  1. Jun 8, 2022 at 8:07 AM
    #661
    MTundra87
    MTundra87 New Member
    Bozeman, MT
    22 TRD OR
    Yea, unfortunately it's drilled into the bumper on mine. No big deal as we have to use a front license plate in Montana, but annoying for states that don't.
  2. Jun 8, 2022 at 10:52 AM
    #662
    Maharisc
    Maharisc w/Patty
    Karl
    Build date: 12/05/22
    Yea, I wish we could do away with it, just down the road from you, MTundra87, in Billings.
    MTundra87[QUOTED] likes this.
  3. Jun 8, 2022 at 1:03 PM
    #663
    MMTundra
    MMTundra New Member
    2022 Army Green TRD OR Ltd
    Just got my Westcott preload lift installed, new wheels/tires and alignment! Truck is a Limited TRD OR, have blacked out all the chrome minus the mustache. Wheels are Method 316s (18x9, +18 Offset) and tires are GY Duratracs (285/75R18). I went ahead and installed a full size spare and it fits if anyone's wondering.
    Chose this setup for weight, wheels are only 27.9 lbs and the Duratracs are about 62 lbs which is on the light to moderate end of the spectrum for the size - goal was to be 90 lbs or below, so I'm right there. Other goal was to find a larger 285/75r18 (these are 35.1") and avoid a true 35x12.5 to reduce poke and (maybe) have some better performance in the snow.
    Almost no noise added, and call me crazy but I think the handling has improved over stock. Love it. Now I need to install the RB20 steps. I'll try and get some more pics once I do that.
    If anyone's interested in the takeoffs, they are the 20" black TRDs with Wildpeaks, let me know. Only 270 miles on them and I'm in CO (Denver area). I will probably do a separate post for those too.
  4. Jun 8, 2022 at 1:09 PM
    #664
    MTundra87
    Bozeman, MT
    22 TRD OR
    Wouldn't that be nice! I see you bought at Ressler ... they're great over there. I originally ordered through them, but the truck was taking forever so I ended up running over to Oregon for mine.
  5. Jun 8, 2022 at 1:57 PM
    #665
    Troa
    Troa I blue it again.......
    Nomad
    2022 Blueprint Limited
    I played in the mud. Haven't seen many dirty pics yet. Everyone keeps them so clean and shiny!
  6. Jun 8, 2022 at 1:59 PM
    #666
    Troa
    Nomad
    Oh, I also just tinted the tails and 3rd brake light (VVivid Light Smoke Air Release)
    Before:
    After:
    Tundra'25 and jmay86 like this.
  7. Jun 8, 2022 at 2:46 PM
    #667
    wayoflife
    wayoflife Exploring Cascadia and beyond
    Seattle-ish, WA, USA
    '22 1794 6.5' TRD Offroad Blueprint/Cream
    Westcott 3/1 Method 705 18x9 18mm Maxxis RAZR 295/70R18
    Got my real license plates on and still need to remember to remove the paper from the rear window.
    "I'm a real boy!"
    Henry1jg and frichco228 like this.
  8. Jun 8, 2022 at 3:57 PM
    #668
    jmay86
    jmay86 New Member
    Josh
    Columbus, Ohio
    '22 Lunar Rock LTD DC TRD-OR
    Pretty easy job on the tails? I’ve heard that air release variety is easy to work with…
  9. Jun 8, 2022 at 4:05 PM
    #669
    Troa
    Nomad
    I used to work for a tint shop and have applied tons of vinyl in my life. I COULD NOT for the life of me get the tails to come out right. I ended up paying a shop $200 to do it.
    The problem is that the lights curve up on top as well as make a 90 degree turn along the sides of the lenses. It requires a relief cut and has to be seamed so it's a bit above my pay grade.
