TRD dual exhaust - detailed installation
Discussion in 'Performance and Tuning' started by Netmonkey, Mar 18, 2017.
  1. Apr 3, 2019 at 8:30 AM
    #121
    Tundradrenalin
    Tundradrenalin New Member
    Virginia Beach, VA
    2016 DC Black TRD nonPRO
    Methods, Toyos, Kings, TCs, CBs
    Toyotoholic likes this.
  2. Jun 29, 2019 at 12:18 PM
    #122
    Hammerdog
    Hammerdog YCMTSUP
    Robbie
    Louisa VA
    2018 tundra sport crew max
    Tint Bed cover Red Tow Hooks TRD Intake 7 inch BDS 22x12’s 35 Toyo’s Rigid ditch lights RC light bar in bottom grille One bad ass stereo
    Anyone know if a 7 inch BDS lift will interfere with the install? Parking brake lines , etc, going to put mine on tonight when the sun goes down.
  3. Aug 23, 2019 at 11:12 AM
    #123
    newguy
    newguy New Member
    2016 CM TRD off road limited.
    TRD Dual Exhaut TRD Pro wheels BFG KO2 275/70/18 GoRhino RB20s Blacked out tail lights Bilstein 6112/5160 combo Coach builder +1 in the rear
    Which product does the heat shield and hangers come with for the TRD dual exhaust? The muffler section? Or the exhaust tips section?
    Someone is going to sell me their muffler section that has never been installed and I want to make sure all the parts are there.
  4. Aug 23, 2019 at 11:28 AM
    #124
    Makoy339
    Makoy339 Simplicity = Reliability !!!
    Super White TRD
    TRD parts
    Heat Shield is for the muffler section.
    Both muffler and dual tips section have hangers.
    newguy likes this.
  5. Aug 23, 2019 at 12:24 PM
    #125
    Tundradrenalin
    Virginia Beach, VA
    You don't really need the heatshield. So if it's not included, it's not a huge loss. The hanger is available separate for about $40.
    newguy likes this.
  6. Sep 8, 2019 at 11:36 AM
    #126
    newguy
    newguy New Member
    Anyone get a little smoke coming out of their TRD exhaust after installing?
    Rica25 likes this.
  7. Sep 8, 2019 at 11:48 AM
    #127
    RLHULK
    RLHULK Too many gamma rays in all that BBQ smoke.
    Rich
    2022 Silverado LT.
    Still rolling stock baby....
    Yup had a pretty sized cloud of smoke roll out from under my truck on the interstate about 8 miles from the dealership, looked like I was driving down a dirt road for a few seconds then it went away, all was good. I figure it was a coating burning off to prohibit rust or some crap.
  8. Nov 5, 2019 at 6:05 PM
    #128
    AmericanAlpha
    AmericanAlpha New Member
    Kyle
    Oklahoma
    2019 Cement Blackout Tundra TSS Off-Road
    TRD Shift Knob Center Console Shelf Door Trim Protectors TRD Dual Exhaust - Black Tip TRD Cold Air Intake Toyota Weather Liners
    Dude, thanks so much for this. It really made things so simple.
    Just installed this on my 2019 along with the intake. Sounds freaking amazing. I called toyota just to see and they quoted me 6 hours to install just the exhaust. Give me a break. It took me 3 hours on the dot and the intake took about 45 minutes.
  9. Feb 16, 2020 at 7:46 PM
    #129
    multimile
    multimile New Member
    2020 Crewmax Cement
    As others have said, thanks to the OP for starting this thread. I used it this afternoon for reference while installing the dials. Made the install easy, even without a jack or lift.
    Indychamp likes this.
  10. Feb 16, 2020 at 9:41 PM
    #130
    georgiey22
    georgiey22 SW Idaho
    2019 Tundra | TRD Sport | Cavalry Blue | Crew Max
    Hello all. Need some help just to be certain.
    I have been given the TRD Exhaust tail piles with chrome tips from my best bud. He tracks his S/C’d Tundra and had to remove the TRD pipes when he lowered his truck. He gave them to me!
