Screen half green
Discussion in '3rd Gen Tundras (2022+)' started by Kirron, Aug 5, 2022.
  1. Aug 5, 2022 at 2:36 PM
    Kirron
    Kirron [OP] New Member
    22 Tundra SR5 CrewCab TRD Off-road 4x4 in Lunar Rock!
    Vanilla
    Yesterday I saw there was a software update so I applied it. The update finished after a few minutes.
    Today when I turned on the cameras I noticed half the screen was green. I hit the camera button a few more times which resulted in… working, working, broke, working, broke, working, etc… I could still use touchscreen buttons “behind” the green. When broken, the green was always on the right half. The green only appeared when the cameras were active.
    Has everything there been any other reports of this? I see there is a recall for the camera system. Could this be related?
  2. Aug 5, 2022 at 3:25 PM
    Maharisc
    Maharisc w/Patty
    Karl
    Build date: 12/05/22
    I had that once, push the volume button in will cause a reboot or you can turn off the truck and back on should clear it up. Seek help from dealer if it continues.
  3. May 1, 2024 at 6:28 PM
    Lomalinda
    Lomalinda New Member
    So I bought a Limited Sequoia Hybrid 4WD last week. Today, I had a similar issue like yours. My whole screen went completely green. Then, returned to normal. I am not sure what I pushed.
    Then, while driving. The cameras turned on display once the vehicle is below 10 miles/ hour. However, the entire right side of the screen turned GREEN. It is happening sporadically. What was the fix for your Tundra?
    TIA.
  4. May 1, 2024 at 6:57 PM
    901tundra
    901tundra New Member
    Memphis, TN
    2023 Magnetic Gray Limited TRD Off-road
    - Color-matched grille and rear bumper insets - 1-inch Cornfed front spaces - TRD grille with light bar and amber marker lights - Debadged
    nice job catching that orange Tacoma!
    Tundrastruck91 likes this.
  5. May 2, 2024 at 8:59 AM
    DTieu1
    DTieu1 New Member
    Andrew
    2022 Toyota Tundra iForceMax
    Im having the same issue in mine. Took it to the dealer, they said it's most likely the camera. So that got replaced. Then couple days ago, same thing. Toyota is saying it's the parking assist ecu. Kinda strange its that. But lets see how that goes.
  6. May 2, 2024 at 6:27 PM
    Littleschipper
    Littleschipper New Member
    SCPA
    2023 Supersonic Red 1794 Hybrid
    This happened to me after an online software update. Every time the camera turned on at a stop half of the screen was blank, but not green. Turned the truck off, restarted it, and it went away. Hasn’t happened since.
    :amen:
