Desperate for airbags or something to eliminate rear sag
Discussion in '3rd Gen Tundras (2022+)' started by ToyotaTundraguy, Jun 15, 2022.
  1. Jun 15, 2022 at 3:12 PM
    You know that hurt….
    GODZILLA and Wahayes[QUOTED] like this.
  2. Jun 15, 2022 at 3:14 PM
    Wahayes
    Will
    2017 tundra limited
    My 2.5 gen
    Cpl_Punishment likes this.
  3. Jun 15, 2022 at 3:42 PM
    Medic343
    Medic343 5+4+3=2
    Kenny
    New Mexico
    '22 SR5 TRD off-road
    Obviously you've been getting good advice so far but my biggest suspicion is the fact that you have a sport. I am sure there are tons of people that will bash me or have something to say but that has always been a thing for me. A "sport" suspension is not going to be designed nor tuned for towing or offroading yet tons of Toyota owners don't see it the same way I do...
  4. Jun 15, 2022 at 4:01 PM
    samwell885
    samwell885 New Member
    2022 Limited 4x4
    I was thinking the same thing. Hooking up a trailer to my ‘22 with Load Leveling air suspension is awesome. Watching it level out as soon as weight is on the hitch is pretty cool. Definitely was built for towing. Hopefully OP can get some aftermarket air bags soon. They really are awesome for towing.
    Red Freighter likes this.
  5. Jun 15, 2022 at 4:09 PM
    ToyotaTundraguy
    ToyotaTundraguy [OP] New Member
    2022 tundra trd sport
    I think you guys are on to something with the sport because it seems to have a heck of a lot of travel in there and it’ll still squat more at that . I need the air bags or somebody to tell me what land cruiser suspension mod to order and where and I’ll be on it
  6. Jun 15, 2022 at 4:42 PM
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
    My trailer tongue is 500lbs and takes my truck down past level from a 2 inch rake. Tundra springs are jelly doesn’t matter the gen. There is an inside coil airbag kit that you can jam in there
    Acedude and Terndrerrr like this.
  7. Jun 15, 2022 at 4:57 PM
    Terndrerrr
    Terndrerrr 923000 miles to go
    Music City
    6UR-FE
    I hear you but squatting with stock suspension is nothing new to any trim level. All 2nd gens were the same way. Toyota tunes the rear suspension toward comfort, not work.
    WDH and air bags or timbrens or RAS or new springs (leaf or coil). Many people beef it up and have no issues. How far they should go beyond what Toyota says they should is a source of endless debate here.
    I will say that I used to load my 4Runner down for trips, and when I put airbags in its rear coils, I could lower the psi down to 5 and not notice they were there.
    Acedude likes this.
  8. Jun 15, 2022 at 6:12 PM
    Cpl_Punishment
    Neil
    2020 MGM SR5 CM 4X4
    WDH and/or a trailer that's an appropriate size for a halfton to tow.
  9. Jun 15, 2022 at 6:33 PM
    Wahayes
    Will
    2017 tundra limited
  10. Jun 15, 2022 at 6:35 PM
    Cpl_Punishment
    Neil
    2020 MGM SR5 CM 4X4
    LarryDangerfield and Terndrerrr like this.
  11. Jun 15, 2022 at 6:37 PM
    Wahayes
    Will
    2017 tundra limited
  12. Jun 15, 2022 at 6:38 PM
    Wahayes
    Will
    2017 tundra limited
    Doesn't appear so based on that article.
    Edit- I guess it could be if an sr5 sport is under the "sport suspension" umbrella
  13. Jun 15, 2022 at 6:43 PM
    Wahayes
    Will
    2017 tundra limited
  14. Jun 15, 2022 at 7:28 PM
    mass-hole
    mass-hole New Member
    If your trailer is really 7000 lbs then your tongue weight is probably more like 925 lbs. I dont think you have enough hitch.
    Im running equalizer 1000 lb bars on my 5500 lb trailer, because equalizers next size down is for a 600 lb tongue. I know my tongue has more weight on it than 600. they level out my coil sprung lexus GX nicely
  15. Jun 15, 2022 at 7:56 PM
    EmergencyMaximum
    I might know what the problem is. Tundras have flexible frame, so if they add beefier suspension, people will load them more because it won't look squatty and will end up bumping their beds against the cab like was posted somewhere in a other thread with dude pulling camper out of the sand.
    This is like a safety feature, you see truck squat and you know you've reached the limit of the frame. That's how I judge how much weight is in the bed. An inch or less to the bump stops: fully loaded.:)
  16. Jun 16, 2022 at 9:42 AM
    KroppDuster
    Here. There. Everywhere.
    Bilstein 5100s
    Check out the 3rd Gen Suspension Lift - MEGA THREAD we've put together. Even though you don't want a lift, you're still dealing with the same solution...heavier rear springs. There's links to the 2 different Dobinsons HD springs available for the 3rd Gen Tundra. There are 2.5" lift and a 2.0" lift versions of the springs.
    You can also check out Dobinsons Direct: https://www.dobinsonsdirect.com/pages/product-result?rq=mk_toyota~md_tundra~yr_2022-on
    That being said, you'll get quite the rake when not towing but it should even you out under major load. In my opinion, you're best course is it go bags so you can control the suspension differently for towing vs non-towing. My 2 cents.
    Acedude likes this.
