Desperate for airbags or something to eliminate rear sag
Discussion in '3rd Gen Tundras (2022+)' started by ToyotaTundraguy, Jun 15, 2022.
  1. Jun 21, 2022 at 8:49 AM
    #91
    Terndrerrr
    Terndrerrr 925000 miles to go
    Music City
    6UR-FE
    You’re correct that they don’t replace a properly set WDH, and they do not add carrying capacity to your vehicle. They do reduce suspension sag and the poor handling that comes with it.
    GODZILLA and Coasty like this.
  2. Jun 21, 2022 at 9:09 AM
    #92
    mverkaik
    mverkaik New Member
    Hamilton, MI
    2021 TRD PRO CrewMax
    WeatherTech Floorliners Toyota Running Boards Reflex Liner Truxedo X15 Pro cover.
    It may add a little weight to the front. A little. Not nearly enough.
    The danger is that the level truck hides the problem. The trailer tows great because you have lots of tongue weight. However steering an braking are not what they need to be and the rear axle is way overloaded.
    Bags can augment and help. But they should only help and be used properly.
    Cpl_Punishment likes this.
  3. Jun 21, 2022 at 10:08 AM
    #93
    Coasty
    Coasty New Member
    Pat
    Oregon
    2022 SRS Crew Max 6.5 4x4
    I think I have the same trailer as you, is that the 26BHW Jayco? My sticker says it weighs 4500 lbs empty but like you I seriously doubt that. My truck weighed 6550 lbs with my wife and I, two dirt bikes and our gear as well as a full tank of gas in it about 850 lbs total. I have about the same amount of sag when I hook up the trailer and set the WD hitch. I plan on putting the trailer on with the bikes in the back but I know I'll be close to max cargo weight. My Ram 1500 was rated about the same as this truck and it did fine with some airbags on it, we'll see how this one does when I load it up but I'm in the market for air bags as well.
  4. Jun 21, 2022 at 10:36 AM
    #94
    mass-hole
    mass-hole New Member
    It actually could hurt the situation if the WDH is not readjusted to properly account for the air bags. Think about it. If you want to go release the spring bars(or chains or whatever your WDH uses), what do you do? You drop the tongue jack on the trailer and lift up the tongue and the back of the truck. This relaxes the spring bars so that you can easily pull them off by hand.
    Stuffing a set of air bags in your springs and inflating them so that the back of the truck raises 3" and looks good, is accomplishing the exact some thing as using the tongue jack. The air bags are increasing the angle between the truck and trailer and causing the spring bars to relax. Relaxed spring bars are not doing their jobs.
    So if the OP were to just run out and grab a set of bags, he might actually be getting less weight transfer to the front axle than he was in the first place. Yeah, his truck will look great, but I bet it actually rides and handles worse than it did without the bags.
    I know from experience that my truck/trailer handles worse with my bags inflated. I often have to tow down rough dirt roads and so I will disengage my WDH and inflate my air bags up to support the trailer tongue. A few times I accidentally left my airbags inflated when I got back to pavement. When I hooked up the WDH and started heading down the road I immediately could tell something was not right. It no longer felt like the truck and trailer were one unit like it normal does, but instead the two were bouncing around and generally riding like crap. I pulled off the road, let the air out of the bags, and everything was good again.
    mverkaik and Cpl_Punishment like this.
  5. Jun 21, 2022 at 12:56 PM
    #95
    mverkaik
    mverkaik New Member
    Hamilton, MI
    My trailer is one step bigger. I have the 267BHS. Mine has a slide on the other side and as a result weighs in about 900# heavier.
    I bet you will be fine with the bikes in the back. Maybe dial in a little more hitch spring to compensate.
  6. Jun 21, 2022 at 2:44 PM
    #96
    Dfrink
    Dfrink New Member
    SR5 CM 4wd
    So even though my trailer is set up good right now, I plan to level the front of my truck in the future. The truck sits level when loaded now (see pic's in previous post). If I level the front (up 2") then the truck will look nose high 2" when the trailer is hooked up. Is there a good way around this? A better WDH? I have a basic ezlift WDH (which currently does a great job). I know airbags will make the truck LOOK good, but I want something that actually fixes the problem... Advise?
