DIRTY SEVEN CLUB
Discussion in '2.5 Gen Tundras (2014-2021)' started by matictundra, Feb 18, 2019.
  1. Jun 15, 2022 at 1:36 PM
    #2071
    Trdwillie14
    Trdwillie14 New Member
    Billy
    2014 trd off road
    2.5 fox 2.5 ads triple bypass T/C uppers Nfab front bumper Westin rear Bajas Rci skids All pro sliders Icon rxt leafs Stt pros Method 701s 37 Mickey Thompson
    K02 37 fit with no chop. Mickey Thompson on the way should be here soon
  2. Jun 15, 2022 at 1:37 PM
    #2072
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    2017 Tundra Platnium
    Too many mods to come
    Looks sick! I scheduled my install for Monday.
    pvn.beluga and Trdwillie14 like this.
  3. Jun 15, 2022 at 1:44 PM
    #2073
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    Where'd you get your mickeys? Still cant believe I snagged some and they shipped lol
  4. Jun 15, 2022 at 2:39 PM
    #2074
    pvn.beluga
    pvn.beluga New Member
    Phuc (Phooc)
    Connecticut
    LOL! I'll have to try that myself when I start cutting more
    Now to take it out to a loading dock!!!
    reywcms likes this.
  5. Jun 15, 2022 at 2:42 PM
    #2075
    Trdwillie14
    Billy
    2014 trd off road
    Discount had 3 in PA and 1 in Az I was shocked
  6. Jun 15, 2022 at 2:43 PM
    #2076
    Trdwillie14
    Billy
    2014 trd off road
    It goes in next Tuesday for the pinch that’s the only thing that comes close but after that I’m way in the clear but as soon as they come in you got it
    pvn.beluga[QUOTED] likes this.
  7. Jun 15, 2022 at 2:44 PM
    #2077
    Shanet421
    Shanet421 (Semi) New Member
    San Diego,CA
    You guys are on 17s with what offset?
  8. Jun 15, 2022 at 2:55 PM
    #2078
    pvn.beluga
    Phuc (Phooc)
    Connecticut
    Not all, I'm running 18s on 12 offset.
  9. Jun 15, 2022 at 3:23 PM
    #2079
    Trdwillie14
    Billy
    2014 trd off road
    I’m on 17s with zero offset
  10. Jun 15, 2022 at 3:25 PM
    #2080
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    Will be on 17”s
  11. Jun 15, 2022 at 3:29 PM
    #2081
    Kur
    Kur New Member
    Mesa, AZ
    08, 5.7, Double Cab Tundra, White
    How much clearance do you have between your tire and the UCA? I can't really tell from the pics. Looks close, which makes me nervous because the wheels I just got are +35 offset. I've heard that +25 was the "sweet spot" but Method didn't make the wheels I wanted in a 17 with that offset. And I heard that 0 offset would cause a lot of rubbing issues, which doesn't seem to be the case with you.
    Makes me wonder if I'm going to need a spacer...
  12. Jun 15, 2022 at 3:36 PM
    #2082
    pvn.beluga
    Phuc (Phooc)
    Connecticut
    Don't think you'd want to get spacers... cause then you'll be 3 offset. And then you'll cut and cut and cut and then it'll finally fit without rubbing. :sawzall:
  13. Jun 15, 2022 at 3:39 PM
    #2083
    pvn.beluga
    Phuc (Phooc)
    Connecticut
  14. Jun 15, 2022 at 4:01 PM
    #2084
    Kur
    Kur New Member
    Mesa, AZ
    Well if I was going to do a spacer, it would only be a half inch spacer. That would get me pretty close to a +25 offset. But I only want to do that if necessary, because that would require changing out the wheel studs to longer ones.
    But if I did do a standard 1.5in spacer, that would bring me a -3 offset which is VERY close to 0. It's roughly only 1/8 of an inch further out than 0. And again, yours surprises me being 0 offset without even needing a BMC.
    I'd still like to know how far away your tire is from your UCA though.
  15. Jun 15, 2022 at 4:23 PM
    #2085
    Shanet421
    San Diego,CA
    I’m on 18s with +25 offset…I believe I am in the “sweet spot” as far as clearance goes. However the selection of 37s for an 18” wheel is not so sweet. I guess 40s…..
    tundra_20 and SAGE63 like this.
