Tundras were built for this!!
Discussion in 'Towing & Hauling' started by FedExTrucker, Jul 29, 2022.
  1. Jul 31, 2022 at 11:37 AM
    #151
    Cpl_Punishment
    Neil
    2020 MGM SR5 CM 4X4
    Jesus, that's a big slide.
  2. Jul 31, 2022 at 11:59 AM
    #152
    Backslider
    Backslider Thirsty...
    Tooele, UT
    2022 GMC Sierra AT4 L5P - 2017 4runner SR5P - 2023 Tesla Model 3 LR
    Outside of safety, one of my biggest concerns if towing above payload and/or tow weight, would be that insurance could rightfully deny any claim after an accident, regardless of whether or not either of these were directly or indirectly responsible for the accident.
    I purchased an HD truck with the desire of being well under because I'm lazy and don't want to do the math, or have it weighing on my mind that if anything were to go wrong I could potentially be out well over $100k.
    If you're rolling deep enough that this potential loss doesn't bother you, or you're just not in this headspace at all, more power to you I guess. I always get ahead of and away from vehicles that are clearly overburdened. I wish police would start pulling people over for this.
    motoryder and PermaFrostTRD like this.
  3. Jul 31, 2022 at 12:05 PM
    #153
    Catmann1972
    Catmann1972 New Member
    Greg
    Rhode Island
    2020 TRD Sport
    The State Police here in the New England area will pull you over if they suspect you are overweight. The local police, not so much.
  4. Jul 31, 2022 at 12:13 PM
    #154
    Samoan Thor
    Samoan Thor God is technically an alien
    Limited 2014 crewmax 4X4
    Kings F&R, no sway bars
    Yea you’re definitely a troller and can’t read, what I was trying to say is before my 3 years of towing I never towed and I can say my experience from those 3 years I know that you’re overloaded. You don’t have enough payload, check your purse for the manual
  5. Jul 31, 2022 at 12:42 PM
    #155
    FedExTrucker
    FedExTrucker [OP] New Member
    Thurman
    19 Limited Crewmax
    Nokian Outpost AT
    Biggest on the market... Open Range has 42" deep slides. The kitchen slides out also with an island in the middle. Feels nice and wide open.
  6. Jul 31, 2022 at 12:55 PM
    #156
    Cpl_Punishment
    Neil
    2020 MGM SR5 CM 4X4
    Hope it doesn't end up looking like the slide in the 2012 Shadow Cruiser I looked at where the slide roller had cracked the floor.
  7. Jul 31, 2022 at 3:15 PM
    #157
    rruff
    rruff New Member
    2016 Tundra SR DC Long
    Exactly. GVWR is the manufacturer's warranty and liability limit.
  8. Jul 31, 2022 at 3:37 PM
    #158
    Lack of regulations? SAE J2807 is the standard. If a truck can’t complete the test at a certain weight, it has to be lowered until it can.
    There is no snake oil in this testing. It either can or can’t.
    Cpl_Punishment likes this.
  9. Jul 31, 2022 at 3:43 PM
    #159
    rruff
    rruff New Member
    The OP is well under the tow rating.
  10. Jul 31, 2022 at 3:55 PM
    #160
    And he is over on payload and axle(most likely). I guess since he might be under GCWR it makes it all right. :rolleyes:
  11. Jul 31, 2022 at 4:09 PM
    #161
    Sorry, missed this quote.
    Heat, speed, and max capacity is what was killing his tires. Sometimes when you have a blowout on one tire, the tire next to it can get damaged as well. It has happened to me on a few occasions.
    One of the tools I carry at all times is a thermal gun. It’s amazing how hot your tires can get on a trailer. I have seen 168*F, but it was 90+* out and was at max GCWR of ~25K lbs.
    Every time I stop the tires, brakes, and rear differential temperature is taken. The day I seen 168* on my tires…I stopped for the day. No reason to push it.
  12. Jul 31, 2022 at 4:21 PM
    #162
    Pillslinger
    Pillslinger New Member
    Rollin
    SWMO
    2018 Cement TRD CrewMax
    Bed light kit Jerry can mount Badge overlays (removed 2021) Pin stripe / TRD decal / pillar vinyl removal Raised tailgate lettering Center console badge/tray/divider Interior/exterior LED upgrade VLED footwells TVD Vinyl TRD Offroad wheels Icon 17x8 rebound titanium Bubbas Garage grab handles WeatherTech floor mats (Eagle Klaw added) Rough country front shackles (removed 2021) DD SS3 yellow fogs MESO map light replacement Softopper MESO Chrome delete
    Think you'll have to fill the cab instead to get the weight off the springs.
