Is this bad?
Discussion in '2.5 Gen Tundras (2014-2021)' started by texasrho83, Aug 15, 2022.
  1. Aug 15, 2022 at 7:05 PM
    texasrho83
    texasrho83 [OP] Old Member
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    Changed my oil tonight and noticed this.
    There was a drop of fluid (wasn't a full drop if that matters) but a closer look didn't show a breach in the seal. Obviously if there's some fluid, I know it is leaking.
    My concern is that the shop that did my gears may have done this by accidentally dropping or using a pry bar to pop the CV out.
  2. Aug 15, 2022 at 8:13 PM
    C.I.
    C.I. Surf, off road, sleep, repeat
    Cesar Pedrin
    Cabo, Mx
    2016 5.7 4x4 Bronze Crewmax
    Mods: Ongoing... probably never ending
    Dang. That can't be good either, though it doesn't look terrible, perhaps can be fixed with JB weld or something.
    texasrho83[OP] likes this.
  3. Aug 15, 2022 at 8:18 PM
    It’s still sealed, further in. That does suck though. I definitely used a pry bar to pop my CVs out, maybe I chose a meatier spot to pry
  4. Aug 15, 2022 at 8:33 PM
    Cruzer
    Cruzer Wheeling Full Size
    Cruz
    Sunnyvale, CA
    Mine looks like that. When I first tried popping out the CV I didn’t really know where to pry it from and chewed up the tube.
    How long ago did you get the gears done? Could the drop be just leftover oil from when the axles were out?
    texasrho83[OP] and FrenchToasty like this.
  5. Aug 15, 2022 at 8:43 PM
    texasrho83
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    End of April. Nah I think it's fresh. The pic shows what it looks like after I wiped with a rag.
  6. Aug 16, 2022 at 7:49 AM
    Cruzer
    Cruz
    Sunnyvale, CA
    Then it’s the seal. Easy to replace. I replaced my driver side seal a couple weeks ago. Make sure to get the correct one because the driver and passenger sides are not interchangeable.
  7. Aug 16, 2022 at 8:55 AM
    JRS
    JRS New Member
    2012 DCLB
    I did my outer seals recently and the driver side still weeps. Do you guys swap in new snap rings, too? My driver's seems to have excessive movement. If I had to guess, that's why.
    Same vein - none of you were able to give them a good yank? You had to use a pry bar?
  8. Aug 16, 2022 at 9:33 AM
    texasrho83
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    I wonder that if the seal is replaced, with that chunk gone, would it still leak....if so, it's pointless to replace
  9. Aug 16, 2022 at 9:36 AM
    C.I.
    Cesar Pedrin
    Cabo, Mx
    You're not wrong, but at the very least you'll know, then you can figure out what to do next.
  10. Aug 16, 2022 at 9:40 AM
    This is exactly why I bring a creeper board with me after getting warranty work or any shop work done for that matter.
  11. Aug 16, 2022 at 10:31 AM
    Cruzer
    Cruz
    Sunnyvale, CA
    The seal is further in the tube like here.
  12. Aug 16, 2022 at 10:35 AM
    Sumo91
    Sumo91 Busy with projects
    TN
    2014 MGM Tundra Platinum 4x4
    The chunk missing in the housing won't cause any leaks directly, but it does expose the actual CV axle seal to dust, dirt, and debris, since all of that can now get directly behind the dust shield, you can see the lip of the dust shield through the hole in your axle housing. Check out the second picture of this post, right next to the screwdriver on the table, that is the dust shield (thanks @Cruzer for the dust shield recommendation when I had to replace my axle seals)
    https://www.tundras.com/threads/front-diff-seals.106673/#post-2751926
    If it were my truck, I'd try JB weld with the CV axle out (with seal still installed to keep oil from contaminating the bonding surface for the JB weld) then lightly sand it down the match the machined surface as good as possible.
    Or put some gorilla tape on it just to cover the hole. That stuff really holds up good.
  13. Aug 16, 2022 at 10:43 AM
    texasrho83
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    I sent the pic to my mechanic. He immediately apologized and mentioned that it probably happened when his tech pulled the CV. He assumed full responsibility and said to bring in the truck and they'll do what it takes to make it right.
    AGTundra, batman900, Mater and 7 others like this.
  14. Aug 16, 2022 at 10:45 AM
    Cruzer
    Cruz
    Sunnyvale, CA
    Nice!
  15. Aug 16, 2022 at 10:54 AM
    Sumo91
    TN
    Now THAT is an awesome mechanic!!
    Mater, texasrho83[QUOTED][OP] and 1UP like this.
  16. Aug 16, 2022 at 10:58 AM
    Cruzer
    Cruz
    Sunnyvale, CA
    I now just use this fork...comes out with ease and doesn't damage anything.
  17. Aug 16, 2022 at 11:38 AM
    texasrho83
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    Well that's going on my wish list lol
    AZBoatHauler likes this.
  18. Aug 16, 2022 at 11:45 AM
    Bakershack
    Kelly
    Spanish Fort, AL
    2020 SSM 1794 4x4
    If I lived anywhere near you, I would DEFINITELY want to know who your mechanic was!
  19. Aug 16, 2022 at 11:58 AM
    texasrho83
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    Yeah he's pretty damn cool in my book. I also got my one piece shield from him and he installed it.
  20. Aug 16, 2022 at 2:20 PM
    AZBoatHauler
    So.Arizona
    Didn’t think it would cost me money clicking on this thread - damn this site
    :spending:
  21. Nov 11, 2022 at 6:17 PM
    texasrho83
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    Update:
    Finally had time to take the truck in for the once over and repair. He immediately ordered the part and installed it as soon as he got it in. Took the truck to him on Monday and I have it back today.
    I didn't know you could get the axle housing tube on its own but thankfully you can.
    Screenshot_20221111-200716_Brave.jpg Screenshot_20221111-195952_Brave.jpg 20221111_162333.jpg
  22. Nov 11, 2022 at 6:23 PM
    Cruzer
    Cruz
    Sunnyvale, CA
    Do you know if they drained and filled your diff?
  23. Nov 11, 2022 at 6:24 PM
    texasrho83
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    No. I asked and he said no it wasn't necessary
    HulkSmurf14 likes this.
