Tundras were built for this!!
Discussion in 'Towing & Hauling' started by FedExTrucker, Jul 29, 2022.
  1. Jul 30, 2022 at 8:14 PM
    #91
    stevesgraytundra
    stevesgraytundra New Member
    Stephen
    2021 MGM SR5 CM 4x4
    Spot on. Good on ya, mate.
  2. Jul 30, 2022 at 8:17 PM
    #92
    Not to be a dick, but I have no filter right now due to lack of sleep, but it sounds like you don't actually check your payload on your truck. Especially telling a guy with a 5th wheel to nose load his trailer.
  3. Jul 30, 2022 at 9:18 PM
    #93
    This is an interesting chat. One can tell who has/hasn't towed with something better vs a maxed out truck.
    This is the trailer, and we know the truck:
    Pin weight is 1510 or 19%. In the event he even puts half of the cargo weight in of 1050 lbs, his pin weight will be 1700 lbs.
    Now we need to add the 158 lbs for his hitch. Now we are at 1857 lbs pin weight. Just a tad over....
    What does this all mean? Upgraded tires...check. Upgraded suspension...check. What's to worry? I may have missed it, but has anyone even talked about rear axle rating (which is 4150 lbs btw). So what do you think an empty Tundra will weigh on a scale with the rear axle on the scale? Wonder why the Tundra has a low payload rating with the 10.5" rear axle? Could it be due to strength? Things I ponder....
    The truck in question:
    2019 Tundra CM. From other posts on here, his payload is probably between 1200-1270 lbs. So he is over by almost 600 lbs before he even gets inside the vehicle. Only he knows his/whomever else is in the vehicle weight. We can just say 350 lbs will be inside the cab. Almost 1000 lbs over payload and only he will know how much over the rear axle.
    I always enjoy the story's of "back in the day" to validate what they are doing now. DOT/OSHA/SAE and other guidelines are written in blood. There is actually a reason because somewhere "back in the day" some dumbass hurt or killed themselves. It's just that simple. I have owned a 1985 GMC 1500 and there is no way in hell that truck would even compare to the current 3rd or 2nd gen Tundra (Hell, maybe even the 1st gen). I would love to see a production 1980's anything out perform its counterpart from today.
  4. Jul 30, 2022 at 9:23 PM
    #94
    Trouble is, those that wish to ignore it will use this exact info in a backwards way. "Yeah, see! The old stuff did it and now these new ones are even better, so we can do even more stuff over the limits and it'll all be fine!" When somebody wants to do something badly enough, they're gonna do it and justify it however they need to.
  5. Jul 30, 2022 at 9:28 PM
    #95
    I agree. It wasn't or ever has been better "back in the day"...most likely slower, white knuckle, 4 mpg, etc.
    I really enjoyed my Tundra, but it had to go. I lived in TN in the early 90's and last month spent a couple weeks on the eastern side. People might be able to get away with it there due to all the flat land towning. Here? No way in hell for the long term.
  6. Jul 30, 2022 at 9:33 PM
    #96
    EmergencyMaximum
    EmergencyMaximum New Member
    I think he knows what he's doing..:notsure:
  7. Jul 30, 2022 at 9:34 PM
    #97
    Totally agree. Hell, go back to when I was first on here and I was looking at a travel trailer, then a toy hauler, and all that. You, specifically, and the forum in general taught me a ton and I recognized the same things you did. The Tundra is NOT built for this. I just went the other direction and tailored my stuff to my truck., while you tailored your truck to your stuff. Both are perfectly good ways to do it, and I'd prefer either to white-knuckling it with a trailer around a bend, taking out 427 mailboxes and narrowly avoiding a drop in the Marianas trench.
  8. Jul 30, 2022 at 9:54 PM
    #98
    landphil
    Phil
    BC, Canada
    ‘08 TRD doublecab
    I know what he’s doing too, that doesn’t make it the right thing to do.
  9. Jul 30, 2022 at 10:33 PM
    #99
    I’m glad he has experience. Truly do.
    He’s not the only one that has a class A CDL with some miles under his belt. Driving a Class 8 truck with 80k lbs combined is a much different experience than a 1/2 ton truck at 16k (or more). Have I ever been overweight in a commercial truck? Everyday. Hell, I was 2500 lbs over on some trucks before the weight was even added and the reason I had overweight slips so I didn’t get fined all the time. I got popped once (cheap), but I made damn sure it was in my tin after my morning pre-trip inspection.
    If any of you ever get a chance to tow with something like this or larger, it will open your eyes to a whole different world.
