TRICKY VIBRATION
Discussion in '2nd Gen Tundras (2007-2013)' started by El Nope-o, Nov 7, 2018.
  1. Nov 7, 2018 at 4:06 PM
    El Nope-o
    El Nope-o [OP] New Member
    2010 Tundra Double Cab
    Mostly Stock
    Ok ya'll, this is giving me a run for my money.
    2010 4.6L 4x4 Tundra Double Cab, 108,000 miles. Daily driver. No check engine lights or DTC's.
    Has a slight vibration/hesitation/stumble feeling that you can feel thru the seat, nothing from the steering wheel.
    Happens at 1,200 - 2,100 RPM's around 55-65MPH, while cruising. Under heavy acceleration nothing abnormal. Under slight easy acceleration it is apparent. Does not happen while coasting (with foot off gas).
    I first thought it was just worn out shocks and changed out the originals for the Bilstein 5100's I had in the garage. Wasn't it. Thought maybe the U-joints may have been going out as they were looking kinda beat up and slinging grease (or what was left of it) so I changed them. No go again.
    Swapped in a new air filter wondering it was starved for air, another loss. Checked rear wheel bearings by lifting truck off ground and trying to wiggle wheel assembly, seems firmly seated, no noises or leaks. Checked rear diff for signs of fluid leakage, all clean.
    Anyone have any ideas?
  2. Nov 7, 2018 at 4:08 PM
    Professional Hand Model
    Fred
    Hand Protectors
    Carrier Bearing?
    15whtrd likes this.
  3. Nov 7, 2018 at 4:26 PM
    El Nope-o
    Mostly Stock
    I looked at it while I had the drive shaft out yesterday doing the u-joints. I did not detect any noises while spinning it, although it flexed about 3/4" to 1".
  4. Nov 8, 2018 at 2:25 PM
    El Nope-o
    Mostly Stock
    It does not appear to be the carrier bearing. I jacked up the truck on all 4 corners, and put it in drive and gassed it. Put my phone under the truck to take a video. It stays nice and centered. Still felt the stumble/ hesitation.
    Checked the transmission mount and it's good. No check engine lights or codes. What else?
  5. Nov 8, 2018 at 2:54 PM
    Atomic City Tundra
    Devin
    New Mexico
    2013 Tundra 5.7FFV CM 4X4
    How do your u-joints look?
  6. Nov 8, 2018 at 3:54 PM
    El Nope-o
    Mostly Stock
    Brand new, just replaced them Tuesday evening.
  7. Nov 8, 2018 at 4:32 PM
    Atomic City Tundra
    Devin
    New Mexico
    Doh! Missed that. Sorry.
  8. Nov 8, 2018 at 5:21 PM
    15whtrd
    15whtrd Mr. Blonde
    Hmm. The only discrepancy, is your test was without load.
  9. Nov 8, 2018 at 5:55 PM
    El Nope-o
    Mostly Stock
    Last weekend I towed a 2000 Malibu across the state. Felt it then too.
  10. Nov 8, 2018 at 7:14 PM
    Hattori
    Hattori STOP SHIMMING COILOVERS!!!!
    Tommy
    Nashville
    2012 Tundra CM TRD
    Me.......
    Could be your pinion angle...
    15whtrd likes this.
  11. Nov 9, 2018 at 2:37 PM
    El Nope-o
    Mostly Stock
    Doubt it, the truck and suspension is stock, leafs are securely in place. Nothing has been changed or modified to induce this.
  12. Nov 9, 2018 at 2:48 PM
    Hattori
    Tommy
    Nashville
    2012 Tundra CM TRD
    Me.......
    But you said you dropped the shaft down right? If anything moved without you 1st measuring the pinion angle before you unbolted it then its more than likely off by a little after re-assembly. Just a thought...
  13. Nov 9, 2018 at 2:49 PM
    15whtrd
    15whtrd Mr. Blonde
    what I was saying is the test up on the jackstands was done with no load on the drivetrain. I’m curious what thecarrier bearing looks like under load. I suspect the carrier bearing is the issue. You said it moved about 3/4 to an 1”
  14. Nov 9, 2018 at 2:54 PM
    TexasTundra27
    TexasTundra27 Moby Dick
    Mark
    2011 Tundra CM 4x4 5.7
    Icon stage 3, Icon billet UCAs, 5.29s, ARB lockers F+R, Coachbuilder +2s and shims, Rago fab ditch light brackets and bed stiffeners, Rago Fabrication sliders, ARE camper, 17x9 XDs and 37/12.5/17 stt pros, DT long tubes, xpipe with dual magnaflows, Full skids, TrailToys front and rear bumpers
    I had a similar issue for a while where I felt some random hesitation and it ended up being my fuel pump cutting out. Only found it by taking it to the dealer and having them plug into it and watch it while driving around.
