Timing belt necessary at 35K miles for a 2004?
Discussion in '1st Gen Tundras (2000-2006)' started by gaitken, Jun 25, 2022.
  1. Jun 27, 2022 at 9:11 AM
    BubbaW
    Bubba
    Where Eagles Nest
    04 DC LTD 4X4 4.7 V8
    T150 Lover
    Yeah, that’s why I used “knew”, past tense….sad indeed. He definetely knew his Hunter equip, I suppose it’s because he help design it !
    shifty` and YardBird[QUOTED] like this.
  2. Jun 27, 2022 at 9:19 AM
    YardBird
    YardBird Native San Diegan
    Jonesy
    2005 RCLB
    DJ was an ACE ~ he definitely "knew" his stuff . . . and sadly, past tense.
    The guy had pretty much seen it all . . .
    He had a gift of being able to explain it to me so that I could understand it as well.
    shifty` and BubbaW[QUOTED] like this.
  3. Jun 27, 2022 at 4:10 PM
    abcinv
    abcinv OEM (+) Junkie
    Tommy
    NW Georgia
    Toyota Tundra Timing Belt Or Chain
    Model Years Engine Option Timing Belt Or Chain Interference Or Non-Interference
    2007 - 2021
    5.7L timing chain interference
    2010 - 2019 4.6L timing chain interference
    2005 - 2014 4.0L timing chain interference
    2000 - 2009 4.7L timing belt interference
    2000 - 2004 3.4L timing belt non-interference
    shifty` likes this.
  4. Jun 27, 2022 at 5:09 PM
    I feel like this needs to be someone's signature or something ^^
    abcinv[QUOTED] likes this.
  5. Jun 28, 2022 at 8:12 AM
    gaitken
    gaitken [OP] New Member
    Greg
    2004 Tundra SR5
    Ok, it's settled, I'll get it replaced. Love the truck and want to keep it forever... BTW, anybody know what the spec is for #hrs service labor required to change a timing belt? The quotes I'm getting are all over the place...
  6. Jun 28, 2022 at 8:48 AM
    I think I saw someone here say 4-5 hours?
    We've had chatter about this before, ow wild the pricing is. Some guys are getting it done at qualified shops as low as $750 with OEM (either Aisin or Denso) parts, including water pump and tensioners. We talked about this a little bit over here.
    As you may see, I personally got quoted north of $2200 from my local stealership. But a lot of guys seem to be coming in between $900 - $1600 depending on who they ask and whether they're using OEM parts. Stealership will always be more, most of them over here concatenate hours on service and charge premium on the parts.
  7. Jun 28, 2022 at 9:08 AM
    sn_85
    sn_85 New Member
    Boise
    2006 DC Tundra 4WD, 2013 Land Cruiser, 2022 RAM 2500 Bighorn
    Mine was ~$1200 at a Toyota specialist in town. I thought it was a fair price.
    YardBird and shifty`[QUOTED] like this.
  8. Jun 28, 2022 at 11:08 AM
    Mr Badwrench
    Mr Badwrench New Member
    If everything were not so horrifically expensive now, I'd say, just do it, but this is a pretty pricey replacement.
    Pull your cover back and take thorough look at it then decide. If you have the bread to do it, then go for it.
  9. Jun 28, 2022 at 12:06 PM
    remington351
    remington351 New Member
    2006 SR5 DoubleCab
    FirstGen has a good suggestion. The pink milkshake of death is no fun either.
    shifty` likes this.
  10. Jun 28, 2022 at 12:06 PM
    Even if it costs $2,000, some dealerships right now are adding $10,000 "market value adjustments" to new vehicles due to "supply chain issues". That's not even the cost of the vehicle, just an arbitrary markup. :rofl:
    It's worth every penny to do the maintenance.
    snoope and KNABORES like this.
  11. Jul 23, 2022 at 9:32 PM
    ToyTunTun
    ToyTunTun New Member
    2004 Limited 4x2 Dbl Cab 4.7 L
    First of all, I'm going to say replace it.... Now that I've got that out the way, I was on my original TB on my 2004 4.7L until YESTERDAY at 195,1xx miles. It didn't snap, but I got it replaced along with water pump and tensioner because after planning to trade it in, I finally decided to keep it. Here's a couple photos of this 18 year old TB with over 195K miles on it... Don't yall yell at me too much.
  12. Jul 24, 2022 at 7:57 AM
    Did you own the truck its whole life?
    Only asking because that looks like a Mitsubishi timing belt, not an OEM Denso timing belt. If it were the the case, your words could give people false hope theirs could last for almost 200k miles also, and it's "OK". We know it's remotely possible for one to last that long, but ...
  13. Jul 24, 2022 at 8:15 AM
    ToyTunTun
    Now you've got me confused, because I got it in 2005 with 14K miles on it. Was never mentioned that a TB replacement was done on a one year old truck The biggest job I've had on it since then was axle shaft bearing.
  14. Jul 24, 2022 at 8:18 AM
    Not only that, but it looks really good for a belt that old. It doesn't even look cracked.
  15. Jul 24, 2022 at 8:21 AM
    Sometimes the cracks in the rubber won't show until you zoom in while flexing the belt.
    That belt definitely has a good 80-100k miles on it. It's also possible Mitsubishi was making Denso belts back then, or Denso makes Mitsubishi belts today, or they share a manufacturer (dunno which). I haven't seen a 15-20 year old Denso belt, but I recognized the writing on that one as a Mitsu belt. Took me a few minutes to sanity check it on Google Images.
  16. Jul 24, 2022 at 8:24 AM
    Could be but we've had other members post pictures of their old belts and it was immediately clear it was past its normal lifespan.
  17. Jul 24, 2022 at 8:35 AM
    ToyTunTun
    I had to go out and look at that old belt again, because I was wondering why a barely year old truck at 14K miles would have a TB replaced
    FirstGenVol[QUOTED] and BubbaW like this.
  18. Jul 24, 2022 at 8:49 AM
    empty_lord
    Indiana, Chicagoland
    05 rollover special
    Looks original to me.
    that said I’ve seen belts that look good, fail. That’s why I’ve replaced 3 of these 4.7s at work.
    shifty`, des2mtn, FirstGenVol and 2 others like this.
  19. Jul 24, 2022 at 9:53 AM
    ACE50
    ACE50 New Member
    VA
    2001 Tundra V6
    Well, I'll do a visual check on mine, but that one looks pretty good.
    Seeing as my V6 is a non-interference engine, I'm gonna let it go.
    I don't put that many miles on it anyway now that I retired.
  20. Jul 24, 2022 at 12:52 PM
    #50
    Huh. Maybe they do share a manufacturer. Or I guess it's possible Mitsu is/was making it for Toyota back then, and re-branding.