  10. Jul 30, 2022 at 10:47 PM
    #100
    When Toyota makes one for the States, I'm down. :spending::spending::spending:
  11. Jul 31, 2022 at 12:12 AM
    #101
    Tripleconpanna
    2021 TRD PRO CM; 2008 SR5 CM
  12. Jul 31, 2022 at 12:15 AM
    #102
    Tripleconpanna
  13. Jul 31, 2022 at 12:18 AM
    #103
    Tripleconpanna
  14. Jul 31, 2022 at 12:31 AM
    #104
    Samoan Thor
    Samoan Thor God is technically an alien
    Limited 2014 crewmax 4X4
    Kings F&R, no sway bars
    It doesn’t doesn’t matter how many years and experience you have OP because clearly all those times you have done it stupidly. You are over your payload, a friggin 6 year old can read the manual and I would hope slap you in the face and say you’re overloaded dumbass don’t bring your “the truck can do it” bullshit here. Every thing you add to the truck takes away from payload yes even the upgrades to make it tow better, I’m from an island never towed before only been 3 years towing a travel trailer and I know you’re overloaded.
  15. Jul 31, 2022 at 12:40 AM
    #105
    Way to move the goal post. That post was to illustrate the absurdity of your assertion that posting a pic of a truck and trailer means that you own it. Had someone decided to troll they could have easily done what I did and googled pics of Tundras with 5th wheels.
    But for "my side of the debate" let's follow your logic. A pic of it means it must be the right way to do it. So using that ridiculous lens please enjoy these pictures that "prove" you need a full blown tractor trailer to tow a 5th wheel trailer. FFS, now I know who the troll actually is.
  16. Jul 31, 2022 at 12:57 AM
    #106
    Tripleconpanna
    F450 pulling more than it's rated for! Truck and trailer are coming down Hwy 50 out of Tahoe into Carson City...
    Brakes are smoked at the bottom of the hill... and this truck has engine braking!!!!
    same rig gets to the intersection at the bottom of the hill and can't stop for the red light and slams into traffic!! The first vehicle hit is a GMC truck both occupants, husband and wife were killed...
    As the tow vehicle and trailer run through and over vehicles that are rightfully in the intersection, one vehicle bursts into flames...
    ...the driver of this vehicle was in critical condition!
    Investigation determined that the load exceeded "max weight limits"...
    For those that don't think "the little stickers" matter; they do!
    For those that don't think exceeding GVWR, payload, etc. is negligent; it is!
    For those that don't think investigative teams won't weigh your shit; they will!
    For those that don't think they can be charged criminally for negligence; you're wrong!
    For those that are unfamiliar with charges such as manslaughter, negligence resulting in death, negligent homicide, etc... These types of felonies don't require pre-meditation or criminal intent. Generally speaking, it's simply a willful and wanton disregard for the safety and well being of another human being(s) resulting in that person(s) death.
    By the way, the driver of the truck depicted above was in fact arrested and charged with multiple felonies in connection with the collision.
  17. Jul 31, 2022 at 1:56 AM
    #107
    I don't think I can give that a like, but it's a solid representation of why I try not to be cavalier about the recommendations and ratings from the people who built the truck. Even if I think they are being extra conservative and erring on the side of safety... WTF is wrong with that? Trying to be safe? How does that make you the dick in the conversation?
    I don't point out the bad idea because I get a kick out of shooting down people's good times, though that's a nice bonus. The purpose is to see if they have thought about what they are doing and if they are really willing to take on the personal responsibility for their actions. It's not just you on the road.
    The guy in the pics you have here... he gets to live with the fact that he hurt people. Compared to the flat out knowledge that your actions ended peoples lives and left families grieving, is prison even that big a deal? Are we so self centered as a society and obsessed with "Bigger!" and "MORE!" that we don't even think about what might happen to other people?
    You don't wanna wear your seatbelt and you're the only one in your car, fine. Go for it, but if you have a passenger you are putting their life in danger by not wearing it. EMT I worked with taught a defensive/safe driving class, and to drive home seatbelts for people to do it in their personal life and have others do it to, he shared his experience of working a single vehicle accident off of I-80.
    The vehicle was a 3 row SUV like a Tahoe or a Suburban with 6 or 7 people in it. The driver wasn't paying attention, overcorrected and crashed in the median near an exit. The only person who died in that accident was the girl who was wearing her seatbelt in the front passenger seat. She was the only one in the vehicle wearing a seatbelt. Do you know what killed her? It wasn't the seatbelt. It was the right shoulder of the guy in the very back left of the SUV because he was launched like missile through the vehicle and his shoulder caved in the back of her skull. If he hadn't decided that he didn't need a seat belt, that wouldn't have been a fatal accident. It would have been a bumps and bruises, everybody walked away from it, happy ending. Do you really think he even remotely thought he was putting anyone but himself in danger? Hell no, but that didn't make her any less dead.
    Just stop and think about somebody else for just a second once in a while.
