  1. Jul 25, 2022 at 11:19 AM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
  2. Jul 25, 2022 at 2:49 PM
    Holy shit, I did sumin'
    Picked up the $50 AutoWIKI aka AutoFREE aka WinJET yellow fog lights off scAmazon before I headed to the farm for the weekend. I have some commentary on the kit they sent, but maybe for another time. I also have a huge spare foglight harness up for grabs (check next reply coming after this).
    The lenses look identical to OEM, but I can't tell how they're glued on, so not sure how easy it would be to retrofit/recap their lenses onto OEM. My OEM were so hazed, I need to take some time to polish them out and re-clear anyway.
    Fitment was "OK". Not horrible, not great. The adjuster seems really like the weak point on these. I dunno if they'll last.
    Here are three pics, one before, two after (off and on). I measured the adjuster on OEM and aftermarket to pre-dial-in the height. I still need to adjust the fogs and headlights.
    abcinv, Voss, Kimosabe and 4 others like this.
  3. Jul 25, 2022 at 2:52 PM
    alb1k
    Left Coast
    05 2WD DC w/ attitude
    It's good
    Fit the MACs tire strap and decided on a trip location for the jack. Minor rehab on some camp knives.
    09153DE3-FC69-4773-91F0-AAF4A916F218.jpg 4EC8258E-7B88-4013-8BCC-D93D76197C8F.jpg C8AA0898-E92B-4CDB-A412-C50C3D8F0F5F.jpg
    Voss, RUSTYNUTS, oscardog86 and 5 others like this.
  4. Jul 25, 2022 at 2:55 PM
    alb1k
    Left Coast
    It's good
    Looks pretty slick. Might be a huge score if they hold. I would try those.
    shifty`[QUOTED] likes this.
  5. Jul 25, 2022 at 2:55 PM
    And to that point, after my install, I have this spare harness for fogs. Pay shipping and it's yours. Please claim dibs here and I'll PM you on it.
    Note: The switch is vertical, not slanted. I dunno how that'll work for some people. I took lots of pics of the switch. The relay is 20¢ garbage, I'd replace if I used it.
    RUSTYNUTS and oscardog86 like this.
  6. Jul 25, 2022 at 2:57 PM
    alb1k
    Left Coast
    It's good
    If I wasn't set for wiring I would jump on that in a second. The baja harnesses I had were good for like 3 projects.
    oscardog86 likes this.
  7. Jul 25, 2022 at 3:01 PM
    Someone is bound to want it, a little pay-it-forward. I'd prefer it goes to someone who checks this thread, I'm not putting it in the marketplace.
  8. Jul 25, 2022 at 3:50 PM
    KK6PD
    KK6PD 2 1 yr. retired . . . after 42 yrs
    ROAD
    Upper Los Angeles Foothills
    2003 AC Tundra . . . . 7th owner
    New Tires, Stereo & Speakers,Uni-Strut Tie Down Continue watching THIS SPACE FOR FUTURE DEVELOPMENTS
    Hey Shifty, I could this! Working on the fogs in my truck, need a switch, this looks perfect.
    Still got this? If so how much you need???
    Thanks KK6PD
  9. Jul 25, 2022 at 3:56 PM
    alb1k
    Left Coast
    It's good
    I imagine you just scored. @shifty` pays it forward, so shipping, but don't quote me o_O. It may be $50 + shipping.
  10. Jul 25, 2022 at 4:56 PM
    It's all yours, I'll PM to get address and see if you want the whole harness or not.
    @alb1k is paying for shipping, whether he realizes it or not :rofl:
    KK6PD[QUOTED] likes this.
  11. Jul 25, 2022 at 5:07 PM
    alb1k
    Left Coast
    It's good
    Better use pirate ship, or whatever it's called today!
  12. Jul 25, 2022 at 5:10 PM
    alb1k
    Left Coast
    It's good
    Yea - use it!
  13. Jul 25, 2022 at 5:45 PM
    NUDRAT
    NUDRAT 6 lug life
    SW CT
    Between 'Ridgelines'
    @Darkness approved.
    RUSTYNUTS, KNABORES and alb1k like this.
  14. Jul 25, 2022 at 6:26 PM
    Made some money! The local watering hole is usually good for a side job or two, newer unit that the condenser got clogged with lint, which then raises pressures and temps internally that sooner or later caused the filter drier to become restricted(I believe)
    Cut the cap tube back, burned in the new filter and the cap tube end………. They don’t make them like they used to….. I started to burn the 1/4” side and was aiming straight down due to wires and rubber in board, and a rubber mat outboard. I soon found out the base was made of plastic! 37AF8A33-9D1C-47EC-9C55-75AABF0425F0.jpg1A80A14C-03D6-464D-9526-26BD2916A3F4.jpgimage.jpg
    MS22, KK6PD, RUSTYNUTS and 3 others like this.
