Wheel torque specs?
Discussion in 'Wheels & Tires' started by boardude, Jun 14, 2015.
  1. Jun 14, 2015 at 11:20 AM
    boardude
    boardude [OP] I am Batman
    Kris
    Tucson, AZ
    [YODAGAN]
    2015 Inferno Ex-Pro
    Anyone know the torque specs for the TRD aluminum wheels? The owners manual says 154 ft/lb but I think thats for the steel spare tire. I think the aluminum wheels are 97 ft/lb but really cant find anything in any of the forums.
  2. Jun 14, 2015 at 12:11 PM
    chphilo
    chphilo Tundra addict
    Western PA
    2010 Toyota Tundra TRD 5.7 4x4 CM
    That's correct. 97 ft-lb for Aluminum wheels and 154 for steelies.
  3. Jun 14, 2015 at 12:28 PM
    boardude
    Kris
    Tucson, AZ
    [YODAGAN]
    2015 Inferno Ex-Pro
    Thank you sir!
  4. Jun 14, 2015 at 4:26 PM
    Rkcruza
    Rkcruza New Member
    Bob
    2002 Tundra AC 4WD TRD OR SR5
    De Badged / Decaled, Firestone Ride Rite Air Bags w/ Daystar Cups, 17" Rims, Big Brake kit w/ slotted & drilled rotors, plus lots of work related stuff.
    I've got 95# written down in the shop so the 97# should be it as they give a range of about 5# or so.
  5. Sep 15, 2022 at 7:06 AM
    hessler
    hessler New Member
    2017 Tundra SR5 TRD Offroad
    So far: LineX bed liner Future: Retrax bed cover, Helwig Rear Sway Bar
    I initially thought the torque was 154# ofor my Tundra and used that for years to set my torque wrench. A guy at the dealership set me straight. Meh, since the techs use air wrenches to tighten the lug nuts I don't think I did much harm compared to what they would have. I tried to loosen a lug nut on my wife's Highlander they had tightened and I couldn't do it by jumping up and down on a 2' breaker bar. I took it back and had them redo it with my torque wrench set to her specs. At least we can change a tire on the side of the Interstate while 16 wheelers zip by.
  6. Sep 15, 2022 at 7:11 AM
    Bergy24
    Bergy24 New Member
    97lbs is correct. I set my wrench to 100 and call it close enough. When I swapped over to my PRO wheels, I had a hard time taking loosening the lugs the dealer installed when they installed my new steering rack. Ended up using a Milwaukee Impact gun to get them loose.
