  1. May 23, 2022 at 10:28 PM
    KK6PD
    KK6PD 2 1 yr. retired . . . after 42 yrs
    ROAD
    Upper Los Angeles Foothills
    2003 AC Tundra . . . . 7th owner
    New Tires, Stereo & Speakers,Uni-Strut Tie Down Continue watching THIS SPACE FOR FUTURE DEVELOPMENTS
    Well,
    A - I too like the pic!
    B - That was some of the funniest what , 3 pages memes about alb1k..... in one day....
    C -Your challenge actually sounds intriguing!
    alb1k[QUOTED] likes this.
  2. May 23, 2022 at 10:48 PM
    alb1k
    Left Coast
    05 2WD DC w/ attitude
    It's good
    Ha, I went to catch up because I realized I missed something. Page back - nope, page back - nope, page back - WTH? Lol.
    I thought about challenges for a bit. I have no idea what they've done over there. That unknown image one seemed unlikely as a repeat and pretty obtainable, or voyer-ish at least which can be weird/cool.
    NUDRAT[OP], 5N0W808 and KK6PD[QUOTED] like this.
  3. May 23, 2022 at 11:03 PM
    assassin10000
    assassin10000 New Member
    Andrew
    Northern CA
    '05 SR5 AC
    Those are one position. Probably not gonna get you there for max caster.
    I've aligned race cars which had kits with holes drilled in 3-4 different sets of plates that would give 5-8 working positions (center, slightly offset and max offset). You'd just flip the offset plates around for inside or outside.
    Doesn't look terrible, except for the slightly positive camber. He could have loosened the SPC upper and corrected that.
  4. May 24, 2022 at 4:12 AM
    They have the sameish kinda challenge on the motorcycle forum I creep on. You have to take a picture of ______ with your motorcycle in front of it. Whoever posts it first gets to pic the next challenge. They also did a scavenger hunt type challenge where it was like 7 easy challenges in 1.
  5. May 24, 2022 at 4:48 AM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    Sequioa sway bars are thicker, yes? And fit the front end of a regular cab? Yes?
    NUDRAT[OP] likes this.
  6. May 24, 2022 at 6:38 AM
    Seems this would be more stout if the verticals were inside the boxed area. Would help reduce potential torsion of the verticals, which would put less strain/wear and reduce possible fatigue on your very-stout hardware.
    Sunnier likes this.
  7. May 24, 2022 at 7:08 AM
    Sunnier
    Sunny
    San Diego, CA
    I think this too.
    But that’s not how these pieces reach/ fit together. ;) (?)
    alb1k and shifty`[QUOTED] like this.
  8. May 24, 2022 at 7:10 AM
    Sunnier
    Sunny
    San Diego, CA
    I *like* positive camber and make maxing it, the primary alignment goal. :anonymous:
  9. May 24, 2022 at 7:17 AM
    It looks like the base plate of the brackets is slotted, allowing for some inward/outward movement; maybe would potentially allow for it?
    Sunnier[QUOTED] likes this.
  10. May 24, 2022 at 7:20 AM
    Festerw
    Festerw New Member
    Cambridge Springs, PA
    04 Tundra DC
    I spent 14 hours driving 800 miles yesterday. My old bones are unhappy today. Boston home to Erie, then to Cleveland to pick up my car, and back to Erie.
    Hooray for cancelled flights, now I get to call and try to get everything straightened out and refunds for additional expenses.
    des2mtn likes this.
  11. May 24, 2022 at 7:47 AM
    Sunnier
    Sunny
    San Diego, CA
    Yeah, maybe. I was thinking he placed those side rails to attach to the top of the bedsides.
    alb1k likes this.
  12. May 24, 2022 at 7:48 AM
    Sunnier
    Sunny
    San Diego, CA
    Good you’re finally home!
  13. May 24, 2022 at 7:50 AM
    Sunnier
    Sunny
    San Diego, CA
    @alb1k i seldom check TW but I did it this morning to catch up on your reception. Super entertaining!