  7. Jun 21, 2022 at 2:48 PM
    #97
    Cpl_Punishment
    Neil
    2020 MGM SR5 CM 4X4
    Keep the rake if you plan to haul or tow heavy.
    GODZILLA, mountainpete and mverkaik like this.
  8. Jun 21, 2022 at 3:03 PM
    #98
    mverkaik
    mverkaik New Member
    Hamilton, MI
    Do you want the look while towing or while empty? You really can’t have both and tow safely.
    Let’s get real, 2” of squat while hauling 800 pounds of tongue weight is really not bad.
  9. Jun 21, 2022 at 3:16 PM
    #99
    Cpl_Punishment
    Neil
    2020 MGM SR5 CM 4X4
    I would say it's expected and the reason trucks have rake. Guys who level their trucks are just telling the world they drive grocery getters.
  10. Jun 21, 2022 at 3:23 PM
    #100
    Sparky916
    Sparky916 New Member
    Blake
    22 Lunar Rock Limited TRD OF
    I have my truck leveled with wescott 3/1 and only have 1.5” of sag when I was pulling my 34’ TT at around 9k loaded. I couldn’t tell you my exact tongue weight. I’m using a harbor freight WDH with 2 sway control kits. If you level your truck, just make sure to setup your WDH again. Your spring bars should run parallel when under load which is the most common error I personally see when people are setting their WDH up.
  11. Jun 21, 2022 at 10:23 PM
    #101
    Jbeans691981
    Jbeans691981 New Member
    2022 Tundra Sport Lunar Rock
    n/a
    This coil rite 4164 kit is 2022 compatible. Ebay says no.
  12. Jun 22, 2022 at 1:10 PM
    #102
    jmay86
    jmay86 New Member
    Josh
    Columbus, Ohio
    '22 Lunar Rock LTD DC TRD-OR
    No to hijack the thread here, but at what point does a WDH become necessary? Is it a certain GVWR of the trailer, solely based on hitch weight, combo of both?
    We are in the market for our first travel trailer and are eyeballing a 22 Jayco STX 174BH with a GVWR of 4150lb (according to the dealers site)... I know nothing about trailers, but do know that is considered very light for our trucks as far as towing abilities go... TIA!
  13. Jun 22, 2022 at 1:19 PM
    #103
    Dfrink
    Dfrink New Member
    SR5 CM 4wd
    Personally, if you had a 3/4 ton I’d say you may not need a wdh for a trailer that light. But I’d get one anyways. Someone told me under 5k pounds you don’t need one. But why not use one anyways?
    For a half ton I’d use a wdh for a trailer that light, no questions asked.
    Scooter73, jmay86 and Sparky916 like this.
  14. Jun 22, 2022 at 1:23 PM
    #104
    Sparky916
    Blake
    There's no set rule on when you should use a WDH, but what I've always gone by is if it's a smaller utility trailer (weighs less than my vehicle when its loaded) I'll just use a regular ball mount. When towing a TT I personally always use a WDH. One of the big benefits using a WDH is the addition of a sway controller which is necessary IMO. If you don't want to spend a fortune on a WDH just get the one from harbor freight and get a sway controller from them too. Its worked great for my 34' TT that's usually at 9k when I'm towing (I have 2 sway controllers installed.) Sure there are better WDH out there, but it gets the job done just fine for me.
    KNABORES and jmay86[QUOTED] like this.
  15. Jun 22, 2022 at 1:51 PM
    #105
    mverkaik
    mverkaik New Member
    Hamilton, MI
    I will second that statement. I would probably use one for anything over about 400lb on the tongue.
    I would look into an Equalizer hitch. They are much easier to hook up and have active sway control vs. passive.
    jmay86 likes this.
  16. Jun 22, 2022 at 2:01 PM
    #106
    jmay86
    jmay86 New Member
    Josh
    Columbus, Ohio
    Thanks for the info... The dealer I've been speaking with quoted $995 installed for a WDH with sway control, but I haven't a clue if that is a good deal or not... I will look into pricing myself as well...