    Now I need the TRD muffler. I see that part number in this thread, will order this week. Next, I will also order a new hanger, just to be certain the TRD pipes hang exactly the same on both sides. Appears a new rubber hanger is around $40.
    Where I need help...
    01| Do the new TRD exhaust gaskets ship with the TRD muffler or the TRD pipes? If it is with the muffler I do not to order separately.
    02 | Does the heat shield ship with the TRD muffler or the TRD pipes?
    03 | Any thing else recommended that I order, so it’s all done and once and the install goes smooth?
    Best,
  11. Feb 17, 2020 at 5:15 AM
    #131
    Netmonkey
    Netmonkey [OP] Don't be a Dumbass
    Georgetown, TX
    the parts box comes inside the tail pipe box. so, you will need to order the heat shield, gaskets, and hangers separately.
    here are the part numbers for the gasket kit and the hanger kit:
    gasket kit: PTR03-34104
    hanger kit: PTR03-34103
    However, I am not sure what the part number for the heat shield is.
    That is everything that you need.
    good luck :)
  12. Feb 17, 2020 at 6:33 AM
    #132
    multimile
    2020 Crewmax Cement
  13. Feb 17, 2020 at 6:53 AM
    #133
    georgiey22
    georgiey22 SW Idaho
    Thank you.
    Netmonkey[QUOTED][OP] likes this.
  14. Mar 22, 2020 at 6:40 AM
    #134
    MMA Lover28
    MMA Lover28 New Member
    NY
    2018 Barcelona Red 5.7l V8 tundra sr5 doublecab TRD offroad. 4x4
    1.TRD dual exhaust 2. K and n drop in oiled panel filter 3. Tonneau tri fold hard top 4. 6" antenna carwash proof 5. Weather tech floor liners 6.Weather tech window liners 7. Front windows tinted to match 8. Matt black tailgate decal insert 9.Front and rear dashcam full 1080 hd infared cams with motion and g force sensors, 120fps and 64g sd memory. 10. Backup battery 5000ah (blackboxmycar.com) (Weathertech.com) (Realtruck.com) (Sparkparts.com) (Toyota.com/parts/TRD) (KNfilters.com) (Lexan ceramic auto tints@ amazon.com) (ToyotaOEM/tundra/badgeoverlay) (Antenna found on (amazon.com)
    Amazing install instructions and pictures!! I got the TRD cat back dual for my truck, and would you know that toyota "welded" the nuts by the cats. So of course they needed to be removed using a oxygen torch..naturally watching so many of these do it yourself videos on youtube no one speculated that they might be welded at the cats. I duno who did that or why, as i got the truck with 10k miles on it...anyone else have that issue??
  15. Mar 22, 2020 at 6:48 AM
    #135
    MMA Lover28
    NY
    Heat shield and gaskets for the muffler to tailpipes are included as well as hanger for the left side. What is NOT included is TRD gaskets from the catalytic to the muffler pipes. You can reuse those if your truck is fairly new. Also i went to toyota to get a new hanger for my original side muffler pipe due to the fact that it was stretched exponentially, so buying a new one helped the pipes sorta level out in back.
  16. Mar 22, 2020 at 6:55 AM
    #136
    toyofan87
    toyofan87 Beer thirty
    Seth
    Gettysburg, Penna
    Congrats and well done..
  17. Apr 6, 2020 at 5:43 PM
    #137
    pgilparra
    pgilparra New Member
    where did you order it from? all i keep finding online are MBRP, magnaflow. etc. toyota sales told me the TRD exhaust is only sold to Pro owners. ‍♂️. i got a 2017 SR5 off-road
  18. Apr 6, 2020 at 7:29 PM
    #138
    Netmonkey
    Georgetown, TX
    i walked into the parts department and ordered the exhaust.
    @Roman should be able to help you.
    Roman likes this.
  19. Oct 20, 2020 at 5:15 PM
    #139
    DMV_Tundra
    DMV_Tundra New Member
    2021 Tundra Limited, Nightshade Magnetic Gray Tu
    Window Tint, TRD Dual Exhaust
    Wish I had seen this before I did mine lol. Although I will say it was pretty straight forward . Love the sound.
