2016 vs 2017 Toyota Tundra
Discussion in 'General Tundra Discussion' started by TexMedic, Aug 14, 2022.
  1. Aug 14, 2022 at 2:34 PM
    TexMedic
    TexMedic [OP] I ask a lot of questions…
    2017 Dark Gray DC Tundra 4x4
    I’m looking into picking up a “new” (used) Tundra. The most common years I’m seeing that are within my wants are 2016 and 17. Is there any real difference between the two? Either one would be a 4x4 5.7 Double Cab. I know trim level can change what comes with it- just looking into general differences (if any).
  2. Aug 14, 2022 at 2:44 PM
    Taco-Spike
    Two Trucks
    I don’t think there are much of any difference??
    Did you find one of each year?
    most of the changes came in 2018 then 20/21 models.
  3. Aug 14, 2022 at 5:02 PM
    tightywhitey
    tightywhitey New Member
    New Orleans, LA
    2015 Toyota Tundra CREWMAX - Louisiana Edition
    2015 FTW!
    I think the 2017 got the bigger tank.
  4. Aug 14, 2022 at 6:44 PM
    TexMedic
    I’ve seen a couple of each- all similar in terms of trim. I know the 20/21 got Apple CarPlay, and I assume that’s it? What’s new in the 2018? Anything worth my while, or are the 16/17/18 the same? I know newer is probably better in terms of age, but that’s not my main motivator.
  5. Aug 14, 2022 at 6:53 PM
    BTBAKER
    BTBAKER .
    Brad
    Castle Rock
    2022 Ram TRX Level 2
    My 17 5.7 has been a very solid and reliable truck.
    Toyotoholic and AZBoatHauler like this.
  6. Aug 14, 2022 at 6:54 PM
    dt325ic
    dt325ic Member
    GA
    2019 TRD Sport
    The LED headlights are much better than the standard halogens. I would seek a truck with those, as it's pricey to add after the fact.
    Go for condition over year, as there isn't much difference between the two.
  7. Aug 14, 2022 at 6:58 PM
    18" TRD Off Road Wheels
    2018 was the addition of the TSS package. (Radar cruise, collision avoidance, etc)
    2016 was the first year the 38 gallon tank became an option but was not standard. The package it was included in varies through the years.
    There might have been a new instrument cluster layout in '16 or '17? Not 100% sure.
    Cpl_Punishment likes this.
  8. Aug 14, 2022 at 7:11 PM
    AZBoatHauler
    So.Arizona
    Agree with the LEDs being far superior.
    It was about $800 when I upgraded my 2017 - not cheap but also not worth spending a few grand on a newer/different trim truck IMO…
    38 gallon fuel tank way bigger deal for me.
  9. Aug 14, 2022 at 7:12 PM
    AZBoatHauler
    So.Arizona
    I think 2017 was the first year the exterior temp is always displayed on the center cluster.
  10. Aug 14, 2022 at 7:20 PM
    GoldenGoon89
    GoldenGoon89 New Member
    Houston,TX
    2018 CM -1794 BLUEEE- 4x4
    Both are great choices.
    I had a 17 and loved it.
    I don’t believe much changed between the years you mentioned. Good luck with your choice!
    AZBoatHauler likes this.
  11. Aug 14, 2022 at 7:22 PM
    locutis1704
    locutis1704 New Member
    Ohio
    2016 Black Tundra
    Love my 2016!!!!!
  12. Aug 14, 2022 at 7:28 PM
    dt325ic
    dt325ic Member
    GA
    2019 TRD Sport
    I agree 100% with you. The 38 gal fuel tank is a must have. The lights are fairly easy to do, and $800 is less expensive than I thought.
  13. Aug 14, 2022 at 7:30 PM
    Baja Mike
    Baja Mike Baja Aficionado
    South Bay, Ca.
    2016 Tundra TRD 4x4 SR5 white
    The 2017 got a honeycomb style grill.
    LED headlights too possibly. My '16 came with the halogens which were absolute garbage.
  14. Aug 14, 2022 at 7:34 PM
    rruff
    rruff New Member
    2016 Tundra SR DC Long
    My 2016 has that.
    AZBoatHauler[QUOTED] likes this.
  15. Aug 14, 2022 at 7:36 PM
    AZBoatHauler
    So.Arizona
    Those were both 2018.