    I will look into these too... Thanks!
  17. Jun 22, 2022 at 2:28 PM
    #107
    mass-hole
    Usually, its determined by the manufacturer of the truck. Like my F150 is limited to maximum tongue weight of 500 lbs without a WDH but I believe the Silverado 1500's are 650 lbs.
    Best bet is to look at the receiver on the truck and see what it says. It probably tells you the maximum ratings with and without WDH.
  18. Jun 22, 2022 at 7:32 PM
    #108
    Cpl_Punishment
    Neil
    2020 MGM SR5 CM 4X4
    I believe Toyota says in the manual it's required if your trailer weighs over 5000 lbs. You're going to be pretty close to that if not over once that trailer is loaded up with gear so I'd go for one. If you get the kind with trunnion bars (instead of chains), you also get sway control.
    jmay86[QUOTED] likes this.
  19. Jun 22, 2022 at 7:33 PM
    #109
    Cpl_Punishment
    Neil
    2020 MGM SR5 CM 4X4
    That price is about on par with what they are here.
  20. Jun 23, 2022 at 9:48 AM
    #110
    mass-hole
    But its also probably a 500 lb tongue weight, which is really what is important. A 4000 lb TT could have a 500 lb tongue
  21. Jul 11, 2022 at 8:09 PM
    #111
    t300
    t300 New Member
    Manitoba
    22tundra
    Sooo OP - what did you end up doing and how does it tow now?
    Jbeans691981 and Cpl_Punishment like this.
  22. Jul 19, 2022 at 9:53 AM
    #112
    Jbeans691981
    n/a
    I’ve installed the coil bag. Rides fine. Tows perfect. Sag virtually gone.
    t300[QUOTED] likes this.
  23. Jul 19, 2022 at 10:10 AM
    #113
    mverkaik
    mverkaik New Member
    Hamilton, MI
    You should run it across the scales and post your axle weights. It will help others understand what works well for you.
  24. Jul 19, 2022 at 10:12 AM
    #114
    Jbeans691981
    n/a
    I tow 3 500lbs ATVs. And a 6X12 trailer. No weight distribution hitch. No scales in our area to be able to provide that specific information. 3 days a week I carry 1400lbs of payload in the bed. I inflate the bags to 30psi and sag disappears
  25. Jul 19, 2022 at 10:22 AM
    #115
    May have been mentioned on this thread already, but rear sag is indicative of the amount of weight being added to the rear axle. Adding airbags doesn’t change this. It eliminates squat, but not the amount of weight being added the rear axle. You’re also unloading the front axle a bit when doing this. A WDH transfers some of the weight back to the trailer and some of the weight forward to the front axle reducing the weight on the rear axle alone. Handling will improve, sway will be reduced. Squat will be reduced as the front will stay at original position or actually “ squat” some with the load as well.
  26. Jul 19, 2022 at 3:38 PM
    #116
    Jbeans691981
    n/a
    Exactly. Primarily I use to offset payload. I do not tow heavy equipment. Transferring weight to front axles in my situation are not necessary. However, WDH is a critical tool
  27. Aug 24, 2022 at 6:29 AM
    #117
    LEM
    LEM New Member
    2022 Lunar Rock Tundra Limited TRD
  28. Aug 24, 2022 at 6:36 AM
    #118
    LEM
    LEM New Member
    Nor did my 2007. Here they are in comparisonD1A23C89-2DE9-4D86-BF44-1778A71D7EB0.jpg with the same trailer.
  29. Aug 24, 2022 at 6:43 AM
    #119
    Cpl_Punishment
    Neil
    2020 MGM SR5 CM 4X4
    Did you readjust the WDH for the new truck?
    GODZILLA likes this.
  30. Aug 24, 2022 at 1:51 PM
    #120
    Knifeguy
    Knifeguy New Member
    Erik
    Oklahoma
    22 SR5 4x4 Crew-Max Short bed
    It could be the photos, but it sure doesn't look like there is much tension on the bars on almost all these pictures of sagging trucks. They all look pretty straight.
