Wrong rear axle assembly replacement on 2006 4.7 Tundra
Discussion in '1st Gen Tundras (2000-2006)' started by wTundra_1713WTundra06, Jun 12, 2022.
  1. Jun 12, 2022 at 1:36 PM
    wTundra_1713WTundra06 [OP] New Member
    Biill
    I had a mechanic(?) in my neighborhood replace the complete rear end assembly with a used assembly-differential, axles, wheels. Somehow the case on the original rear end cracked. The assembly he used was non-abs and the original was abs. Anyone have info on what would be involved to at least get my speedometer working? (cruise would be nice too, but not that necessary) I can live without the abs.
    Thanks in advance
  2. Jun 12, 2022 at 9:04 PM
    NickB_01TRD
    KY
    01 Tundra V8 4X4 AC SR5 TRD
    Only way for abs is to get an ABS axle I believe or at least axle shafts maybe. Probably a bit of work.
    Thought the speedo ran off the transmission (or tcase maybe) though anyway. Hopefully someone else will chime in.