  17. Jun 16, 2022 at 10:22 AM
    ToyotaTundraguy
    So I just need to replace springs or will I need other parts aswell ?
  18. Jun 16, 2022 at 10:22 AM
    ToyotaTundraguy
    I always have a load so it make work well
  19. Jun 16, 2022 at 10:27 AM
    KroppDuster
    Bilstein 5100s
    If you're going increase the rear travel by 2", which is what you'll be doing when you're not towing a load, then you will want the following:
    • Rear Springs
    • Extended Brake Lines
    • Extended Rear Shocks
    • Adjustable Rear Track Bar (Most likely - to re-center the rear axle)
    You're probably ~$1,300 in parts plus install labor.
    But, again, you'll increase the rake 2" in the rear when you're not towing. It'll look a bit like a mild "hot rod." haha
    Acedude likes this.
  20. Jun 16, 2022 at 10:29 AM
    #50
    Wahayes
    Will
    2017 tundra limited
    Also to get that down with dobinsons spring you would need a pretty substantial constant load . It takes quite a bit to bring them down
  21. Jun 16, 2022 at 10:43 AM
    #51
    KroppDuster
    Bilstein 5100s
    Yeah. I've heard they're a beast. Everyone I know that have used Dobinsons springs are using them on expedition/overland rigs. They're throwing a lot (and I mean a lot) of weight in the rear. I'm talking Alu-Cabs, water tanks, or rear bumper mounted 35" spares, etc.
    If his tongue weight is well north of 500 lbs...especially if it's close to 900 lbs as someone mentioned...he should be able to take a lot of the rake out of them under load. But when not under a load...totally different story.
    That being said...I'm offering advice as someone who has 100x more experience lifting vehicles than towing with them. :rofl: All of the towing guys are probably saying, "Just put air bags in."
    RookieEP likes this.
  22. Jun 16, 2022 at 11:12 AM
    #52
    king.cong.1119
    king.cong.1119 New Member
    try roadmaster active suspension, wait.... they don't have leafs anymore NVM
  23. Jun 16, 2022 at 11:15 AM
    #53
    Wintersun
    Wintersun New Member
    Every Toyota truck I have owned has needed additional support at the rear leaf springs. I would go to a 4x4 shop and have them add a leaf at the rear on each side. I see many Toyota trucks and 4Runners with the rear sagging and no load at all. At this time the best option is a set of SuperSprings added to the rear. They only come into play when the load is too great for the factory springs.
    I added a set to my 2500 truck and increased it payload capacity from 2800 lb to 4000 lb and could put a 3700 lb slide in camper in the bed with no sag at all. The SuperSprings take less than an hour to install and can be done with the truck's wheels on the ground. Nothing to adjust and nothing to fail. If only one air bag fails on a trip it would be a real problem.
    Adding to the load support is also good for the life of the shocks which otherwise are working overtime.
    Acedude likes this.
  24. Jun 16, 2022 at 12:23 PM
    #54
    mass-hole
    Or just get the correct wdh spring bars.
    jproy12, Scooter73, GODZILLA and 2 others like this.
  25. Jun 16, 2022 at 12:24 PM
    #55
    Wahayes
    Will
    2017 tundra limited
    Can he add leaf springs to a coil sprung truck?? He's in a 3rd gen.:confused:
    Scooter73 and Cpl_Punishment like this.
  26. Jun 16, 2022 at 12:27 PM
    #56
    Cpl_Punishment
    Neil
    2020 MGM SR5 CM 4X4
    Don't waste your time with that troll and his terrible "advice".
    Wahayes[QUOTED] likes this.
  27. Jun 16, 2022 at 2:05 PM
    #57
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
    OP, think twice if you want new springs. Unless you’re planning on a lift or something, why ruin your unloaded ride? You want help with towing, why add rougher springs every other day of the week
    Cpl_Punishment and Wahayes like this.
  28. Jun 16, 2022 at 5:06 PM
    #58
    Silver17
    Eastern PA
    2017 TRD 4x4 Harrop SC
    As previously mentioned you should probably have 1000# WDH bars. Once the trailer is loaded up with your camping gear most of which will probably be biased toward the tongue, they will be spot on. My blue ox swaypro WDH with 1000# bars are perfect for my 32’ trailer which is about 6200 lbs dry.
  29. Jun 16, 2022 at 6:51 PM
    #59
    Wahayes
    Will
    2017 tundra limited
    Good looking truck.
  30. Jun 16, 2022 at 11:57 PM
    #60
    evergreenoffroad
    evergreenoffroad More Trees / Less Screens
    Garrett
    '22 LTD DCLB TRDOR
    Full Dobinsons IMS Suspension 35" Geolandar Tires Alucab Cabin Camper Prinsu Designs Roof Rack Rig'd UltraSwing
    If you're looking to add a little extra beef to the rear of your truck, we're happy to help. I've lifted my tundra 3" overall and am happy with the ride quality. If you're looking to do towing I might suggest heavier springs in the rear but otherwise, I've just created a kit for Tundra owners who want to lift the rear 3".
    https://evergreenoffroad.com/produc...-offroad?_pos=1&_psq=2022-tundra&_ss=e&_v=1.0
    Use coupon code "tundras.com" at checkout for a discount.
    Here's how the rear end will sit. Keep in mind I have a few overland decorations on my rear end so you might yield a bit higher lift on yours.
    =JSG= likes this.
