Gen 2.5 PS rusted metal line
Discussion in '2.5 Gen Tundras (2014-2021)' started by trd_in_cny, Aug 3, 2022.
  1. Aug 3, 2022 at 2:02 PM
    trd_in_cny
    trd_in_cny [OP] Code jockey and cloud monkey
    Donny
    Central NY
    2015 TRD DC Limited
    Hi, quick question on a power steering part. PN 44410 - TUBE ASSEMBLY, PRESSURE FEED. Is there any reason I need to do a full part replacement versus eliminating the double-hairpin metal line only? Can I go with a high-pressure flex line instead?
    Can anyone provide insight into why it's built like this? At first I thought exposed metal for cooling properties; but I have a PS fluid cooling fin in front of the tranny cooler. Then I thought maybe the 180 degree bends do something with volume vs pressure.
  2. Aug 5, 2022 at 8:19 AM
    trd_in_cny
    Donny
    Central NY
    2015 TRD DC Limited
    Found some guidance on AllPar that sounds feasible - harmonics...
    Can anyone confirm or deny that the mixture of materials is simply a cost and/or ease of installation factor? As in, flexible hose use in matings and areas of vibration whereas metal is used where it won't need to flex at all? I guess it's time to bite the bullet and buy the OEM replacement...
