Boat Owners BS
Discussion in 'Fishing' started by ToyotaTundraMike, May 17, 2016.
  1. Jul 1, 2021 at 8:43 PM
    #271
    Dalandshark
    Dalandshark Infected with 5G
    Northwest
    2007 Tundra SR5 5.7 Longbed
    Eibach Level LIft
    Hey guys. Trying to figure out a new prop for my Honda 9.9 on a 15’ Smokercraft Alaskan. Currently has a 3 blade 9 1/4 x 8 stock aluminum. Boat moves plenty fast for a 9.9. However, it takes a little work for it to plane with my family on board.
    - will a stainless steel of same size help with the “hole shot”? I don’t want to lose any speed, and I don’t want to make the problem worse.
    - will a stainless of the same size give a little more speed but do nothing with hole shot?
    -other opinions?
    Thx.
  2. Jul 1, 2021 at 9:03 PM
    #272
    Brown Bear
    Brown Bear New Member
    Nor cal
    03 TRD offroad
    -6" RCD lift in front. -Custom leaf springs in rear 4" lift. -17" race line, raptor wheels. -35" Goodyear Duratrac. -4.88 gears. -ARB rear air locker. -ARB air compressor and tank. -Custom front sway bar quick disconnect -Custom one piece driveshaft -Black Oak Led 40 watt ditch lights.
    I don't think a ss prop will help. That's more for big hp motors. I don't think the prop on a 9.9 is spinning fast enough to cause flexing in a aluminum prop. A 4 blade will give you a better hole shot but you will lose top end. If you go with a prop with to much higher pitch you could lose rpm witch means less speed. I'm not positive about the Honda but other outboard brands have several different hp ranges on the same platform. For instance I just took shipment ofa new suzuki 20hp today. This motor is the same platform as the Suzuki 9.9hp and the 15hp. There is just a few parts that are different. Computer, intake etc. You might get more bang for you buck if you can bump up the hp. This would require some research on your motor and year.
    Badknees and Dalandshark[QUOTED] like this.
  3. Jul 1, 2021 at 9:31 PM
    #273
    Dalandshark
    Northwest
    Eibach Level LIft
    Yeah I looked into that a while back and I believe the bf8/9 are same displacement but bf15 has bigger displacement. Mine is a 2014… I think there is a misconception with the Honda’s that the throttle is governed to hold back 5hp… but with different cylinder size your not going to make them the same. Don’t remember the details but it wasn’t cost effective.
    I may end up using this motor for a sailboat and finding a good used 20hp for the smokercraft… 15 would be an improvement but I think a 20-25 would be good, especially if it was a lighter Yamaha.
  4. Jul 30, 2021 at 7:23 PM
    #274
    Velocity72
    Velocity72 New Member
    Upstate SC
    2021 Platinum
    AEA0E4DB-81D6-443D-B65F-AD2B2F7F3B67.jpg 8F37CA23-3FE4-42A0-892B-F608AE6D7151.jpg
    A boating thread on Tundras.com. Trucks and boats, what could be better!
    Been boating all my life. On the water is always the best place.
    The current boat is an Alumacraft 18.5’ bass boat with a 115 Yamaha. Stable, pretty fast, fishes well and also pulls the kids well kneeboarding or tubing. Pictures are from Kerr Lake in NC, camping at one of the state parks with family. I was actually able to launch the boat at the campsite on the sand. Didn’t even need the boat ramp!
  5. Jul 30, 2021 at 7:30 PM
    #275
    gosolo
    Ray (or maybe Dale)
    NW Oregon
    Here’s a quick question for y’all;
    I am looking for a long shaft 4stroke trolling motor, around 8-10hp. A new Honda would be about $2,400.00. I hope to find a decent used one for 1/2 that.
    I live up in the upper nw corner of Oregon. If you have any good leads, please pm me
  6. Jul 30, 2021 at 8:05 PM
    #276
    Zilla18
    Zilla18 New Member
    Scott
    Richmond, TX
    18 SR5 CM TSS Offroad
    New 17 footer for me and my boys to hit up some local bass spots...
  7. Jul 30, 2021 at 8:37 PM
    #277
    ToyoMafia
    Magic carpet.
    Cool slaps and plastiDip
  8. Jul 30, 2021 at 8:38 PM
    #278
    Outbound
    Aaron
    Northern Alberta
    Mmmm, triple 300 Yammys. So much sex...
  9. Jul 30, 2021 at 8:41 PM
    #279
    ToyoMafia
    Magic carpet.
    Lots of lube
  10. Jul 30, 2021 at 8:43 PM
    #280
    ToyoMafia
    Magic carpet.
  11. Aug 15, 2021 at 6:38 PM
    #281
    Dalandshark
    Northwest
    Eibach Level LIft
    CBC86C8D-DCA0-476E-BBF9-43FD219F6F25.jpg Sold the Smokercraft. Someone bought through consignment for 8500.00, from which I recouped what I had paid for the boat minus a few accessories.
    :spending:
    Went to Langley for our first overnight in the Con-pac 23-2.
