1st gen tundra 3rd member compatability?
Discussion in '1st Gen Tundras (2000-2006)' started by Unjoymyself, Aug 26, 2022.
  1. Aug 26, 2022 at 8:41 AM
    Unjoymyself
    Unjoymyself [OP] New Member
    A bit confused. I have an 03 tundra access cab, 4x4, ABS, LSD, 3.91 ratio. The diff is bad. Want swap 3rd members. I read a thread started by bmwahba. Want to know the consensus an compatibility? Can you all help me out?
  2. Aug 26, 2022 at 7:00 PM
    NickB_01TRD
    KY
    01 Tundra V8 4X4 AC SR5 TRD
    I'm no expert in this but you just need another 3.91 ratio diff. Could be LSD or not depending on how desperate you are to keep it. The whole axle itself differs between double cabs and others but the 3rd member is the same as far as I know.
  3. Aug 26, 2022 at 9:30 PM
    assassin10000
    assassin10000 New Member
    Andrew
    Northern CA
    '05 SR5 AC 2wd
    3rd is the same, with a caveat. The pinion flange differs between 2wd/4wd and/or RC/AC/DC.
    Simple solution is to just swap your pinion flange if different (and do the pinion seal while your there).
    Unjoymyself[OP] likes this.
  4. Aug 27, 2022 at 11:47 AM
    Unjoymyself
    Thanks for info..all good thoughts.
