Door broken where door holder attaches
Discussion in '1st Gen Tundras (2000-2006)' started by RVAtruck, Jul 19, 2022.
  1. Jul 19, 2022 at 6:10 PM
    RVAtruck
    RVAtruck [OP] New Member
    Richmond, VA
    2005 Tundra double cab Limited 4wd
    I just bought an 05 tundra and it’s turning out to be more of a project than I thought. My first problem is that the door is broken where the door holder attaches (see picture)
    anybody ever had success rigging something in that spot to hold the door holder in place? I’m thinking a thick piece of metal outside of the screws may do the trick. I don’t have the budget to replace the door
  2. Jul 19, 2022 at 6:12 PM
    Looks like you need to replace the door check or it’s cover plate (if that is a separate item).
  3. Jul 19, 2022 at 6:19 PM
    There is a guy that sells reinforcement plates and kits to fix this. I'm trying to remember his name.
    @FrenchToasty do you remember?
  4. Jul 19, 2022 at 6:21 PM
    Hahaha didn’t you buy some? I think it was a FB crony but don’t remember who
  5. Jul 19, 2022 at 6:31 PM
    RVAtruck
    Richmond, VA
  6. Jul 19, 2022 at 7:02 PM
    Ha! My terrible memory strikes again. I think it's valiant Guy George on Instagram but I deleted the app so I can't check.
    That's the plate but you need the repair kit too. If you have Facebook you can ask in the 1st gen page.
    They mention it in the last paragraph on that link you posted.
  7. Jul 19, 2022 at 7:26 PM
    assassin10000
    assassin10000 New Member
    Andrew
    Northern CA
    '05 SR5 AC 2wd
    Yep, @valiantguy.george on IG
    des2mtn, FirstGenVol and FrenchToasty like this.
  8. Jul 19, 2022 at 8:05 PM
    Aerindel
    Aerindel New Member
    Montana
    I have this exact same problem....after fixing the door check. That I think is probably what caused it to break, old truck just couldn't handle a functioning door check.
    I haven't decided yet if I want to make a metal plate, or weld. Probably just fabricate a plate.
    Jack McCarthy likes this.
  9. Jul 20, 2022 at 4:53 AM
    RVAtruck
    Richmond, VA
    I ordered the one that is not for welding since the weld plate is sold out. Will let you all know how it works out. Thank you all for the help!
  10. Jul 20, 2022 at 8:03 AM
    scooterprint
    scooterprint Idiot with a wrench
    Jeremy
    Conway, AR
    ‘04 DC 4x4
    Best of luck, those no-weld plates are quite a bit smaller than the weld-in plates. Not sure it will cover the damage you have.
  11. Aug 12, 2022 at 10:08 AM
    RVAtruck
    Richmond, VA
    It took a few attempts, but it’s working!
    My first two attempts, I hammered the metal back as close to the original spot as I could, but it was too warped for the nuts to reach the door check. Luckily I had more checks than I needed from that salvage vehicle cause I stripped the bolts on two of them trying to force them to fit.
    I emailed customer service from firstgentundras.com and Cameroon was kind enough to send me some special nuts he had for this situation (pictured below). There was enough metal there for it to hold and it’s working well now. Hopefully there’s enough support for the door to hold up over time and I won’t have to go to a welder. Thanks everyone for your advice, and thanks firstgentundras.com for the great customer service!
  12. Jun 30, 2024 at 4:26 AM
    TommyII Tundra
    TommyII Tundra New Member
    Harry
    2000 Tundra
    I have the same problem. They say to replace the door or it is a 1000$ repair job. I'm glad there is an alternative.img_1410-1-jpg_b3e18e99e9a3bc83ac8cba3c8fcbff8d619a770f.jpg
  13. Jun 30, 2024 at 8:21 AM
    3bears
    3bears New Member
    Joshua
    fairbanks alaska
    2002 acess cab
    none yet
    mine has this problem too