  16. Jun 15, 2022 at 4:34 PM
    #2086
    pvn.beluga
    Phuc (Phooc)
    Connecticut
    You're probably referring to @Trdwillie14, but I'm running 12 offset. My offset required PWM, very aggressive BMC (I haven't plated yet), and trimming my bumper caps.
  17. Jun 15, 2022 at 4:47 PM
    #2087
    Trdwillie14
    Billy
    2014 trd off road
    Yah maybe I have a bmc and doing a pretty aggressive pinch. But I’m pumped it clears as is.
  18. Jun 15, 2022 at 4:54 PM
    #2088
    SAGE63
    San Diego County
    method trail series has +25 I have the 701 18" +25 rims. need to know how much more I need to do. hsve PWM and A decent BMC. wish I could find someone with close to true 37"s on +25 so I could do a test fit before I buy the 18" 37x12.5 or 13.5
    All the 37s I know are on +0 17s
  19. Jun 15, 2022 at 4:54 PM
    #2089
    TownTRD
    TownTRD New Member
    Cris
    Bay Area, CA
    2020 Army Green TRD PRO CM
    Almost there.
  20. Jun 15, 2022 at 4:56 PM
    #2090
    pvn.beluga
    Phuc (Phooc)
    Connecticut
    Now you just gotta get the tires and slap them on. Can't do much until you do that step. You can guess all you want about clearance and what not, but all of our trucks will run slightly different from one another.
    SAGE63[QUOTED] and reywcms like this.
  21. Jun 15, 2022 at 5:01 PM
    #2091
    Trdwillie14
    Billy
    2014 trd off road
    Also depends what your gonna do. With zero offset I would never go hardcore of nuts on this set up u may cause a little fender issues lol
    SAGE63[QUOTED] likes this.
  22. Jun 15, 2022 at 5:05 PM
    #2092
    SAGE63
    San Diego County
    my BMC and PWM. I have A C4 overland bumper so not worried there 3" lift
  23. Jun 15, 2022 at 5:06 PM
    #2093
    eccracer104
    eccracer104 Dirty Paws Off-Road
    San Diego, CA
    2011 Tundra 5.7 4x4 CM
    Here’s 37x12.5x17 with 17x8.5” methods at 0mm offset.
    (don’t have a tape measure handy but here’s a key for scale - not at the widest part though)
  24. Jun 15, 2022 at 5:08 PM
    #2094
    SAGE63
    San Diego County
    dont forget you have the icon billet UCAs so that helps a bit too on the clearance
    eccracer104 likes this.
  25. Jun 15, 2022 at 5:09 PM
    #2095
    eccracer104
    San Diego, CA
    Did you have Jason do it? Looks really clean!
    tundra_20 likes this.
  26. Jun 15, 2022 at 5:10 PM
    #2096
    SAGE63
    San Diego County
    I sure did!!!!
  27. Jun 15, 2022 at 5:11 PM
    #2097
    eccracer104
    San Diego, CA
    Totally. I know it’s more for clearance on the body mount, but the “thickness” (for lack of a better word) could play a roll in clearance. I’d imagine max of like 1/4” change between these and a UCA that sticks out more.
  28. Jun 15, 2022 at 5:12 PM
    #2098
    CrunchTimeHD
    CrunchTimeHD New Member
    Louis
    Easton Pa
    2011 tundra limited CrewMax
    I'm on 37x13.5 and I have no rubbing in the front and very little rubbing in the rear at full flex.Screenshot_20220615-201045_Gallery.jpg
  29. Jun 15, 2022 at 5:12 PM
    #2099
    SAGE63
    San Diego County
    so waiting on LK to rebuild the Icon 3.0 coilovers and 2.5 omega rears. debating if I should keep the built right UCAs or get the billet ICONs... btw I have a set of the Icon tubular delta joints too just missing a nut for one of the DJs came with the shockd from Joon
  30. Jun 15, 2022 at 5:20 PM
    #2100
    pvn.beluga
    Phuc (Phooc)
    Connecticut
    This is the clearance I have between SPC and my Toyos.
