  1. Jul 11, 2022 at 8:00 PM
    Mr.bee
    Mr.bee King Turdra
    '02 AC TRD
    link?
    Who you calling an aslo?
  2. Jul 11, 2022 at 8:02 PM
    alb1k
    Left Coast
    05 2WD DC w/ attitude
    It's good
  3. Jul 11, 2022 at 8:07 PM
    alb1k
    Left Coast
    It's good
    I can't begin to understand most of that, but is it safe to say don't jam the brakes before they are broken in? Asking for a friend.
  4. Jul 11, 2022 at 8:09 PM
    Mr.bee
    Mr.bee King Turdra
    '02 AC TRD
    Yea, anytime you cook the brakes, pull the pads and scuff em on the concrete.
  5. Jul 11, 2022 at 8:10 PM
    alb1k
    Left Coast
    It's good
    Ahh. thank you, I understand that completely. Ditch the glaze (polish) get the grab.
    Mr.bee[QUOTED] likes this.
  6. Jul 12, 2022 at 4:31 AM
    KingSequioa007
    KingSequioa007 Dreaming of URD S/C
    San Diego, CA
    07 Sequoia SR5
    Current mods: AFE Cold air intake, AFE TB Spacer,JBA Long tube headers, DD full cat back race exhaust, pedal commander pedal controller, URD MAF Calibrator tuned by Mike @ Autowave, DD 12 hole 320CC injectors, R9K ECU reflash,Solid Off road mounts. Future upgrades: 4.8 gears and LSD, ,long travel kit.
    Yes agreed. Maybe someone local to him that can reach out. Group buy anyone?
    5N0W808[QUOTED] likes this.
  7. Jul 12, 2022 at 10:55 AM
    Kimosabe
    Kimosabe Slacker
    Sun Valley, Idaho
    06 Tundra DC TRD 4WD
    I was getting some rubbing in the driver front wheel well when backing up out of the driveway and turning. I tried to move the wheel a bit and found out my adjustment cams are frozen, and I managed to tear the rack boot causing a decent leak. Now, as an excuse to go big, and because I haven't had to do anything to the truck in a while I placed a nice big order this morning. I'll be replacing the rack and pinion and steering shaft seal as well as lower control arms, and cams. I also found a new place to relocate the shock reservoirs so I'll be moving those at the same time. Wish me luck!!!
    RUSTYNUTS, KK6PD, shifty` and 3 others like this.
  8. Jul 12, 2022 at 12:19 PM
    shifty` You can call 1 (800) PP5-1-DooDoo
    Voss and Kimosabe[QUOTED] like this.
  9. Jul 12, 2022 at 1:36 PM
    alb1k
    Left Coast
    It's good
    I was happy but not pumped with the durabak 18 dark grey on the lid. So, I ordered some smooth dark grey and black and did a custom mix. Much better.
    C70E2DC2-11EC-4CB8-82AF-A27776FFBC21.jpg 06B57B5C-75BB-46B1-A920-E6D2069E8CC9.jpg
    Archive, CodyP, Mr.bee and 2 others like this.
  10. Jul 12, 2022 at 5:45 PM
    cadebucket
    cadebucket New Member
    Utah
    2005 Tundra DC Limited
    Aftermarket headunit install. I found this Boss BVCP9685A open box on ebay. So far I can tell its not as high resolution or as responsive as name brand headunits I've used but it was cheap. I made the steering wheel controls work using a axxess ASWC-1. it was super easy to set up. I decided to run new speaker cables as I didn't want to pay $70 for a harness that made the speaker wires twice as long as they needed to be. Not really worth it as running the speaker wires took a very long time. Now I just need my tweeters to show up.
    While taking off the tweeter covers the small clip that stays in the door broke on both sides. I haven't been able to find an individual part number, has anyone else replaced these?
    Lextech, Kimosabe and mcharfauros like this.
  11. Jul 12, 2022 at 5:52 PM
    Which head unit kit did you use with that? I like it a hell of a lot better than the Metra kit I used with mine.
  12. Jul 12, 2022 at 5:52 PM
    I replaced mine with aftermarket. Needed a little coercion. Sounds cleaner, louder and brighter. Factory made a high pitched tinny whistley noise, but didn’t sound like music.
    des2mtn likes this.