    Atomic City Tundra likes this.
  15. Nov 9, 2018 at 6:10 PM
    El Nope-o
    Mostly Stock
    It did not appear to move on the video, but while bolted up in place I could move it about 3/4" - 1". I'll see if I can locate a carrier bearing locally and try that. At this point the carrier bearing theory is the only one that makes any sense.
    15whtrd[QUOTED] likes this.
  16. Nov 9, 2018 at 9:44 PM
    landphil
    Phil
    BC, Canada
    ‘08 TRD doublecab
    Still original spark plugs? Light throttle misfiring is a classic symptom of worn plugs. You’ll feel it before it ever thows a fault code too, in my experiences.
    07DCLimited likes this.
  17. Nov 10, 2018 at 5:07 AM
    El Nope-o
    Mostly Stock
    Plugs were changed last year.
    landphil[QUOTED] likes this.
  18. Nov 10, 2018 at 5:12 AM
    El Nope-o
    Mostly Stock
    This was felt before I pulled down the driveshaft. Driveshaft was reinstalled in the same position and the carrier bearing in the same position. Pinion angle would be unaffected.
    15whtrd likes this.
  19. Nov 11, 2018 at 10:10 AM
    lilharv321
    lilharv321 New Member
    My 07 had similar issues at 55 mph and would go away at 75-80, did the carrier bearing and it did nothing. Checked the wheels bearings for wiggle and they had none but it did end up being my front right wheel bearing. Replaced it and everything was good.
    Skew12 and El Nope-o[OP] like this.
  20. Nov 11, 2018 at 12:20 PM
    El Nope-o
    Mostly Stock
    Changed out the carrier bearing out this morning, quick test drive feels good. I'll be able to tell for sure after driving to work tomorrow morning as I'll have the drive time and plenty of speed variations.
  21. Dec 31, 2018 at 6:55 AM
    rebmo
    rebmo 2020 Crewmax Limited 4wd Silver/Black
    Rural SE Wisconsin
    2020 CM LImited 5.7L V8 4WD
    Outside chance but check your parking brake for hang up issues. The mechanism under the drivers side passenger seat hung up on mine and did not fully disengage the parking brake. at 45-50mph the truck would shake at times and dealer could not figure it out (extended warranty). I felt the rear wheels and the drivers rear was hot. I cleaned and lubed the parking brake linkage and the problem went away. It came back after the first winter (after fixing) and cleaned and lubed the mechanism again and problem gone. I now coat it good with fluid film along with the underside of the truck prior to each winter and have not had any issues. The shaking felt like a bad wheel or driveshaft but could not feel through brakes or steering. Took a while to figure out but found a post somewhere on the parking brake sticking and the hot wheels. That led me to check it out and sure enough that was the issue.
    Skew12 and Svengalicanada like this.
  22. Jul 23, 2022 at 2:36 AM
    Svengalicanada
    Svengalicanada New Member
    2010 rcsb 4x4 4.6l
    Good call rebmo, notice how your post stopped this discussion .
    Just freed up my rusted equalizer e brake linkage with penetrating oil and an air chisel and coated it with formula 3000 undercoating. E brake no longer sticks...mystery vibration gone !!
    rebmo likes this.
  23. Jul 23, 2022 at 4:24 AM
    blenton
    blenton New Member
    Old thread, but I had this happen once. The parking break cable had some moisture in it that froze up one winter. The vehicle would shake pretty severely after releasing the parking brake and driving down the road. Would give an occasional shimmy until I had it looked at and it turned out to be the cable not releasing correctly. Several years later, I had the same thing happen on a different vehicle and I instantly recognized it. Now, I use my parking brake whenever I park on any sort of incline as well as whenever I've got a trailer hitched up whether or not it's parked on a grade. Keeps the cable from seizing up.
    rebmo likes this.
  24. Jul 23, 2022 at 9:29 AM
    Svengalicanada
    2010 rcsb 4x4 4.6l
    Yup,when you have a manual tranny the e brake becomes part of shutting off the vehicle. With an automatic it's not as important unless your on a grade so you never use it as much and it gets seized.
    Then once fixed you say to yourself ok I'm gonna start to use it faithfully, and that's what you start to do...until you drive for twenty miles on the highway one day before you realize (because you see the red e brake on indicator lit up ) you forgot to shut your e brake off...
    At least that's what I go through...lol