  12. Aug 15, 2021 at 6:53 PM
    #282
    Blang805
    Blang805 New Member
    Central Coast California
    2010 CrewMax Platinum 4x4
    Build in Signature
    I have myself a 1974 Sears GameFisher powered by a 1986 Johnson 15hp e-start and a Minn Kota Terrova.. Awesome little local lake hopper.
    The Terrova was put on recently and I've only been able to go fishing twice since the new install :annoyed:
  13. Aug 15, 2021 at 6:59 PM
    #283
    BayRunner
    BayRunner I’m here, except when I’m not
    2017 Tundra Platinum
    Congrats on your sale.
    Yup, it’s a sellers market. I sold my 30 year old Large boat for nearly what I paid for it 8 years ago.
  14. Aug 16, 2021 at 9:08 AM
    #284
    withoutapaddle
    withoutapaddle New Member
    2016 Tundra SR5 Magnetic Gray
    Sellers market is a huge understatement, I sold my 91 Rinker cuddy for $10k. I purchased it for $6600 in 2017. Not bad for 5 years of boating.
  15. Feb 5, 2022 at 1:12 PM
    #285
    Pac12AfterDark
    Pac12AfterDark New Member
    Finally winterized it last weekend.
  16. Feb 10, 2022 at 7:02 AM
    #286
    Njmike13
    Njmike13 New Member
    Hunterdon county, NJ
    2021 PRO Lunar Rock
    I wish! My boat was winterized and wraped mid October. Can't wait to get back out. Won't unwrap till the end of march.
    Prostar 190 and Cpl_Punishment like this.
  17. Feb 10, 2022 at 7:32 AM
    #287
    Pac12AfterDark
    Yeah I usually start fishing in April.
    Boat show this weekend. This year I am coming prepared already got quotes on what I have been drooling over for half a decade.
  18. Feb 10, 2022 at 7:52 AM
    #288
    Cpl_Punishment
    Neil
    2020 MGM SR5 CM 4X4
    My dad's stays on the driveway from September until June. :(
    Prostar 190 likes this.
  19. Feb 10, 2022 at 7:55 AM
    #289
    Njmike13
    Njmike13 New Member
    2021 PRO Lunar Rock
    terrible
  20. Feb 10, 2022 at 8:02 AM
    #290
    That's horrible.
  21. Feb 10, 2022 at 8:05 AM
    #291
    Njmike13
    Njmike13 New Member
    2021 PRO Lunar Rock
    Do you ice fish? At least you have that. NJ winters are the worst. Cold no snow and not enough ice so you can't do anything but wait for spring.
  22. Feb 22, 2022 at 11:50 AM
    #292
    BayRunner
    Man, this Covid crazy and boat prices are out of control. Just got an email from the boat dealer I bought my boat from in ‘19 saying they just got a shipment in. The exact same boat I purchased is now 22% higher price with a smaller motor. Crazy!
  23. Feb 22, 2022 at 1:23 PM
    #293
    Pac12AfterDark
    Yep. Saw the same increase over what I had quoted summer.
    Oh well.
  24. Feb 23, 2022 at 11:20 AM
    #294
    Kua_Vang
    Kua_Vang New Member
    Kua
    2014 Tundra
    Just waiting on better days...... Off to the lake with my boy.
    HBTundra, Brown Bear, Bprose and 7 others like this.
  25. Feb 23, 2022 at 1:25 PM
    #295
    BayRunner
    Nice, what size motor is on that?
  26. Feb 23, 2022 at 1:44 PM
    #296
    Kua_Vang
    Kua_Vang New Member
    Kua
    2014 Tundra
    Its a 2008 Nitro 591DC with 150 Optimax
  27. Feb 25, 2022 at 5:12 PM
    #297
    Bucks04
    Bucks04 New Member
    2013 TRD Tundra
    Working on it
    Failed to mention if 2stroke or 4stroke, if you change out definetly go to 2stroke I have mariner9.9 2 stroke , went to trade for 25 hp 4stroke , dealer said no , the 2 stroke had same power as the 4 strokes, so if going up in hp make it 2 stroke.
  28. May 30, 2022 at 12:21 PM
    #298
    BayRunner
    Good weekend to be out on the water.
  29. May 30, 2022 at 8:15 PM
    #299
    AZBoatHauler
    So.Arizona
    Hell yea it was!
    9BC7C0AF-54B7-4D22-82DE-C7CE94A1DB75.jpg 5622A691-0C25-4DB9-B27D-3509A94BB66C.jpg FA71C6FB-08BE-4128-B344-F12C4C834117.jpg DED6903C-D6CE-4564-B6EA-5BE67DE671DD.jpg 25CC0919-4E02-490D-8C08-7836C3FDAF7A.jpg
  30. May 30, 2022 at 9:31 PM
    #300
    Brown Bear
    Nor cal
    03 TRD offroad
    My new alumacraft voyageur 175 cs with a 115 Yamaha vmax sho.20220515_133700.jpg 20220507_111227.jpg IMG_7214.jpg