    Toyotoholic and NWPirate like this.
  16. Aug 14, 2022 at 7:37 PM
    CaptRussia253
    CaptRussia253 New Member
    Ruslan
    Reason I bought my 2017. I love the large 38 gallon tank on our long family trips. It’s a must.
  17. Aug 14, 2022 at 8:35 PM
    BTBAKER
    BTBAKER .
    Brad
    Castle Rock
    I guess it’s settled. The 2017 Tundra was the best truck ever made. Find one in good shape and you’ll be a happy Tundra owner. :thumbsup:
  18. Aug 14, 2022 at 8:35 PM
    AZBoatHauler
    So.Arizona
    2017 Limited CM to be precise. :fistbump:
    BTBAKER[QUOTED] likes this.
  19. Aug 14, 2022 at 8:36 PM
    BTBAKER
    BTBAKER .
    Brad
    Castle Rock
    I also swapped my headlights to LED in my 17. Very easy to do.
  20. Aug 14, 2022 at 8:37 PM
    BTBAKER
    BTBAKER .
    Brad
    Castle Rock
    I couldn’t agree more. :rofl:
  21. Aug 14, 2022 at 10:39 PM
    ZappBrannigan
    Canada, by way of Hawaii
    2018 1794 MGM
    NVS light bar
    If the 2018 didn’t exist that would be true.
    2018 for the win!
  22. Aug 15, 2022 at 6:10 AM
    Cpl_Punishment
    Neil
    2020 MGM SR5 CM 4X4
    I thought it was 2018 that got the new cluster. Seems to me like that's worth it.
    To the OP, if I were buying a used Tundra, 2018 would be my choice. Big fuel tank, upgraded cluster and transmission cooler.
    ZappBrannigan and Junior 88 like this.
  23. Aug 15, 2022 at 6:43 AM
    Yeah, I'm honestly not sure when they updated the cluster for sure.
    100% agree the bigger tank is a must, but you have to check all the details on the packages by MY because they kept moving it around. It was in the SR5 Convenience Package on mine, but I think on another year it was in the TRD Off Road. That tank is such a high priority to me that I wouldn't buy one without being certain it was there.
  24. Aug 15, 2022 at 7:14 AM
    Toyotoholic
    Toyotoholic -4Life-
    Jmz
    17' MGM
    Pro suspension, sways
    They updated the cluster in the 18 due to the TSS electronics, and LED lighting
    17 was the last year you had everything in your control without any extra computers.
    Big tank.
    Trans-cooler
    No nanny
    Best of the best IMO.
    But no LED lights. (Easy fix)
    Yes I have a 17... Lol
    A loaded 16 would be closest without the computers so long as you got one with the big tank.
    CaptRussia253 likes this.
  25. Aug 15, 2022 at 8:02 AM
    Cpl_Punishment
    Neil
    2020 MGM SR5 CM 4X4
    OP, if you plan to tow and you get a 2016 or 2017, make sure to get the TSB done on the integrated brake controller or get yourself an aftermarket one. The controller in my truck is good but I think they had some issues before 2018.
  26. Aug 15, 2022 at 9:06 AM
    TexMedic
    They updated the cluster in the 18 due to the TSS electronics, and LED lighting.
    Big tank.
    Trans-cooler
    No nanny
    A loaded 16 would be closest without the computers so long as you got one with the big tank.[/QUOTE]
    What do you mean by “had everything in your control without any extra computers”? What did they add in the 2018+? Sorry, I’m new to this. Coming up from a 2012…
  27. Aug 15, 2022 at 9:08 AM
    Lots of people do not like the Toyota Safety Sense items and refer to them as nannies. The truck can automatically brake to prevent a collision, for example.
  28. Aug 15, 2022 at 9:23 AM
    TexMedic
    Thanks. I assume you can’t turn them off? In that case, I better prioritize a 2017 over an 18. If I see a good 18, then I might take it (assuming all the new stuff isn’t a pain in the rear). I do really like that “new” cluster though. Thanks guys.
  29. Aug 15, 2022 at 9:25 AM
    TexMedic
    Don’t plan on towing with it. That’s what my F250 is for haha.
  30. Aug 15, 2022 at 9:42 AM
    You can turn them off, but you need to do so each time the truck is started. I have a 2019 with them, and it's not intrusive IMO, and I love the radar cruise control.
