Looking for part number
Discussion in '1st Gen Tundras (2000-2006)' started by ryderboy, May 13, 2022.
  1. May 13, 2022 at 2:08 PM
    ryderboy
    ryderboy [OP] New Member
    06 tundra sr5 double cab
    Hi guys, first post here. So to start off I bought my 06 tundra about a month ago and I love it. Probably my favorite truck so far. I sold my 21 Tacoma dclb for this. I had a 19 power stroke previously and for some reason this truck just hits the spot.
    But anyways I have the typical rust issues around the front leaf spring bracket. The frame is doubled up in that area and the actual frame seems to be good but the inner part it rusted out. Hopefully everyone knows the part I’m talking about . I can’t seem to find just that part. I have searched like crazy with no luck. Hopefully someone knows a part number.
    I plan on keeping this truck for awhile. It has 70,000 miles and everything else is like mint condition (besides cv axles). I just want to get ahead of everything before it’s to late. Any help would be appreciated.
  2. May 13, 2022 at 2:11 PM
    Picture would really help. From what you're describing with words, I don't think it's something you can buy separately.
  3. May 13, 2022 at 2:25 PM
    ryderboy
    AFE33FE3-281A-4AA8-BC0F-DC7D8A6382A3.jpg 04D60D50-A827-4904-A0E3-7417BD8C02D3.jpg DF06BA3A-CC22-48B7-9858-59967F99E838.jpg
    shifty` likes this.
  4. May 13, 2022 at 2:27 PM
    ryderboy
    The front leaf spring bracket is bolted though it. I was thinking maybe cut out the bad parts of it and maybe do a 3x5 3/8” angle it there but I don’t want to half ass it either
  5. May 13, 2022 at 3:14 PM
    BubbaW
    Bubba
    Where Eagles Nest
    04 DC LTD 4X4 4.7 V8
    T150 Lover
    We've had a couple of posters that have posted about fillers one can buy but striking out in finding past posts.
    Hard to tell from those pics but in case it helps others, is your issue where the red rectangles are ?
    Sunnier likes this.
  6. May 13, 2022 at 3:26 PM
    ryderboy
    Yes, those look to be about where my problems are. The more I’m thinking about it, I think angle iron would be the way to go. I think it would be stronger, last longer and be easier. Cut out the real bad parts and por-15 the best I can
  7. May 13, 2022 at 3:37 PM
    BubbaW[QUOTED] likes this.
  8. May 13, 2022 at 3:39 PM
  9. May 13, 2022 at 3:53 PM
    ryderboy
    Ahh yes the last link he made his own ( frame stiffeners) that’s what I need. Looks like the only option it to make your own. Like you said before I don’t think you can buy them separately
    Mogo Gogo likes this.
  10. May 13, 2022 at 5:26 PM
    Do check out that AutoCraft or whatever website linked in one or both of those threads, there were lots of brackets to choose from. It's still not clear to me whether or not they have what you need. But yeah, stick around, ping N8, maybe he can give some feedback.
  11. May 13, 2022 at 7:59 PM
    typhoon
    typhoon New Member
    2003 Tundra AC Limited
    I had the same issue. So I removed them and brought em to a welder. Cost me about $500.20210821_070658.jpg20210813_192737.jpg
    Air hammer with a chisel bit worked well on the rivets.
  12. May 14, 2022 at 6:27 AM
    ryderboy
    I like that idea. I thought it would cost a lot more. Did you go with a thicker steel? Hopefully I can find someone who can do it fast so I don’t have much down time
  13. May 14, 2022 at 6:51 AM
    typhoon
    typhoon New Member
    If I remember right, we did 3/16 flanges with 1/4 web. It's a tight squeeze to get everything back in and lined up.
    Yeah, my pictures are out of order, but I removed the rusted section. Which is a frame stiffener. Brought it to the welder, they fabed the new piece shown. Then I bolted it back in.
    Mogo Gogo[QUOTED] likes this.
  14. May 14, 2022 at 7:57 AM
    In a pinch, an angle grinder to grind the head off one side, then a punch (or a punch bit on an air hammer) to knock it out using the side you ground also works well.
    I've had to do similar on frames from a couple of diff't manufacturers to pull of LS swaps. Sometimes getting that chisel bit at the right angle can be a real bitch, grind and punch is the best alternative to it.
    @typhoon it looks like that brace has the framerail sandwiched between it and the leaf perch with a rivet. Curious, did you just use standard grade 8 hardware and poly-locks to button it all back together?
  15. May 14, 2022 at 10:10 AM
    typhoon
    typhoon New Member
    Yeah all grade 8 hardware now, but with the steel top lock nuts.
    shifty`[QUOTED] likes this.
  16. May 14, 2022 at 10:14 AM
    typhoon
    typhoon New Member
    Unfortunately most of my pictures were to just help with reassembly. 20210813_192809.jpg 20210815_175517.jpg
  17. May 14, 2022 at 10:17 AM
    1lowlife
    DADA
    THE GREAT STATE OF TEXAS
    2014 MGM DC SR5
    You guys are hard-core badasses....:eek2:
    I mean that as a compliment....:thumbsup:
  18. May 14, 2022 at 11:48 AM
    typhoon
    typhoon New Member
    Ha ha thanks. Just trying to make sure the ol tundra lasts a bit longer.
    KK6PD and bmf4069 like this.
  19. May 15, 2022 at 6:22 PM
    N84434
    N84434 In the Frozen Tundra
    Milwaukee WI.
    2001 Limited TRD
    w666, typhoon and bmf4069 like this.
  20. May 16, 2022 at 2:08 PM
    ryderboy
    Soon! I’m making templates today. I’m hoping I’ll be done in a few weeks. Hard finding time to rip a truck apart that you need everyday for work.
    N84434[QUOTED] likes this.
  21. Jul 23, 2022 at 10:40 AM
    ryderboy
    So I found some time to do the passenger side. I bought a plate of 3/8 steel and used 1/4” angle for the bottom. I also used 1/2” grade 8 bolts.
    The hardest part was getting the rivets out. I tried just a air chisel but it would not budge them. It ended up being a combination of drilling them out and the air chisel.
    It’s such a good feeling having the one side done. I know for sure it’s way stronger than stock. It is about 6” longer then the original. I’ll grab some pics later tonight when the driveway isn’t 400 degrees
    N84434 likes this.
  22. Jul 23, 2022 at 12:43 PM
    N84434
    Milwaukee WI.
    2001 Limited TRD
    Sounds exactly like what I did!
  23. Jul 23, 2022 at 2:51 PM
    ryderboy
    You’re where I got the inspiration from lol. I’m not a welder so I just bolted mine together. I think it will be plenty strong though
  24. Jul 23, 2022 at 2:55 PM
    ryderboy
    2416B419-397A-4C65-9491-8AAC3AE6F2B0.jpg 6215B5AD-C624-470D-A330-F7C97DFF8293.jpgI couldn’t get it to fit the contour of the frame but I think it good enough.
    N84434 and w666 like this.
  25. Jul 23, 2022 at 2:56 PM
    ryderboy
    The white is just some wd-40 white lithium that I had
  26. Jul 24, 2022 at 3:36 AM
    N84434
    Milwaukee WI.
    2001 Limited TRD
    A different approach, but it should work well.
