TPMS Module location
Discussion in '1st Gen Tundras (2000-2006)' started by knicmark, Jul 29, 2022.
  1. Jul 29, 2022 at 5:39 PM
    knicmark
    knicmark [OP] New Member
    I have a 2006 Tundra and am needing to modify the TPMS to stop the indicator light from flashing. It is a 4 door cab. Can't anybody help me?
  2. Jul 29, 2022 at 6:49 PM
    Solid TPMS light in dash = low tire pressure in one tire.
    Flashing TPMS light in dash = failure to communicate with a sensor in one or more tires.
    You'll need to figure out which tire has a dead sensor. Probably the battery on the sensor failed. Most people go to a tire store to sniff which one is not transmitting, then have them swap it out. Not only does the sensor need to be replaced, but the truck needs to be programmed to recognize it. Tire store will have tools to do the job.
  3. Jul 29, 2022 at 7:57 PM
    NickB_01TRD
    KY
    01 Tundra V8 4X4 AC SR5 TRD
  4. Jul 29, 2022 at 9:34 PM
    jerryallday
    jerryallday New Member
    Jerry
    Pasadena, Ca
    2006 DC SR5 V8 Grey
    I replaced my tpms sensors with Denso brand. You need to do all 4 + the spare ($34 a pc).
  5. Jul 30, 2022 at 2:20 AM
    w666
    w666 D. None of the above
    Maryland
    04 Access Cab SR5 V8 4WD
    I managed to get by ~ 50 years of driving without a TPMS...pull the bulb.
  6. Jul 30, 2022 at 6:05 AM
    knicmark
    I know all about what the TPMS does. I know about grounding one of the wires. I know about supplying a 5V signal to the ECU to make it think all is good. Knowing all of that does not tell me where the TPMS Module is located. That is what I would like to know. Where can I find the TPMS Module on a 2006 Toyota Tundra? Mind you this is a 2006 Tundra. I DO NOT need the TPMS and I do not need to spend the money to fix the TPMS. I just want to bypass the TPMS. Can anybody show me where the TPMS Module is located and how to access it?
  7. Jul 30, 2022 at 6:25 AM
    BubbaW
    Bubba
    Where Eagles Nest
    04 DC LTD 4X4 4.7 V8
    T150 Lover
    The 06 TPMS RX is located in the roof and removing headliner is how you would access it.
    from 06 FSM....
    from 06 FSM....
    edit....
    tunyota and FrenchToasty like this.
  8. Jul 30, 2022 at 6:45 AM
    landphil
    Phil
    BC, Canada
    ‘08 TRD doublecab
    If you remove the glovebox, you can find the TPMS ECU (not the receiver) to the left toward the head unit and above the HVAC controls. Access is a bit tight, but I was able to get to the connector and do what needed to be done. The module is labeled. Both were on ‘06 models as well.
