Overheating at idle
Discussion in '1st Gen Tundras (2000-2006)' started by The tundy, Sep 10, 2018.
  1. Aug 11, 2019 at 7:45 AM
    bajaphile
    bajaphile New Member
    Solana Beach, Ca
    2001 4x4 Limited
    Icon Coilovers, Icon AALs, JBA headers, 285/75r16 BFG KO2s
    Does your fan clutch "roar" at startup? Once warmed up I would park the truck and verify the fan clutch is really pulling air.
    I had this exact same problem on my Land Cruiser, which is somewhat common. You can actually open up the fan clutch and drain out the silicone oil, then replace it with heavier stuff (RC truck differential oil). It made a world of difference, cheap and easy to do. I would personally verify the fan clutch is working before messing around with an electric fan.
    TX-TRD1stGEN likes this.
  2. Aug 11, 2019 at 11:06 AM
    JessiJane06Tundra
    JessiJane06Tundra New Member
    Jessica
    San Antonio
    06 Tundra crew cab
    Small lift
    @Tundyfundy mine acted exactly the same was a pinhole leak in the radiator. Replaced radiator, hoses and thermostat and runs like a champ.
    Tundyfundy likes this.
  3. Aug 11, 2019 at 11:27 AM
    Ajkkane
    Ajkkane Old fart.
    Nj
    2014 CM SR5
    Exhaust Dirty Deeds 8”SS, some led lights, Osram headlights, Pro Stop brakes, Pop Lock, AFE dry air filter with charcoal delete.
    I had one time where the impeller slipped on the shaft of the water pump. You wont know unless you remove the pump. Hope this helps.
  4. Jul 29, 2022 at 1:11 PM
    Christhekey
    Christhekey New Member
    2001 silver tundra 4wd 4.7 v8
    Cold air intake
    Just a little fix I have done recently and it worked for me, try adding a cooling fan to the front of your ac cooler, I wired mine up to a switch in the truck and I turn it on when I’m idling or in slow traffic and I have no overheating issues, the ac blows cold for a lot longer now to.
  5. Jul 30, 2022 at 5:31 PM
    Interesting. I must experiment.
    gascap likes this.