  13. Jul 31, 2022 at 4:48 PM
    #163
    Tripleconpanna
    2021 TRD PRO CM; 2008 SR5 CM
    To tie this back into this thread topic: There’s a lot of space between this fool in Nevada towing multiple tons over what his truck is rated for with no trailer brakes and no CDL, and the OP towing a load that realistically puts him 800-1000 lb over payload.
    Given new info about the @FedExTrucker ’s rig, I would definitely never pull that trailer with a crewmax Tundra.
    Lastly, I’m not saying investigative teams won’t weigh your private recreational vehicle rig. I’m just still looking for an example. This story is not the “proof” we’ve all been asking for.[/QUOTE]
    1000lbs 'over' on payload is almost double for the Tundra!!!! So, if you double the payload/tow capacity of the SD from 20k to 40k or double the Tundras, either way is irresponsible and could be equally tragic.
    No disrespect intended here... But, I struggle w/the whole 'show me proof that I can't and that someone of authority will call me on it', or it mitigates the application of common sense in the scenario on anyone's behalf.
    EX>>>
    I'd bet a paycheck that no state has, within its statutes or vehicle codes, anything that specifically says you MUST run the recommended air pressure in your tires as depicted on your vehicle's door jamb placard (the same one that talks about payload, GVR, etc...)
    I'd also bet a paycheck that no one of authority is running around checking the air pressure of the tires on your Tundra, even when they appear to be under inflated.
    I'd bet the same holds true even when a tire blow out is likely the cause of a severe accident; my guess is that no one is running around checking the air pressure on the rest of your tires.
    We all know that running a severely under inflated tire will cause said tire to heat up excessively, and it will significantly increase the likelihood of that tire having a blow out.
    So, with all that being said, just because there is no PROOF that someone will actually investigate your air pressure and there is no specific statute prohibiting you from under inflating your tires, doesn't common sense and being a reasonable prudent human being override the lack of legislation and potential subsequent intervention from anyone of authority?
  14. Jul 31, 2022 at 5:06 PM
    #164
    Pillslinger
    Rollin
    SWMO
    EX>>>
    So, with all that being said, just because there is no PROOF that someone will actually investigate your air pressure and there is no specific statute prohibiting you from under inflating your tires, doesn't common sense and being a reasonable prudent human being override the lack of legislation and potential subsequent intervention from anyone of authority?[/QUOTE]
    Cpl_Punishment and GODZILLA like this.
  15. Jul 31, 2022 at 5:06 PM
    #165
    FedExTrucker
    Thurman
    19 Limited Crewmax
    Nokian Outpost AT
    EX>>>
    My new 10 ply tires have an 80 psi max... When towing I'll probably run between 65 and 70. Now I WAS towing it with the stock tires at about 35 psi... And that did make me nervous but we only made 2 trips. These new tires make me feel a whole lot better!
  16. Jul 31, 2022 at 5:16 PM
    #166
    Vizsla
    Vizsla 2 = 2.5
    Proof? Like starting a thread on a public forum to brag you can tow/haul more with a Tundra than it is rated for? Hahaha. Be stupid for me to do, but nobody knows who I work for, and don’t have a CDL. Play stupid games win stupid prizes is one thing, but you raised the bar.
  17. Jul 31, 2022 at 5:22 PM
    #167
    You completely missed his point.
    ColoradoTJ and Cpl_Punishment like this.
  18. Jul 31, 2022 at 5:29 PM
    #168
    Black@Blue19
    Black@Blue19 Old Salt
    Ken
    SE Texas
    Six pages, I keep going back to the statement
    “By that I mean I usually have the cruise set at 67 and it goes right up without losing even 1 MPH. Now she drops a few gears and runs up to about 3500 RPM but has no trouble pulling it at all.”
    And every time I read it I get a nice little laugh!!!!:) WOW!
  19. Jul 31, 2022 at 5:32 PM
    #169
    Pillslinger
    Rollin
    SWMO
    landphil and GODZILLA[QUOTED] like this.
  20. Jul 31, 2022 at 5:33 PM
    #170
    landphil
    Phil
    BC, Canada
    ‘08 TRD doublecab
    I know, right? I know what mine does on cruise when empty, and it ain’t that. My foot and I do better, and that’s how I tow. I’ve also spent enough time on a ranch to know what bullsh1t is.
