  1. Jun 19, 2022 at 6:42 PM
    dlowry81
    dlowry81 New Member
    Doug
    2004 Tundra Doublecab
    So short back story. I’ve noticed slop in my shift lever and thought about doing the bushing replacement where the cable attaches to the lever. I read where some guys thought the lever play wasn’t from that so I put it on the back burner.
    Well tonight I go to play hockey and as I’m shifting once it hits neutral the lever goes limp and won’t shift. Lever moves up and down but no shifting taking place. I’m stuck in neutral. I feared the cable broke but disassembly shows the bushing completely gone. I ziptied the end to hold the cable in place till bushing arrives.
    Jack McCarthy, FirstGenVol and w666 like this.
  2. Jun 19, 2022 at 6:43 PM
    dlowry81
    dlowry81 New Member
    Doug
    What brand? I heard Felspro sucks, but I had good luck with Becks Arnley I believe was the brand.
  3. Jun 19, 2022 at 6:45 PM
    Ghostly.-
    Ghostly.- Tragic.
    Mitchell
    Montana
    Tried Felpro, those were the worst. Then OEM, then Mahle. At least with the Mahle ones only one side is leaking now so I don't have to pull both fuel rails.
  4. Jun 20, 2022 at 2:21 AM
    w666
    w666 D. None of the above
    Maryland
    04 Access Cab SR5 V8 4WD
    Speaking of welds...those are some seriously shitty welds on your NEW crossmember
  5. Jun 20, 2022 at 7:33 AM
    5N0W808, bmf4069, Siebler and 3 others like this.
  6. Jun 20, 2022 at 8:01 AM
    alb1k
    Left Coast
    05 2WD DC w/ attitude
    It's good
    I thought so as well, lol.
  7. Jun 20, 2022 at 8:10 AM
    Especially for the price they're asking!
  8. Jun 20, 2022 at 8:24 AM
    alb1k
    Left Coast
    It's good
    shifty`[QUOTED] likes this.
  9. Jun 20, 2022 at 10:47 AM
    Mr.bee
    Mr.bee King Turdra
    '02 AC TRD
    Rattle canned the inner fenders flat black before heading to kempner. They were much lighter, and in some places had sandblasted through to some white. Very light coat after cleaning. Next time I wash down there I’ll bust out the beer box masks and do the chassis gloss, and the wheel wells that foam underbody spray.
    Or, I may pull the springs and find out how much droop I can get. And can get some painting in tomorrow.
    oscardog86 likes this.
  10. Jun 20, 2022 at 4:12 PM
    Ghostly.-
    Ghostly.- Tragic.
    Mitchell
    Montana
    Fuel leaks are now fixed, but then it wouldnt rev past 3000. Found that the power wire for the MAF broke so I reconnected it. Now it bogs hard at barely any throttle and struggles to do even 20mph. Any ideas?
  11. Jun 20, 2022 at 4:28 PM
    AS stupid as this will sound, disco battery and go have a couple beers.
    NUDRAT likes this.
  12. Jun 20, 2022 at 4:30 PM
    Ghostly.-
    Ghostly.- Tragic.
    Mitchell
    Montana
    Man if only. I've tried that, but still nothing. The worst part is that it doesn't even throw a CEL.
  13. Jun 20, 2022 at 4:31 PM
    Have another MAF you can toss in?
  14. Jun 20, 2022 at 4:33 PM
    PS - do you have any way to monitor air intake and fuel output readings?
  15. Jun 20, 2022 at 4:56 PM
    Ghostly.-
    Ghostly.- Tragic.
    Mitchell
    Montana
    Yep, I have the one off my truck and the one off of the junkyard truck. Just did a little more testing, and it will go back into limp mode(limited to 3k rpms) if I run it without the MAF plugged in. I have a scanner plugged in, and its showing increased airflow as I rev it in park. At idle it showed 1lb/min if I remember correctly. Also forgot to mention it revs just fine in park, just wont when in gear.
  16. Jun 20, 2022 at 5:01 PM
    And there aren't any codes pending?