  18. Jul 31, 2022 at 3:20 AM
    #108
    Tundy4x4Dude
    Tundy4x4Dude Backroad Bandit Buster
    '14 SR5 TRD 4x4 Double Cab 6.5' bed
    Payload capacity is close to 2k. A trailer that size has a tounge weight of around 800 lbs to 1k depending how it's loaded... And I said to not load to tail heavy... that doesn't mean you should load the crap out of the nose... Not my fault everyone is underestimating this truck and forgetting it's not a dang TACO :thumbsup:
  19. Jul 31, 2022 at 3:36 AM
    #109
    No, the payload of a 2019 Limited CrewMax is NOT near 2000 lbs. That is 100% false. With the optimistic marketing the highest rating a 4x4 Limited CrewMax 1530 lbs. Claiming 2000 lbs is an exaggeration of 30%. If your boss tells you they'll pay you "Close to" $100 per hour but your paycheck only shows up with $75 per hour rate, how easily are you gonna let that slide? Pop up to post #98 on this page and doublecheck that trailers hitch weight again. https://www.tundras.com/threads/tundras-were-built-for-this.110751/page-4#post-2859937 What's it say? Oh. More than double the 800 lbs low ball you suggest and 50% more than the 1,000 lbs you figure is high end. That's the dry weight. You are grossly underestimating the trailer's weight while over estimating the trucks ratings. Not my fault you think this truck is a 3/4 ton HD truck, because it isn't.
  20. Jul 31, 2022 at 3:51 AM
    #110
    Tundy4x4Dude
    @GODZILLA LOOK! Another guy with a crewmax complaining about PAYLOAD :D Sorry not all of us got crew cabs haha! I knew someone was going to have to come back with the " N0o0o0 the truck is n0t capable!!" response... instead of using logic to realize that the tounge weight should NOT be 20 PERCENT of the weight of the trailer??? like come on man... TIRED of people on this thread who don't even think before commenting and who think this is a TACO rock crawler that can't haul anything. Upgrade your tires and get to work.
  21. Jul 31, 2022 at 3:54 AM
    #111
    This is about the OP's truck which is a crewmax limited. Also, this isn't a bumper pull, it's a 5th wheel so it's a completely different animal for weight. It is absolutely going to be 20% pin weight because it's NOT a bumper pull trailer. FFS, go read the thread before you spout off about people not thinking.
  22. Jul 31, 2022 at 5:46 AM
    #112
    EmergencyMaximum
    I don't think anyone here is going to admit that it is wrong pulling 5th wheel that size with tundra. Nature of the internet is running its course. Best to save strength..
    GODZILLA and Cpl_Punishment like this.
  23. Jul 31, 2022 at 6:15 AM
    #113
    Cpl_Punishment
    Neil
    2020 MGM SR5 CM 4X4
    On a 2nd Gen Tundra? In what universe?
    Outbound, akmerle, Medic343 and 4 others like this.
  24. Jul 31, 2022 at 6:29 AM
    #114
    EmergencyMaximum
    My 2010 DC LB
    4.6 4x2 tow pkg
    1325 lbs
  25. Jul 31, 2022 at 6:35 AM
    #115
    TundraMcGov.
    Jofus
    Burpinham, Babalama
    2015 MGM Limited 2x4 Sequoia
    Fo Sho. My beer and whiskey days closed out almost 6 years ago. Its Diet Pepsi for me. I'm on the south side of the city proper (Hoover). PM me.
  26. Jul 31, 2022 at 6:44 AM
    #116
    Retired...finally
    But you didn't account for inflation! My payload increased by at least 9% since I bought the truck last September. :rolleyes:
  27. Jul 31, 2022 at 7:49 AM
    #117
    Lake.Life24
    Lake.Life24 New Member
    Shawn
    Upstate, NY
    2021 GMC Sierra 3500HD Gasser
    Exactly! If the trucks from back in the day were so beastly then why are trucks constantly getting more ridged and powerful? Oh maybe because people realized having to white knuckle 10k lbs and pray the drum brakes hold up, is absolutely zero fun and a liability. We maybe be spoiled today, but I actually enjoying towing now that the truck doesn’t struggle and get pushed around the road.
    People can do what they want, but to say the tundra is built for a 5th wheel is wrong. Case in point the removal of the transmission cooler :rofl:
  28. Jul 31, 2022 at 8:06 AM
    #118
    Retired...finally
    We can always increase our payload by using lighter weight oils, can't we?:crapstorm:
  29. Jul 31, 2022 at 8:16 AM
    #119
    landphil
    Phil
    BC, Canada
    ‘08 TRD doublecab
    Or putting 28 lbs of air in the tires, instead of 38 lbs. Don’t forget the spare for more weight savings.
    Swap out the 16 lb rad cap for a 10 lb. Heck, we’ve added up to 56 lbs already.
    :rolleyes:
  30. Jul 31, 2022 at 8:26 AM
    #120
    This made me smile. :hattip:
