Front diff seals
Discussion in '2.5 Gen Tundras (2014-2021)' started by Sumo91, May 1, 2022.
  1. May 1, 2022 at 7:08 AM
    Sumo91
    Sumo91 [OP] Busy with projects
    TN
    2014 MGM Tundra Platinum 4x4
    Hey guys, I seemed to have blown out both my front diff seals after some hard wheeling yesterday. It's leaking on both sides, dripping on the cardboard I have underneath it, probably a few ounces so far. I believe the parts numbers I need are as follows, but feel free to correct me
    90311-47027 left seal
    90311-47013 right seal
    I'll be upgrading to the ecgs bushing while I'm in there, but I want to get the seal from toyota. Is there any other seals, etc I should replace while I'm in there? I appreciate any insight! Just wanna make sure I'm on the right track.20220501_093420.jpg 20220501_093433.jpg 20220430_172316.jpg
  2. May 2, 2022 at 5:24 AM
    Sumo91
    TN
    Ordered the 2 seals this morning, they'll be available for pick up tomorrow at the dealership. I'll tackle the seals once I replace the alternator (it finally gave up after the huge mud hole) and I'll keep everyone posted on whether it fixes it or not.
    texasrho83 likes this.
  3. May 2, 2022 at 7:04 AM
    You check the breather for the front diff? If it’s clogged up the pressure from the heated fluid could be causing the seals to fail.
  4. May 2, 2022 at 7:36 AM
    texasrho83
    texasrho83 Old Member
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    It's pretty high up on the firewall so it should be fine unless he totally submerged his engine bay
    Tundra18overland and Sumo91[OP] like this.
  5. May 2, 2022 at 8:11 AM
    eick
    eick New Member
    2020 CrewMax TRD Off Road
    Judging by that pic he may have totally submerged his headliner too
    r1-superstar and Sumo91[OP] like this.
  6. May 2, 2022 at 8:18 AM
    texasrho83
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    Sumo91[OP] likes this.
  7. May 2, 2022 at 8:30 AM
    If it gets muddy, it could get plugged up. Mid will definitely splash up to there. Believe me.
  8. May 2, 2022 at 9:21 AM
    Sumo91
    TN
    I don't *think* I submerged it. I'll post a pic showing how deep it was, I hit it pretty fucking hard though, I was the only one who didn't get stuck in a full size vehicle. It's a beast of a truck. I'll check out the breather and see if it's clogged20220430_172233.jpg 20220430_164136.jpg
  9. May 2, 2022 at 9:25 AM
    texasrho83
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    Man I am glad I wasn't there. Would've totally charged through that too
    Sumo91[QUOTED][OP] likes this.
  10. May 2, 2022 at 9:32 AM
    Cruzer
    Cruzer Wheeling Full Size
    Cruz
    Sunnyvale, CA
    Order two of these 413360C010
    They are the seals that go on the inside of your spindles where the CV axle mates with.
    Sumo91[OP] and texasrho83 like this.
  11. May 2, 2022 at 9:41 AM
    Sumo91
    TN
    I'll call the dealership and get them ordered. Any special tool I need for this job? I think I read that I need a 35mm socket?
  12. May 2, 2022 at 9:43 AM
    Sumo91
    TN
    My man! It was a blast. Had a big crowd watching watching too, cause once the jeep got stuck, we held up a group of side by side riders. They were placing their bets on who would and wouldn't make it. The tundra prevailed!
    Cruzer and texasrho83[QUOTED] like this.
  13. May 2, 2022 at 10:08 AM
    texasrho83
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    Prevailed as it should!
    Did you win enough on those bets to cover the gas? :p
  14. May 2, 2022 at 10:18 AM
    Sumo91
    TN
    We burned through a 1/4 tank in about 6 hrs (26 gal tank) so it wasn't too expensive.....until I got home and my seals were leaking and alternator was toast lol
  15. May 2, 2022 at 1:24 PM
    Cruzer
    Cruz
    Sunnyvale, CA
    I just used a 2x4 block to evenly set them in place. Don’t over do it or the wire spring inside the seal will bust out.
  16. May 3, 2022 at 5:12 PM
    Sumo91
    TN
    The breather lines weren't clogged, I made a post about all the breather lines in the engine bay here
    https://www.tundras.com/threads/breather-line-location-guide.106788/
    I got the alternator installed, took around 2 hours. Both seals came in today as well, but the dust covers won't be here till tomorrow or Thursday. I picked up a 39mm socket to remove the axle so I can replace the seals and install the ecgs bushing.
    DZ_ and KNABORES like this.
  17. May 4, 2022 at 2:02 PM
    Sumo91
    TN
    Looks like I got water in my front diff when the seals popped. Pulled a sample out of the drip container I have underneath the diff, and its slightly milky looking compared to a sample out of a new container. I just changed it 4k miles ago too.20220504_165524.jpg 20220504_165558.jpg
  18. May 5, 2022 at 4:06 PM
    Sumo91
    TN
    Got the passenger side CV removed. Still waiting on my parts from ECGS. Fed ex dropped the ball on that one. The CV seems to have a groove in it from the seal, but I dont think it's an immediate issue, alot of sand and dirt was in the seal causing the leak. 20220505_172840.jpg 20220505_173015.jpg
    Tundra Dude 45 and AZTundra like this.
  19. May 5, 2022 at 5:42 PM
    Sumo91
    TN
    So quick question for someone who may have the specs for this. I was installing the passenger side seal, and it isn't supposed to seat all the way. Whats the specs on seating it? I drove it in a touch too far from what I could tell. I was able to get a random old bracket I had and very gently pry the seal back out without damaging it. Worked better than a seal puller.
    When I grabbed my calipers to get measurements from the lip to the seal, it wasn't even on top, bottom, left, and right, maybe .3-.5 mm off (5.43mm-5.89mm). I'm guessing my differential casing isn't perfectly flat on the lip. The seal is even all the way around on the machined surface inside the lip though.
    Maybe I'm just overthinking it. But I'd like to get it done right the first time.
  20. May 8, 2022 at 8:17 AM
    Sumo91
    TN
    Just an update. Finally got the truck finished on Friday after fed ex finally delivered the goodies from ECGS. My overnight shipping took 3 days :eek: all seems to be well, no leaks or strange noises. All in all, it wasn't too bad. Once I got the seal installer from ECGS I as able to see my mistake installing the seal and was able to get it corrected.
    The bottom of the diff still has some dirt/mud in it I couldn't get out. But I plan on changing the fluid again soon anyway just for good measure. I'll probably rig up a recirculating pump set up next fluid change so I can flush out the diff case with mineral spirits. I didn't wanna use brake cleaner because it's a little too harsh on seals.
    thearborbarber and Piki like this.
  21. Aug 7, 2023 at 12:18 PM
    yakeng
    yakeng 3URFE Apologist
    Measure the seal depth with calipers before you pull it out. Before I replaced my ECGS, I tried to find that info and couldn’t find anything but “don’t push it too far”. I matched existing and no leaks.