    I have zero experience with SC setups, much less this one, so I'm throwing this out there to spitball ... have you tried a more mild tune on the Unichip? Is there a way to bypass the Unichip temporarily just to see if maybe it's not the funky link here?
  17. Jun 20, 2022 at 5:09 PM
    Ghostly.-
    Ghostly.- Tragic.
    Mitchell
    Montana
    No pending codes :(. I've got 2 tunes on the Unichip, the base tune and one made for the mods I have. Both have the same issue. Also the Unichip N/A tune I was running was completely fine, and I'm scared that there won't be anything running the 9th injector if I unplug it. It almost makes me think there are more wiring issues with the MAF considering It doesn't go full potato with it unplugged.
  18. Jun 20, 2022 at 5:12 PM
    If it's the same no matter which MAF you put in, yeah, could be.
    I haven't read back. Who built the harness, if applicable? Do you have a DMM? A wiring diagram so you can test continuity etc?
    You've given a once-over on the throttle body assembly, cable and articulation looks good?
  19. Jun 20, 2022 at 5:39 PM
    Ghostly.-
    Ghostly.- Tragic.
    Mitchell
    Montana
    Yeah, the 3 plugs on the TB looked good. The harness came from unichip, and none of the connections look bad. Sadly I can't do anymore atm because its pouring rain again.
  20. Jun 20, 2022 at 5:41 PM
    If it were me, as much as I like plugging away at unknowns and solving problems, I'd button it up and contact Unichip in the AM.
  21. Jun 20, 2022 at 9:52 PM
    2uzfe2000
    2uzfe2000 New Member
    Front end delete complete. Hoping this will improve highway ride quality.
    CodyP, TravisJr, des2mtn and 4 others like this.
  22. Jun 20, 2022 at 9:55 PM
    empty_lord
    Indiana, Chicagoland
    05 rollover special
    hover craft mod? sweet
    Tundra2, NUDRAT, oscardog86 and 3 others like this.
  23. Jun 20, 2022 at 10:01 PM
    Bluetoof
  24. Jun 21, 2022 at 7:09 AM
    JustJake
    JustJake New Member
    2006 AC
    2" lift. Trying to diagnose driveline vibration when towing. I am thinking the weight of the trailer is changing the angle of driveshaft. Bad vibration around 65.
    Already tried a carrier bearing drop but without any change. What else can I try with the DS? Any thoughts? So far, I have had it balanced. WIs it worth having the u-joints and carrier bearing replaced? Only 140k on the truck.
    Considering a one-piece replacement DS.
  25. Jun 21, 2022 at 10:02 AM
    Ghostly.-
    Ghostly.- Tragic.
    Mitchell
    Montana
    Finally it runs! Went through the Unichip config, it all got changed when I updated the firmware. All is good now, truck rips.
    Kimosabe, KNABORES, NUDRAT and 9 others like this.
  26. Jun 21, 2022 at 10:05 AM
    Mr.bee
    Mr.bee King Turdra
    '02 AC TRD
    @Outbound was it you chasing driveline vibes?
  27. Jun 21, 2022 at 10:27 AM
    rock climber
    rock climber New Member
    2001 Sequoia 4X4, 2000 AC 4X4
    What lift on the rear? Others have had luck with angled shims under the rear leaf pack.
  28. Jun 21, 2022 at 10:29 AM
    JustJake
    JustJake New Member
    2006 AC
    2-3" in rear. Is an angled shim on the leaf pack rotating the pinion angle?
    Mr.bee likes this.
  29. Jun 21, 2022 at 10:47 AM
    Outbound
    Aaron
    Northern Alberta
    Yeah. Never came up with a solution. Both myself and my mechanic spent alot of time trying almost everything. The only thing I haven't tried is a one piece drive shaft, which may or may not make a difference. I've given up, the vibration is only in a 5 - 10mph range and I'm selling the truck next month anyways.
    Jack McCarthy and Mr.bee[QUOTED] like this.
  30. Jun 21, 2022 at 11:00 AM
    I thought you gave it to your dad like 6 months ago?