    Netmonkey[OP] likes this.
  20. Nov 7, 2020 at 3:15 PM
    #140
    pop's
    pop's 1794
    Michael
    North Aurora IL
    2017 Tundra 1794 Blue Pearl / 1995 T100 4x4 DX
    $7500 in upgrades
    If you order this through your local Toyota dealer you will $ave the shipping fees.
  21. Nov 7, 2020 at 4:08 PM
    #141
    Rob's Inferno
    Rob's Inferno New Member
    2017 SR5 crewmax 4x4 Inferno
    Can the bolts that connect the cats to the muffler section be bought from Toyota or just buy good stainless bolts? After 2 winters my bolts at the cats are so rusted they look like they're 20 years old already and im sure they will break off.Also for all of those in salt country,how does the TRD exhaust look after a good salty winter? From what ive seen the pipes rust like crazy ( not acceptable) for a $1300 exhaust compared to the stock single exhaust.
  22. Apr 24, 2021 at 11:10 AM
    #142
    Appalachian_Gargoyle
    Appalachian_Gargoyle New Member
    Josh
    2021 Cement Tundra Ltd
    Thanks for the instructions. Got my buddy's after he decided to go custom fairly soon after purchasing his new truck. Install was about 1:30 while being interrupted due to a pork butt being smoked! Son and I had a good time doing this install and the test drive, well both our faces lit up!
  23. Apr 24, 2021 at 11:39 AM
    #143
    Raggedy_Man
    Raggedy_Man Gandalf The Gray
    Mark
    Sacramento, CA
    2020 Platinum CrewMax Magnetic Gray
    I added the black tip version to mine, but too lazy to do it myself, so had Toyota do it. About $350 in labor. Love the sound and look. Not obnoxious
  24. Aug 13, 2021 at 9:29 AM
    #144
    Marco
    Marco New Member
    I installed mine. Really easy. Remove spare tire. If not on lift. Driver side hanger hardware rivet.in pilot hole. Notch frame.
    35 ft torque for bolts. Easy as 3.14
  25. Aug 18, 2021 at 6:33 PM
    #145
    PapPap
    PapPap New Member
    Tennessee
    2021 TRD Sport
    Excellent detailed post! It inspired me to install the exhaust on my 2021 sport. I did it with a couple of borrowed ramps. I did it by myself and didn't need any straps except when I took the muffler off. I strapped it but the hangers allow for release. As long as you use the hangers when installing you won't need any support. It really was simple. Thank you so much for taking the time to go into so much detail. Btw, it took me 1.5 hour start to finish and I only looked at your instructions once to make sure the original muffler clamp did not have to be reinstalled. It didn't as far as I could tell. Thanks again!!!
  26. Sep 13, 2021 at 8:18 AM
    #146
    normagene
    normagene New Member
    Normagene
    New England
    2021 Cement DC Limited Texas Edition
    Texas Edition
    Excellent instructions and tips. I feel I can attempt this myself.
  27. Sep 13, 2021 at 2:11 PM
    #147
    PapPap
    PapPap New Member
    Tennessee
    2021 TRD Sport
    When youre done you'll be pleasantly surprised at how easy it was, and a bit gratifying.
    normagene[QUOTED] likes this.
  28. Sep 21, 2021 at 2:14 AM
    #148
    sabet
    sabet New Member
    Do you have part number for hanger on original side and gasket from catalytic to muffler pipes?
    It looks like PTR03-34103 is for Left Hand(driver side) only. I’d like to replace original gasket instead of reusing as well.
    Thanks,
  29. Oct 22, 2021 at 7:17 PM
    #149
    Beastmode1
    Beastmode1 New Member
    Pete
    Excellent work splendido!!!!!
  30. Jun 3, 2022 at 12:23 PM
    #150
    Tundra694
    Tundra694 New Member
    AJ
    2021 Tundra Crew Max Trd Off Road
    This post was very helpful. I got a Trd system for $50 used !! Painted it up and got it on today along with Trd anti roll bar. Install was seamless. Perfect mix of tone but not too much.
