forgetting to grab a piece of mesh screen to put over the hole.
    WVI, joseph_womack and Mountun Goat like this.
  11. Aug 29, 2022 at 12:20 PM
    Jeff_1974
    Jeff_1974 Cookeville, TN
    Jeff
    Tennessee
    2010 supercharged rock warrior dc
    Supercharger Bama Exhaust Bully dog tune Bed extender Roll up Bed cover Bed carpet 18” Method wheels Falken wildpeak 285 75 18 P & P rock sliders Weather tech floor mats Sdhq pre runner bumper Warn 9.5 xp synthetic winch Icon 2.5” lift Iron cross rear bumper RCI al skids Trd brake pads Trd front sway bar Deaver u748 leaf springs Marathon seat covers
    :mad: Rodents
    my pitbulls have stopped bushy tailed tree rats from building nests in the engine bay.
  12. Aug 29, 2022 at 6:54 PM
    ACDC2ZZTop
    ACDC2ZZTop Rock n Roll!
    Travis
    Oregon
    2012 MGM Tundra double cab 5.7L V8
    All cosmetic so far see my posts in 2nd gen Black out chrome in progress….
    Pulled vinyl from B pillars. Much better!
    D4x4TRD, WVI, Red Sonja and 6 others like this.
  13. Aug 29, 2022 at 7:14 PM
    Filthyphil
    Filthyphil Lions Not Sheep
    Phil
    2000 Toyota Tundra TRD 4.7
    Any issues how’s the journey been?
  14. Aug 30, 2022 at 12:14 AM
    French Avocado
    Utah / Wyo
    Steady and constant performer. Only routine maintenance and service. No real issues except failure of the clear coat. It convinced me to get the 2020. I have had my best success with Toyota - far better than any other brand (the others include GMC, Ford, Jeep).
  15. Aug 30, 2022 at 3:26 AM
    Jjclamdips
    Jjclamdips New Member
    Wichita, Ks
    2000 Access Cab
    Excellent look!
  16. Aug 30, 2022 at 12:11 PM
    PayItOff428
    Jake
    Little update, The wheels came in today and I just can’t do it! I like the finish but the face profile is convex! WTF! Flat or Concave is a minimum expectation for a good looking wheel. Really disappointed but Discount Tire is amazing so they are sending them back. I’m going with a different wheel instead.
  17. Aug 30, 2022 at 1:50 PM
    wv00097
    wv00097 New Member
    Wes
    AZ > GA
    2011 SR5 TRD OR
    BDS 7 w/ Fox 2.5 OME Dakar leaf pack CB +2 shackles 18x9 Method 308 +18mm 37x12.5 Toyo AT3 TRD intake/exhaust Infinity Kappa w/ Pioneer HU
    Anyone with steering rack experience? Can inner seals or something inside the rack cause a creaking noise? Can't find anything on this in any of the forums. Audible groaning when turning, under load (no noise when on jacks), especially when it's dry out (goes away with rain). I've almost pinpointed it to the rack, you can feel it, physically hand on the rack under the truck. Can't find anything else. New bushings everywhere, everything is greased. Been chasing this for a year now.
    Silverghost2 likes this.
  18. Aug 30, 2022 at 2:01 PM
    PayItOff428
    Jake
    Likely your tie-rods are shot and dry. I bet the rubber boot is missing too
  19. Aug 30, 2022 at 3:42 PM
    Kiddnapped Tundra
    Kiddnapped Tundra New Member
    Grand Island, NY
    2010 Tundra DC
  20. Aug 30, 2022 at 3:44 PM
    PayItOff428
    Jake
    Ha ha, At first I thought it was a shed in the yard behind your truck and that you parked perfectly in front of it and then I realized it’s not. It’s an actual cap! Your not using it to Kidnap are you?
    Sean492 likes this.
  21. Aug 30, 2022 at 3:54 PM
    Kiddnapped Tundra
    Grand Island, NY
    2010 Tundra DC
    HAHAHA ! ! No, I want to try something other than sleeping on the ground when camping. LOL
    It's used, so cheap.
    Sean492, Mountun Goat and NueveTundra like this.
  22. Aug 30, 2022 at 4:14 PM
    PayItOff428
    Jake
    I hear you on that. I just bought one used for $300 in not so good of shape but it keeps it dry back there.
  23. Aug 30, 2022 at 5:38 PM
    wv00097
    wv00097 New Member
    Wes
    AZ > GA
    2011 SR5 TRD OR
    Nope. Tie rods and boots are all fine. If you put your hand on the steering rack, you can feel it internally.
  24. Aug 30, 2022 at 6:14 PM
    PayItOff428
    Jake
    If it stops when it’s raining then it has to be something that is exposed and not internal. Get a spray bottle with water and wet things down during your investigation for a process of elimination
  25. Aug 31, 2022 at 4:22 AM
    ftmyerstundra
    ftmyerstundra New Member
    Gary
    2007 Tundra Crew Limited
    absolutely none
    I actually really like those. DO you have a link to them?
    Sean492 likes this.
  26. Aug 31, 2022 at 4:31 AM
    PayItOff428
    Jake
  27. Aug 31, 2022 at 4:09 PM
    wv00097
    wv00097 New Member
    Wes
    AZ > GA
    2011 SR5 TRD OR
    I've sprayed everything. Everything external, that's why I'm thinking it's something inside the rack, but I've never dissected one. Boots have all been fine and both tie rods appear fine, grease and all. Just scratching my head. Sounds like something out of a Frankenstein movie, embarrassing as hell
    joseph_womack likes this.
  28. Sep 1, 2022 at 7:04 AM
    joseph_womack
    joseph_womack @ 4x4bound
    Joe
    Louisiana
    2007 RCLB, 4WD, 4.7L V8
    My rack also makes a whining noise when turning, its not crazy loud, but I can hear it if everything is quiet. I hear solid front axles creaking all the time due to the stabilizer shocks for their steering, honestly I'm not even worried about it lol
    what size tires you running? I've got 35"
    wv00097[QUOTED] likes this.
  29. Sep 1, 2022 at 9:15 AM
    flyeaglesfly94
    flyeaglesfly94 2013 Tundra Platinum
    Atlanta GA, USA (ATL)
    Eibach Pro Truck Lift - Stage 2
    Did you paint your front bumper? or wrap?
  30. Sep 1, 2022 at 5:45 PM
    Blang805
    Blang805 New Member
    Central Coast California
    2010 CrewMax Platinum 4x4
    Build in Signature
    I ordered up some seat jackets for both the driver and passenger to see what they hype is about.