    There is a small gap in the seam (1-2mm) that can be seen from up close if you're paying attention and a small bubble where the injection molding point is. Not terrible, but not perfect either. The film also has a bit of "snakeskin" effect to it from the air release pattern
    If I had to do it again I would stick with VHT Nightshades, which is what I usually do. I wanted to give the film a shot this time around in case I didn't like it and couldn't get it off or get replacement lights with all the parts back orders.
    Tundra'25 likes this.
  10. Jun 8, 2022 at 4:13 PM
    #670
    jmay86
    jmay86 New Member
    Josh
    Columbus, Ohio
    Right on. Thanks for the pics and info... I'm planning to try my hand at wrapping for the first time on my handles, bumper and grill pieces once my truck arrives... Figured $80 for the vinyl is worth the gamble to potentially save hundreds... Time will tell...
    Troa[QUOTED] likes this.
  11. Jun 8, 2022 at 4:55 PM
    #671
    Troa
    Nomad
    10/10 would not recommend trying the tails then. The mustache will most likely require 3 pieces. The rest I think can be done in one piece each
    jmay86[QUOTED] likes this.
  12. Jun 8, 2022 at 5:07 PM
    #672
    jmay86
    jmay86 New Member
    Josh
    Columbus, Ohio
    you're talking 1 piece for the stache, and 1 each for the bottom stache/mid bumper pieces? or 3 parts for just the top stache?
  13. Jun 9, 2022 at 10:11 AM
    #673
    hivetyrant
    hivetyrant New Member
    2022 Limited Tundra
    Cat plate from talons garage installed. Pretty easy by myself and I’m a weakling!
  14. Jun 9, 2022 at 12:56 PM
    #674
    SoCalJose
    SoCalJose New Member
    Looks good! Whats the part number??
  15. Jun 9, 2022 at 6:26 PM
    #675
    jdub22
    jdub22 New Member
    Not a fan of stickers... so these hit the road today.
    I just cold peeled them and they both came off pretty easy with a little patience. Cleaned then waxed and they were never there.
    Badges are next.
  16. Jun 10, 2022 at 6:44 AM
    #676
    BlueRibbon4x4
    Geno
    2015 Blue Ribbon 4x4
    Looks great! How’s the ride on the Pro comps?
  17. Jun 10, 2022 at 10:16 AM
    #677
    MTundra87
    Bozeman, MT
    22 TRD OR
    Repeat of post in toppers thread, but installed a 2014-2018 Chevy/GMC 6.5 topper and it fits pretty dang well. Has some over hang as you can see in the mirror, but really happy with it overall. Perfect until I can order something more utilitarian next year. We are visiting Denver this weekend and Chris over at Suburban Toppers was unbelievable to work with. Super helpful and went extra mile to fit as good as possible.
    Lift goes on next week!!
    Tundra'25 and hairychestedfrog like this.
  18. Jun 10, 2022 at 2:45 PM
    #678
    hasselhof
    hasselhof New Member
    im very happy with them. Smoothed out the ride after adding the e rated tires. Really negated the harshness of the 10ply tires over all the chip seal and absolute garbage roads we have here. Haven’t taken them on any real deal off-roading though, only LI beach trails.
    I know pro comp isn’t as highly regarded as the other bougie brands, but seemed just as quality as the fox setup I had on my f150 in my hands. I guess time will tell in that regard.
  19. Jun 10, 2022 at 3:34 PM
    #679
    BlueRibbon4x4
    Geno
    That’s awesome. I was a little concerned about not seeing many reviews here, but I haven’t seen any negative ones. I don’t have a 3rd gen, but I found some very inexpensive brand new pro comp coilovers for my 2.5 gen. Thanks for the reply!