  13. Jul 12, 2022 at 5:55 PM
    Also, not sure
    Best kit is the 2000-2002 dash bezel….
    NUDRAT, oscardog86 and daveeasa like this.
  14. Jul 12, 2022 at 5:55 PM
  15. Jul 12, 2022 at 5:56 PM
    Yeah, I agree. I'm just not willing to go through another center dash swap again :D
    des2mtn likes this.
  16. Jul 12, 2022 at 5:56 PM
    Aw come on, what’s one more?
    des2mtn and shifty`[QUOTED] like this.
  17. Jul 13, 2022 at 10:27 AM
    Kimosabe
    Kimosabe Slacker
    Sun Valley, Idaho
    I've got the same headunit setup as you @shifty` and I agree that I'm not impressed with the Metra kit. I don't like having the gap at the top and bottom. However, I am looking at relocating my phone mic by drilling a spot for it in the side filler piece.
  18. Jul 13, 2022 at 2:20 PM
    This is where mine ended up, more details here on how I installed. It's a simple no-drill option which doesn't require removal of the A-pillar trim. Everyone says I sound great on the phone.
  19. Jul 13, 2022 at 2:41 PM
    daveeasa
    That's a good spot. I have mine off the driver visor but that spot might be better.
  20. Jul 13, 2022 at 2:48 PM
    Kimosabe
    Kimosabe Slacker
    Sun Valley, Idaho
    That is a pretty good spot. Mine's on the bottom of my steering column and nobody can hear me well so I hang up. On second thought, I'll keep it where it is.
    I need to take mine out, but if I can have it flush with the bezel trim piece then it would be nice to have it not be seen, and look a bit less aftermarket. I may not get around to it any time soon.
  21. Jul 13, 2022 at 2:51 PM
    assassin10000
    assassin10000 New Member
    Andrew
    Northern CA
    '05 SR5 AC 2wd
    This reminds me, I need to get an aftermarket mic and see if I can pin it to work with the OEM 86 radio.
    Know if it'll work @empty_lord ?
  22. Jul 13, 2022 at 2:53 PM
    CodyP
    CodyP Such a n00b
    Cody
    CDA, ID
    2006 Tundra 4x4 DC
    but I'm sure you still don't sound as great at @empty_lord no matter where you put that mic.
    RUSTYNUTS and FrenchToasty like this.
  23. Jul 13, 2022 at 3:05 PM
    805Tundra
    805Tundra New Member
    Ben
    Central Coast
    2004 White 4x4 Double Cab
    This is where mine is, no complaints from people I call. Can hear me loud and clear.
    shifty` and FirstGenVol like this.
  24. Jul 13, 2022 at 3:25 PM
    Microphones are usually just 2 or 3 wires, whether OEM or otherwise. Number of wires depends whether or not it's balanced. I can't imagine why you wouldn't be able to make it work.
  25. Jul 13, 2022 at 3:40 PM
    assassin10000
    Andrew
    Northern CA
    '05 SR5 AC 2wd
    That's my thought as well.
  26. Jul 13, 2022 at 6:09 PM
    alb1k
    Left Coast
    It's good
    Best microphone spot is left pillar at the top, clipped between the headliner and the pillar trim. I said it.
    Archive and 5N0W808 like this.
  27. Jul 13, 2022 at 6:11 PM
    Mines at the windshield by the navigation indicator, I never used it because I’m not important enough to be talking while driving, and I’d rather listen to music
    NUDRAT and shifty` like this.
  28. Jul 13, 2022 at 6:15 PM
    alb1k
    Left Coast
    It's good
    Well, I won't argue the importance, I think it's been proven that you may as well have your phone up to your ear.
  29. Jul 13, 2022 at 6:19 PM
    If I do for some reason take a call at work or something while driving, when I hang up, I feel like I just woke up from a narcoleptic nap; how did I even get here? Did I stop at lights?
    there’s also this certain stop sign at work, that for some reason I thought I was at a light waiting for it to be green……… I’ve done it twice
  30. Jul 13, 2022 at 6:26 PM
    alb1k
    Left Coast
    It's good
    That phenomenon happens anyway, once you have been driving so long it's quite automatic. Like muscle memory. But, Focus is diluted if you are talking to someone in the car or out. Amplifies it.