  21. Jul 31, 2022 at 5:40 PM
    #171
    EmergencyMaximum
    EmergencyMaximum New Member
    Maybe he forgot he un-hitched his trailer that day?
  22. Jul 31, 2022 at 5:40 PM
    #172
    Melikeymy beer
    Melikeymy beer No cooler for you!
    Muscogee Nation
    2019 Platypus Tundra
    Bonus I'll sound like Alvin the Chipmunk as I'm singing along to Van Morrison's Brown Eyed Girl as I drive down the road. The wife will love it.
  23. Jul 31, 2022 at 5:40 PM
    #173
    Pillslinger
    Rollin
    SWMO
    :amen:
  24. Jul 31, 2022 at 5:58 PM
    #174
    Terndrerrr
    Terndrerrr 925000 miles to go
    Music City
    6UR-FE
    I totally agree that we should all exercise common sense and use reasonable prudence. I’m playing devil’s advocate a bit, to be honest.
    I just think the idea that if you get into a wreck with a truck and trailer, they’re going to drag your wreck to the scales, find that you’re over payload, and deny your insurance or send you to jail is COMPLETELY FALSE. It is a particularly strong form of internet lore, and I find it to be extremely rich coming from people who readily admit that they drive in excess of the posted speed limit (which is an actual legal standard). And the idea that your truck being 1000lb over payload is going to wind up like the moron in Nevada hauling 18-19 tons behind him in an F350 with no trailer brakes is laughable, sorry.
    Yes, the OP’s rig is more than a bit over payload.
    • So were the Tundras that ran a million miles worth of oilfield hot shot hauling. Toyota readily shared this info with the world with no caveats or disclaimers.
    • So was the Tundra given to the ranch and run for 100k miles worth of farm duty, including pulling extremely heavy loads. Toyota made a series of ads out of it.
    • So are both flatbed truck camper overlander Tundras on YouTube. (Look up Bound For Nowhere—theirs is 9000lb empty. That’s 1800-2100 lb over GVWR, empty).
    Lots of people make their livings bolting WAY too much shit to Tacomas, Jeeps, Tundras, etc that put them at or over GVWR before anyone steps into the vehicle or loads so much as a water bottle into it. If it were actually dangerous, it would be actually illegal to be above the “should not exceed” numbers on your door jamb. If it were actually illegal, then this would be a heavily regulated industry with licenses and inspections and DOT numbers just like commercial haulers. Again, OF COURSE we should all exercise prudence and be as safe as possible at all times.
    This also means you should never speed. Ever again. It is a limit set by engineers for each state based on tons of data from population density to weather to geography to traffic accident data to density of entry/exit points to the roadway etc etc etc. How dare you drive 5 mph over on the highway! My kids are in my truck with me! Let me know where you live so I can stay off your roads you selfish Neanderthal. (Not speaking to you directly, @tripleconpanna…this is just how the internet payload police sound to me).
  25. Jul 31, 2022 at 6:28 PM
    #175
    Vizsla
    Vizsla 2 = 2.5
    Lol! Like this? Believe originally hit a rock that should of been fine, to whatever. But idk.
    https://www.instagram.com/p/CeT_YtuJUz6/?igshid=NDBlY2NjN2I=
  26. Jul 31, 2022 at 6:34 PM
    #176
    Terndrerrr
    Music City
    6UR-FE
    His words: “as I crest[ed] a small hill the road was washed out, the truck dropped into the washout and then struck the bank of the washout as it was coming out. No time to avoid, just managed the impact and drove out of the rolling force.”
    The two flatbed Tundra overlander accounts I was referring to both boxed in their frames. Like you did. Looks like this guy did not.
    Vizsla[QUOTED] likes this.
  27. Jul 31, 2022 at 7:39 PM
    #177
    I do the devil's advocate bit myself, but it's hard in this case. You do raise some good points, so let me raise a couple counter points.
    1. If this set up were in an accident there would be no need to weigh it to see that it is over the ratings. It wouldn't have to be hauled anywhere. Based solely off the Tundra door sticker and the trailer sticker it's over at a minimum it's payload, and possibly even the combined weight rating.
