  1. Aug 17, 2022 at 1:11 AM
    BoysandHisToys
    BoysandHisToys New Member
    Central Virginia
    2013 Tundra Crewmax Limited
    Hope to be in the Gatlinburg area the December for a long weekend to see the Christmas lights!
    joseph_womack and Ohannon7 like this.
  2. Aug 17, 2022 at 6:14 PM
    WVI
    WVI New Member
    @008 Tundra Limited
    Leveled up the truck in order to do the transmission service tomorrow:Levedout.jpg
    Here's the factory cooler on the 08:FrontofTC.jpg
    Here are the connections in the engine compartment:Back of TC.jpg
    Here is how i intend to determine flow in the AM:TCflowTest.jpg
  3. Aug 17, 2022 at 6:46 PM
    Retroboy1989
    Northern Utah
    Wow, that is a very different design. From the later trucks.
    WVI[QUOTED] likes this.
  4. Aug 17, 2022 at 6:54 PM
    Kalyan123
    Kalyan123 New Member
    Kalyan
    2007 Tundra Sr5 TRD off road
    Hey where did you bought those red things from ? Behind the steering wheel.. the speedometer and odometer ones?? Thanks.
    aelarson likes this.
  5. Aug 17, 2022 at 7:04 PM
    PayItOff428
    PayItOff428 New Member
    Jake
    The United State of Texas
    2012 SR5 Double Cab 4X4
    What bumper is that?
    Ohannon7 likes this.
  6. Aug 18, 2022 at 2:06 AM
    Chrslefty
    Chrslefty New Member
    08 dubble cab
    And the matching climate control knob's.
    @ACDC2ZZTop
    Musicmasterd12 likes this.
  7. Aug 18, 2022 at 3:38 AM
    TravisJr
    TravisJr New Member
    2001 AC SR5 4WD, 2010 DC SR5 4WD
    Lots o’ mods
    I’m not ACDC2ZZTop, but those climate controls are definitely AJT Designs. Can’t speak to the gauge bezels.
    ACDC2ZZTop and Chrslefty like this.
  8. Aug 18, 2022 at 6:48 AM
    WVI
    WVI New Member
    @008 Tundra Limited
    Yes, I've not seen it in any vids I've watched.
    The fluid seems not to be plumbed thru the radiator either, which I'm not used to..I almost want to add another..some day maybe.
  9. Aug 18, 2022 at 3:11 PM
    WVI
    WVI New Member
    @008 Tundra Limited
    Finished the trans service...
    For the final check, I let the trickle go untill was just a bit less than what he shows in this vid, which is more than I've seen in other vids...
    all collected, the amount I put back in seems to be about 2qts more than extracted....
    Tomorrow, more snooping to try and determine where the drive-line vibration is coming from.
    On Edit: If you have this trans cooler, it's the top pipe that you want to connect your discharge tube to.
    On Edit 2:....I realized early this am, that the reason I seem to have the extra fluid in the system, is because I top off the used jugs with the old fluid...which is about right!
    Shalom
  10. Aug 19, 2022 at 8:07 AM
    WVI
    WVI New Member
    @008 Tundra Limited
    Moving along now......well, I checked the front end again due to the growling that seems to be getting closer. yep, up next on my ever growing list of "Things that NEED to get done..." is the drivers side prop-shaft/Axle bearing at the differential, drivers side.
    When I began to hear said growling, I had did a quick check of it and there didn't seem to be much play...boy there is play in it now!
    Onward and upward.have a great day.
  11. Aug 19, 2022 at 8:31 AM
    Retroboy1989
    Northern Utah
    Is that the needle bearing that has an aftermarket fix?
  12. Aug 19, 2022 at 9:11 AM
    WVI
    WVI New Member
    @008 Tundra Limited
    Yes it is.
    It would be using the bushing from East Coast Gear.
  13. Aug 19, 2022 at 12:15 PM
    BEDINTRUDER
    BEDINTRUDER New Member
    Dom
    OHIO
    2011 Tundra RockWarrior (SOLD) 2018 Tundra Limited
    I have been running this bushing now for a while and after 37,000 miles it is now time to replace the bushing again. Growling and vibration is back
  14. Aug 19, 2022 at 5:10 PM
    Retroboy1989
    Northern Utah
    Can you describe the vibration?
  15. Aug 19, 2022 at 10:59 PM
    ACDC2ZZTop
    ACDC2ZZTop Rock n Roll!
    Travis
    Oregon
    2012 MGM Tundra double cab 5.7L V8
    All cosmetic so far see my posts in 2nd gen Black out chrome in progress….
    I pulled the dash piece and the rings come off.
    I painted with anodized red spray can.
