Parking Break Malfunction, Cruise Control Malfunction
Discussion in '3rd Gen Tundras (2022+)' started by jfletch133, Mar 14, 2022.
  1. Mar 14, 2022 at 4:25 AM
    jfletch133
    jfletch133 [OP] New Member
    Wayne
    2022 Tundra SR5 TSS Offroad
    I keep getting a parking break, cruise control malfunction error code. Toyota has no idea what's wrong and has not been able to fix it. Anyone else having this issue?
  2. Mar 14, 2022 at 5:27 AM
    Rwaters
    Rwaters New Member
    2022 Tundra TRD SR5 Crewmax
    I had several malfunctions and the dealer had the same problem figuring it out. Toyota corporate got involved and they hooked up all kinds of computers/recorders to my truck. I started a thread but at the time I was the only one with the problem. Supposedly I was the first one in the country. Good luck
    https://www.tundras.com/threads/lta-malfunction-and-carplay.101516/
  3. Mar 14, 2022 at 5:34 AM
    OnThaLake
    OnThaLake New Member
    Does it actually say "break" on your dash, or is something broken when parking?
  4. Mar 14, 2022 at 5:35 AM
    Donas
    Donas New Member
    TN
    22 Tundra Platinum
    We should start a club! I was said to be first in country with AC issue, lol.
  5. Mar 14, 2022 at 6:08 AM
    Rwaters
    Rwaters New Member
    Some of us probably should. Do we get trophies!?
    Donas[QUOTED] likes this.
  6. Mar 14, 2022 at 6:25 AM
    raylo
    raylo not so new member
    Frederick, MD
    DashCam, amp & sub, DIY rear seat delete, cat shield, AMP power boards
    No trophies, but the rest of us give you early adopters many thanks for helping Toyota to sort all this stuff!
  7. Mar 14, 2022 at 12:28 PM
    VCsam
    VCsam New Member
    2022 Tundra LR, 2006 Tacoma SPRT, 2001 Hilux 4x4
    Carseat
    This is what some 2nd gen owners don't understand. If it wasn't for the early owners in 2007 (and other refresh years), the 2nd gen wouldn't be as great as it is now (in terms of reliability). Btw, it's nice to see someone from my area. Maybe you'll spot my truck in the next few weeks.
    TMack77 likes this.
  8. Mar 14, 2022 at 12:54 PM
    KroppDuster
    Here. There. Everywhere.
    Bilstein 5100s
    haha. I checked my A/C the other day, even though it was only 75 outside, just to make sure it worked. I realized that I hadn't ever tested it since I took delivery of the truck in mid-December. Blew ice cold. Whew.
    Rwaters likes this.
  9. Mar 14, 2022 at 6:46 PM
    Donas
    Donas New Member
    TN
    22 Tundra Platinum
    Funny, mine gets run year round. Usually, 62 is about as high as it goes, lol. Not sure why, but driving this weekend in the snow at about 25 degrees, 60 felt comfortable and 61 almost felt like the heat was on. Today, it was near 70 and AC on 60 still felt comfortable.
    I'd be interested to know the exact temperatures others ACs are blowing. Anyone have a laser temp gun and wanna experiment?
  10. Mar 14, 2022 at 7:35 PM
    IR/laser handheld temp guns are very inaccurate when trying to measure air flow temps. We always spot calibrate them in the absence of any air flow. Air flow distorts the measurement.
    OnThaLake likes this.
  11. Jun 18, 2022 at 7:11 AM
    jfletch133
    Wayne
    Turns out it was ABS Module. Once replaced it works fine.
  12. Jun 18, 2022 at 8:33 AM
    Maharisc
    Maharisc w/Patty
    Karl
    Build date: 12/05/22
    I have the same issue, been going on for a couple weeks, I don't drive much as I work from home. Usually turn it off and back on resets it for a short term. Also seems to be heat related, living up know we recently have warmer weather and it is acting up more often. Your last statement says ABS module, good to know. Thank you.
  13. Jun 18, 2022 at 10:46 AM
    Jr3volution
    Jr3volution New Member
    Johnnie
    DFW TX
    2022 Tundra Platinum
    I have this pop up occasionally but it goes away when I engage and disengage the electronic brake
  14. Jun 18, 2022 at 12:05 PM
    KroppDuster
    Bilstein 5100s
    That tends to happen when you don't pause long enough between shifting into Park and shutting the truck off. If you shift into park and then immediately turn off the truck, it doesn't give the Emergency Parking Brake (EPB) time to engage before the truck shuts off.
    Just give it an extra second (literally...that's about all it takes) between putting the truck in park and shutting the engine off.
  15. Jun 18, 2022 at 12:29 PM
    Jr3volution
    Johnnie
    DFW TX
    that’s probably what it is. I will definitely keep this in mind.
    Thank you @KroppDuster
  16. Jun 18, 2022 at 7:59 PM
    OnThaLake
    Must be a Tundra issue.
    My wife's newer Toyota with epb never displays a warning message, under any circumstances.
    I really like Toyotas, but these little issues are suspect.....