  15. Jul 25, 2022 at 6:38 PM
    scooterprint
    scooterprint Idiot with a wrench
    Jeremy
    Conway, AR
    ‘04 DC 4x4
    This is gonna look great with some bigger tires and different wheels. It definitely skipped leg day this time around. P.S. Be ready to cut and hammer my friend because unless you have the perfect setup, you're gonna rub somewhere.
  16. Jul 25, 2022 at 7:06 PM
    This is actually more often a problem with DC than it is AC or RC. Plenty of AC and RC drivers have gone with very basic lifts, 2.5" and less, and had zero rubbing with 275/70, and 285/80 with no rubbing, except sometimes a small frame rub in reverse at full lock.
    The DC is just a different beast.
  17. Jul 25, 2022 at 8:51 PM
    TravisJr
    TravisJr New Member
    2001 AC SR5 4WD, 2010 DC SR5 4WD
    Lots o’ mods
    We will see. It’s definitely going to be close. I did a lot of research into backspace and offset - hopefully I found a good combo.
    Hoping for an update tomorrow.
  18. Jul 26, 2022 at 6:17 AM
    daveeasa
    Today I will attempt to un-F my headlights. First with an aftermarket switch for low beams. And some work on the ball and socket joint on the passenger side. Which may turn into a take home project.
    Tentatively hoping to move it out of state in a week if it’s ready enough to be safe to drive.
  19. Jul 26, 2022 at 6:40 AM
    Casper421
    In the woods
    06 DC
    Received an email that the backordered Nitro 4.88 gears will be in stock Friday and hopefully in hand in a week or two. Order placed 11/22/21 :frusty:
  20. Jul 26, 2022 at 6:48 AM
    des2mtn
    SW
    2004 Black DC Limited 4x4
    Tonto cover
    Two months to go, the clock is ticking!
  21. Jul 26, 2022 at 6:49 AM
    I’ll have nothing new done by then, maybe I’ll wash it……
    RUSTYNUTS and des2mtn[QUOTED] like this.
  22. Jul 26, 2022 at 7:04 AM
    Casper421
    In the woods
    06 DC
    Gears, rear arb, CSF rad, tb/wp and tire clearance…I’ll stay busy! Thankfully it’ll only be high 90’s for the next 2+ months, perfect wrenching weather! :bananadead:
    Voss, 5N0W808, RUSTYNUTS and 2 others like this.
  23. Jul 26, 2022 at 7:06 AM
    oscardog86
    oscardog86 New Member
    Southern California
    What tire size are you trying to fit? Ill be watching vicariously through you as i wanna do something similar on mine in the next year or so. 4:88 gears, 33s, rear locker and probably new suspension by then.
    RUSTYNUTS likes this.
  24. Jul 26, 2022 at 7:09 AM
    Casper421
    In the woods
    06 DC
    35x12.5r17
  25. Jul 26, 2022 at 7:14 AM
    des2mtn
    SW
    Tonto cover
    Treat yourself and put a little gas in it too
    5N0W808, NUDRAT, RUSTYNUTS and 3 others like this.
  26. Jul 26, 2022 at 7:30 AM
    Gas is down to $3.70 ish outside of town and around $4.20 near my house! I don't get the huge swings from place to place. I think gas stations are gouging us.
  27. Jul 26, 2022 at 7:49 AM
    oscardog86
    Southern California
    Just paid $5.50 per gallon yesterday and thought that was a good deal! California and their stupid taxes
    Voss, des2mtn and RUSTYNUTS like this.
  28. Jul 26, 2022 at 9:00 AM
    snoope
    snoope The Old Man
    I drove it :burnrubber:
    And made the appointment to get windows "tinted":cool: with Ceramic ; following advice of others :thumbsup:...
    It will be a bit as Wifes surgery trumped everything :monocle: But that is now into PT mode...
    Until then, the Corolla racks up the miles..:hattip:
    5N0W808 and NUDRAT like this.
  29. Jul 26, 2022 at 9:10 AM
    RUSTYNUTS
    Rusty
    sOCal
    to be continued...
    Cocktail? wuts innayer?
    Any first gen trying to fit 33's or 35's are going to have clearance issues. Spacers will keep you off the frame, but there's no escaping that rub near the body mount at the rear of the tire without some persuasive bodywork by hammer and grinder (says the guy with an AC on 35" tires)
    ^This guy gets it
    Also should be mentioned that a slight rub at ride height in a parking lot, can be a rough chomp-chomp when you go 'full stuff' and test out your bumpstops
    Shoulda bought mine a couple months ago when i offered:notsure: Motive 4.88's..
  30. Jul 26, 2022 at 9:17 AM
    RUSTYNUTS
    Rusty
    sOCal
    to be continued...
    Voss, 5N0W808 and alb1k like this.