    2. Yes, the Nevada guy had more weight, and was a more extreme case of going beyond the tow rating. Just because somebody does something worse doesn't make this any more acceptable. Try looking at the payload on the OP's set up like this: He's not X number of pounds over payload. He's X percentage over payload. I think most people aren't going to panic if you're 10,20, or even 30% over payload, but with a likely payload of 1200ish lbs and a dry pin weight of 1510 lbs it's already in the upper end of that before anything else in the truck or trailer. Add the hitch, driver, a passenger, water and propane for the trailer... It's not a stretch to think that it's operating at 50% beyond payload or more.
    3. Running an overloaded truck around your ranch is a lot different than running it down the interstate.
    4. Those flatbed overlanders are HEAVILY modified. Boxed frames for a start. There is also a huge difference in being over payload on your truck and being over payload on your truck while also towing a 30+ foot trailer that puts you at or beyond the truck's tow rating.
    Look at speed to illustrate the proportional perspective. 10 miles per hour isn't particularly fast, right? So we could try to make the argument that being 10 MPH over the speed limit isn't that bad. Doesn't sound extreme, and we've all been passed by people out on the interstate going 10 over. Now, let's add some context to the percentage/proportional perspective. Take that same 10MPH over and put it in a school zone with a 20MPH limit. Now it's not just 10 over, it's 50% over. Apply the 10 over to a parking lot or narrow residential street with a 5 or 10 MPH limit and all of a sudden your doing double or better. Point is, 1000 lbs over payload in an new HD truck isn't the same level of bad idea as 1000 lbs over payload in a 2007 half ton, and that's exactly what a Tundra is.
  28. Jul 31, 2022 at 8:05 PM
    #178
    Windsor
    Homeless in Oregon
    2008 Tundra Crewmax 5.7L
    Some.
    I think this should be close enough to get me some $. California requires tire service providers, tire sellers to fill tires at or above the manufacturer tire pressure on the door jam.
    "The California Office of Administrative Law (OAL) has officially approved the “Regulation to Reduce Greenhouse Gas Emissions from Vehicles Operating with Under Inflated Tires (Section 95550 in Title 17 of the California Code of Regulations)."
    Edit: PM me and I'll give you my mailing address where you can send me that paycheck.
  29. Jul 31, 2022 at 8:09 PM
    #179
    Terndrerrr
    Music City
    6UR-FE
    1. I started out defending the OP, but I hope it's clear that I stopped once the actual numbers of his trailer came out. I am, however a couple hundred pounds over GWR when we camp, and I have put 1500 lbs of rock and concrete in my bed before. :anonymous: That's pushing my rear axle limit. Whenever we have this conversation, it's always hypotheticals, unless you count the guy running 18-19 tons behind his F350 with no trailer brakes, which in no way represents the worst towing offender on this site. I am playing the devil's advocate on this because I can't stand holier-than-thou internet shaming from strangers who readily admit they endanger everyone on the road around them driving in excess of the posted speed limit (in a lifted truck, no less), as if it's not the exact same thing.
    2. Nevada guy isn't representative of anything anyone is doing here. No one here is hauling over 26k without a CDL or pulling a trailer several tons in excess of what their truck's GCWR is. And again, I have stopped defending the OP. He's 2k over GCWR. I would never do that. He gets away with it, because as a recreational vehicle, he is not required to register his rig, stop at weigh stations, print DOT numbers on his door, ect.
    3. Ranch trucks do not operate solely on private land. I come from a long line of midwestern ranchers, and every one of my family's trucks transports livestock, feed, tools, and equipment whether it's to other parts of the farm, someone' else's farm, a slaughterhouse the next county over, or a livestock sale or competition a few hours away. They do more in F150s than that ranch did with the Tundra. And they go through them faster than that ranch did as well. My point is, there is no reason to think that Tundra stayed off of public roadways.
    4. Yep, modified is right. Still on the stock semi-floating rear axle, though. I don't see the problem being over payload if you are still within the stated towing (and therefore stopping) limits in the manual. For example, an 8k load that puts a truck 500 lb over payload when that truck is rated to pull 9800 is not a problem in my eyes, especially if that truck is a 2nd gen Tundra that weighs 6000 lb. Of course, you need a weight distributing hitch, LT tires, and beefier rear suspension. If Toyota says your truck can pull 9800 lb, they're implicitly saying it can stop 9800 lb, too. Just follow the manual. Stay under 65mph, and use S4 at the very least when going downhill. I'd stay in S4 the whole time to prevent heat buildup in the torque converter.
  30. Jul 31, 2022 at 8:12 PM
    #180
    Melikeymy beer
    Muscogee Nation
    Wow. Just wow.
