POTENTIAL 5TH WHEEL PURCHASE
Discussion in 'Towing & Hauling' started by dukeofURL, Jul 24, 2021.
  1. Jul 25, 2021 at 1:59 PM
    #61
    rockmup
    rockmup New Member
    Todd
    Greenwell Springs LA.
    Kings, 5:29's, E-lockers on 37's
    Don't need to look it up, if you say it it is, it probably is. Didn't know a DC had a longer bed
  2. Jul 25, 2021 at 2:19 PM
    #62
    Catmann1972
    Catmann1972 New Member
    Greg
    Rhode Island
    2020 TRD Sport
    http://towcalculator.com/
    OP...I suggest you input your weights of your truck and your wouldbe 5th wheel trailer into the above towcalculator web site and see what you get. I am 100% positive that the calculator will tell you that it can not be done with the weights of the Tundra. Trust me, I did the calculations using the lightest and smallest 5th wheel weights and the calculator told me it was not safe. So please, look over the calculator figures and do what is right to keep yourself, your family and everyone else on the road safe.
    Cpl_Punishment likes this.
  3. Jul 25, 2021 at 2:24 PM
    #63
    Catmann1972
    Greg
    Rhode Island
    2020 TRD Sport
    here is something else for you to review.
    https://www.savagecamper.com/lightweight-fifth-wheel-camper-options-half-ton-trucks/
    dukeofURL[QUOTED][OP] likes this.
  4. Jul 25, 2021 at 2:36 PM
    #64
  5. Jul 25, 2021 at 2:41 PM
    #65
    Cpl_Punishment
    Neil
    2020 MGM SR5 CM 4X4
    Far too many...
    Booney, Oey12, Terndrerrr and 2 others like this.
  6. Jul 25, 2021 at 4:06 PM
    #66
    Same wheel base.....
  7. Jul 25, 2021 at 4:29 PM
    #67
    JCBerb
    JCBerb Semper Fi
    Joel
    2017 CM LImited
    C4 Overland bumper, BD SAE fogs, Leitner Designs Rack, Rago Bed Channel Stiffiners, Warn Xeon 12S Plarinum, Bedslide, Front Runner Roof Rack, roof rack solar panels, RCI Full under carriage aluminum studs, RCI rear diff skid, Rago dash plate, Rago accessory panels, OEM LED headlights with wiring harness.
    I purchased a 2005 Sandpiper Sport 26 foot toy hauler. This thing dry weighs more than a modern unit of comparable size does loaded. Bought it from a family friend for near nothing. in hindsight, I should have not gotten such a heavy unit, or should have gotten a bigger truck. I am somewhere around 100-200 pounds over when I am all set up. I ended up getting a Propride hitch to make towing more controlled.
    rockmup likes this.
  8. Jul 25, 2021 at 7:38 PM
    #68
    rockmup
    rockmup New Member
    Todd
    Yeh I got that when someone said the bed was 1' longer on the DC. Learn something new everyday.
  9. Jul 24, 2022 at 9:53 PM
    #69
    Joe333x
    Joe333x Member
    Boston
    2019 Tundra CrewMax Platinum
    How do you like the Propride hitch? It looks super cool but is it work the cost?
  10. Jul 24, 2022 at 10:54 PM
    #70
    JCBerb
    JCBerb Semper Fi
    Joel
    2017 CM LImited
    I’ve had it over two years and have used it countless times. Can assure you it is worth it. At first I thought all the hype was nonsense and wanted to find out for myself. It surely allows you tow at the upper limits of the Tundra and not feel sway anywhere near as much. Its just an all around well grounded feeling. If you set it you set it up right, the weight distribution is great. I find hitching and unhitching is easier. Another thing is customer service, they respond quickly and don’t bullshit you. I needed a replacement for something I misplaced and it was at my door within a week at no cost to me. Plus the folks will take the time to answer all your questions.
    I still have mine after selling my toy hauler. I set it up on my 18ft enclosed trailer because I didn’t want to have it laying around. So if your in the market for one and are close to Grass Valley CA come take a look and I’ll sell it to ya.
    Joe333x[QUOTED] likes this.
  11. Jul 24, 2022 at 10:58 PM
    #71
    Joe333x
    Joe333x Member
    Boston
    Thanks! I don't even own a trailer yet but am looking at a camper at some point and seen an ad for the ProPride and watched as many videos I could find on it afterwards since I couldn't tell if it was a gimmick or actually as amazing as they make it out to be. Havent been able to find a single bad review though. I'm in Mass, but thanks for the offer!
  12. Jul 24, 2022 at 11:09 PM
    #72
    JCBerb
    JCBerb Semper Fi
    Joel
    2017 CM LImited
    No worries I can send you videos or pictures to help you out just let me know. This thing is pricey for sure. Oh yea a similar one is called the Hensley Hitch. The ProPride is an improved version derived from that. Apparently the guy from ProPride worked with Hensley and then went on his own making ProPride (something along those lines).
    How big are you looking. In my case I had 6900lbs dry. By the time I added 100gal of water, food, and gear…I was over payload with no passengers just me.
  13. Jul 24, 2022 at 11:15 PM
    #73
    Joe333x
    Joe333x Member
    Boston
    Honestly probably not that big because its just me and my dogs and I'd like to be able to use it in to boondock in the winter for ski trips. I've only towed a trailer once but it was a friends boat. So I'm just doing all my research now so I know exactly what Im getting into and what I want.
    JCBerb[QUOTED] likes this.