  20. Jun 10, 2022 at 3:48 PM
    #680
    MRQZTNDR93
    MRQZTNDR93 New Member
    San Diego CA
    2022 TUNDRA SR5 TRD OFF ROAD
    no i was able to get them the next day easy installing too I left that center bracket how it is since the middle finisher covers it
  21. Jun 10, 2022 at 4:15 PM
    #681
    PapaDave418
    PapaDave418 A Dude who knows a Dude
    Dave
    North Idaho
    3rd Gen Limited TRD
    37’s—PullKitchen--KB Voodoo Rack & Full Ext Cargo Tray
    Got my @KB Voodoo gear lockers in today, I love the modularity of the rack. I opted for the lockers and the cargo tray
    DE320F3D-A702-4CB9-BA46-6AF972C1C312.jpg 2BB287D5-8A67-4169-86CD-A472A200BF04.jpg
    Cargo tray and 22” rack without the lockers or Rotopax on yet
    RookieEP and KB Voodoo like this.
  22. Jun 10, 2022 at 8:33 PM
    #682
    Leboxerdog
    Leboxerdog New Member
    2022 tundra SR5 TRD Off road- midnight black
    how much did they charge ?
  23. Jun 13, 2022 at 8:15 PM
    #683
    KB Voodoo
    KB Voodoo New Member
    Chad
    2017 Tundra Pro Crewmax, Cement
    Many KB Voodoo Fabrications accessories!!
    Well don’t tease us, post some pics!!
    PapaDave418[QUOTED] likes this.
  24. Jun 14, 2022 at 6:58 AM
    #684
    PapaDave418
    Dave
    North Idaho
    3rd Gen Limited TRD
    Got my gear lockers for my new ProMax rack installed. @KB Voodoo makes some seriously quality stuff. My plan is to haul recovery gear and tools in these lockers which will open up space in my bins and tool box. Lockable and weather resistant, plus I’m going to add lights inside for nighttime. Cargo tray is a must, and the new iKamper 3.0 is nice
    This is the rack unloaded1453B630-CA0F-42E4-9F25-3884E2EA21BA.jpg7FD25DC3-50B2-4E51-9882-A54EA2BB0D81.jpg247B0D51-4FAC-4677-8983-D26A1F1F3F6E.jpgB50BE73C-6668-4F26-9066-E33BE6C99A56.jpg5FABDBBE-8EF6-4FD9-A03F-A3E16DC57434.jpg11D34EAA-AABA-4F36-972D-E514FDECC8CA.jpg
    Still need to add lights, Rotopax, and miscellaneous gear to it
    in_the_mud, oxlsu40, ToyoMon and 2 others like this.
  25. Jun 15, 2022 at 8:07 PM
    #685
    MTundra87
    Bozeman, MT
    22 TRD OR
    Installed the Westcott 3/1 today with 18” OZ Rally Raid wheels (+27) and 35” KO2’s. Starting to come together.
  26. Jun 15, 2022 at 8:16 PM
    #686
    jmay86
    jmay86 New Member
    Josh
    Columbus, Ohio
    Looks good... Camper info?
  27. Jun 15, 2022 at 8:23 PM
    #687
    MTundra87
    Bozeman, MT
    22 TRD OR
    Thanks! It’s actually from a 2014-2018 Chevy/GMC 1500. It’s not perfect, but getting the job done until there’s some options for the 3rd Gen.
  28. Jun 15, 2022 at 8:30 PM
    #688
    Medic343
    Medic343 5+4+3=2
    Kenny
    New Mexico
    '22 SR5 TRD off-road
    Great looking truck! At first glance on the picture from the rear...with the angle of the shot, the body lines on the rear fender, and the reflection on the paint makes it look like a dually lol
  29. Jun 15, 2022 at 8:46 PM
    #689
    jmay86
    jmay86 New Member
    Josh
    Columbus, Ohio
    Sorry, I was referring to the Opus haha... Have always heard good things, wondered what model you had?
  30. Jun 15, 2022 at 10:01 PM
    #690
    MTundra87
    Bozeman, MT
    22 TRD OR
    Haha oh my bad. That’s the OP15. We just recently picked it up and are loving it. First extended trip next week!