    The dash piece was gray and I went with a flat black to match rest of the dash.
  16. Aug 20, 2022 at 6:41 AM
    WVI
    WVI New Member
    @008 Tundra Limited
    Is your truck suspension stock?
  17. Aug 21, 2022 at 5:40 AM
    COTundie
    COTundie Whoa Black Betty
    Trey
    Black 5.7 DC TRD 4x4
    Pretty things
    Paranoia finally caught up with me and I picked up the last Miller cat protection plate at my local dealer on Friday.
    3 piece design made from pretty beefy 3/16" aluminum, so it's plenty sturdy while remaining light enough to easily install by myself. The hardware is of very high quality and recessed into the plate, so I have a better chance of clearing rocks offroad.
    The only letdown is, they didn't take the time to deburr the heat extraction slots in the plates, so they are pretty sharp on one side (the exposed bottom-side of course).
    While there is excellent coverage for the front cats, the rears are mostly exposed with this design. Miller apparently has extensions which can be purchased and added, but reviews seem to indicate they are kinda flimsy. We'll see if I order them, rig something myself, or just let it be. It would still be somewhat annoying to access the pipe in front of the rear cats in order to remove them, but definitely possible. Luckily, all of the expensive stuff that also seems to get damaged during a theft is surrounding the front cats, so there is some solace in that.
  18. Aug 21, 2022 at 6:39 AM
    Zebruaj
    Zebruaj New Member
    MN
    08 CM SR5
    Hauled supplies up for camp. Stopping for gas every 90 mins worked well with my bladder.
  19. Aug 21, 2022 at 8:32 AM
    Ohannon7
    Ohannon7 New Member
    Central Fl
    2013 5.7 4WD CM Bench-Seat Silver
    6” Pro Comp 37’s Custom audio and interior Off road capability is current focus
    150 M.P.T.
    miles per toilet
    blenton, Chrslefty, wv00097 and 7 others like this.
  20. Aug 21, 2022 at 3:12 PM
    ACDC2ZZTop
    Travis
    Oregon
    Added active noise filter to aftermarket stereo. Hopefully it gets rid of low hum in the background.
    Also gave it a bath.
    omgboost and joseph_womack like this.
  21. Aug 21, 2022 at 8:54 PM
    joseph_womack
    joseph_womack @ 4x4bound
    Joe
    Louisiana
    2007 RCLB, 4WD, 4.7L V8
  22. Aug 22, 2022 at 2:09 AM
    BoysandHisToys
    Central Virginia
    joseph_womack[QUOTED] likes this.
  23. Aug 22, 2022 at 4:40 AM
    BEDINTRUDER
    Dom
    OHIO
    No, i have the bilstein 6112s on the front and 5160s on the rear
  24. Aug 22, 2022 at 4:41 AM
    BEDINTRUDER
    Dom
    OHIO
    Its a rotational vibration the does not follow the speed of the vehicle. Its felt between 47-54ish mph can feel in through the floor board. Vibration goes away when truck is in 4wd
  25. Aug 22, 2022 at 4:53 AM
    Shanet421
    Shanet421 (Semi) New Member
    San Diego,CA
    I got these from another member a few months back. For me they absolutely made my seat much more comfortable to sit in.
    B54AB360-F77C-4388-8CBB-A0D9766AEF99.jpg 213F9954-881D-46FD-8216-F93725F58FF3.jpg
    You can see here how much more it will recline then the passenger side. Ignore the tear :anonymous:
  26. Aug 22, 2022 at 6:40 AM
    joseph_womack
    Joe
    Louisiana
  27. Aug 22, 2022 at 6:41 AM
    joseph_womack
    Joe
    Louisiana
    do you have a carrier bearing drop installed?
  28. Aug 22, 2022 at 7:16 AM
    BEDINTRUDER
    Dom
    OHIO
    I do have the diff drop, installed it when i did the struts
  29. Aug 22, 2022 at 7:33 AM
    joseph_womack
    Joe
    Louisiana
    no not the diff drop, the bearing on your rear driveshaft, its in the center of the shaft, has two bolts holding it up to the bed, that is the carrier bearing, you need to space it down when lifting the truck, I'd recommend throwing a spacer on before buying or replacing a bunch of expensive components
    the spacer is meant to alleviate driveshaft vibrations (I'm running one with 2.75" in the front and 1.5" in the rear with no issues https://shop-coachbuilder.myshopify.com/search?type=product,article,page&q=carrier+bearing
    NueveTundra likes this.
  30. Aug 22, 2022 at 7:58 AM
    BEDINTRUDER
    Dom
    OHIO
    My bad, I misunderstood what you meant. I have a carrier bearing drop as well.