    Really, they were pretty nice to you. I figured they’d have noticed how few posts you have, and got out the pitchforks straightaway.
    alb1k likes this.
  14. May 24, 2022 at 7:55 AM
    alb1k
    Left Coast
    It's good
    I agree. I have to move or cut relief for the top bolts that hold the rack to the load bars so I can adjust the legs wider. It’s on the list :thumbsup:
    shifty`[QUOTED] and Sunnier like this.
  15. May 24, 2022 at 7:58 AM
    alb1k
    Left Coast
    It's good
    I know, right?
  16. May 24, 2022 at 8:07 AM
    Fleawalker
    Fleawalker New Member
    South FL
    2001 V8 4x4 Access Cab
    None (yet)
    Overdrive On or Off?
    I recall seeing a discussion somewhere on this but I'm curious...do you recommend Overdrive on or off when driving:
    Highway ?
    City ?
    Towing ?
  17. May 24, 2022 at 8:16 AM
    I was always taught OD off while towing, although it can be OK to leave on if no hills. I can't imagine how realistic asking about city is, chances are you won't kick into OD anyway. I think you'll always get better mileage at hwy speeds if you can kick into OD if there's no significant load to pull. So I guess I'd break down your Q as:
    Highway : ON if no significant load
    City : ON though it probably doesn't matter
    Towing : OFF if hills, can be ON if flatland.
    NUDRAT[OP], des2mtn and alb1k like this.
  18. May 24, 2022 at 8:21 AM
    Fleawalker
    South FL
    None (yet)
  19. May 24, 2022 at 8:24 AM
    des2mtn
    SW
    2004 Black DC Limited 4x4
    Tonto cover
    Some of these threads pertain to towing, but @tvpierce has some good insight into O/D and the torque converter.
  20. May 24, 2022 at 8:28 AM
    Fleawalker
    South FL
    None (yet)
    That's what I saw. Thanks for that. No many hills here in South Florida but we do have some tall bridges/overpasses.
  21. May 24, 2022 at 1:53 PM
    assassin10000
    Andrew
    Northern CA
    '05 SR5 AC
    Yes. Non-sunroof is 27mm (same as later gen tundra) and sunroof is 28mm.
    I'm running the 28mm on my AC.
    daveeasa likes this.
  22. May 24, 2022 at 1:59 PM
    daveeasa
    And early FGT is 26mm or something?
  23. May 24, 2022 at 2:05 PM
    rock climber
    rock climber New Member
    2001 Sequoia 4X4, 2000 AC 4X4
    They plates are reversible.
    Features:
    • All in one, 3 way adjustable (-,0,+) 1/4" steel eccentric plates
    Also, the idea is to use them with the solo LCA which adds a few degrees of caster and the SPC which would be used for fine tuning the alignment.
    Casper421 likes this.
  24. May 24, 2022 at 4:40 PM
    alb1k
    Left Coast
    It's good
    Turns out with some persuasion the risers went in there. I did do my bolt throughs first, so was able to apply some torque to get them in.
  25. May 24, 2022 at 4:47 PM
    alb1k
    Left Coast
    It's good
    Hours fixing that Morimoto vanity light yesterday. Complete re-wire and solder repair. Perfect! Dead this morning. OMFG. I'm pulling the working ones and making chase lights out of them.
    shifty`, NUDRAT[OP] and daveeasa like this.
  26. May 24, 2022 at 5:54 PM
    alb1k
    Left Coast
    It's good
    Tacoma guys sent this to tell me what would happen if I didn't pick a winner for the weekly photo challenge on time. I though ony 1st Gen Tundra crew had the rights :rofl:[​IMG]''
  27. May 24, 2022 at 5:56 PM
    Better tell them with a 300 meme
    Jack McCarthy and alb1k[QUOTED] like this.
  28. May 24, 2022 at 5:57 PM
    Sunnier
    Sunny
    San Diego, CA
    :evil: I reviewed both. The guy with the pizza is ours. The gal-with-the-water-customization is theirs.
  29. May 24, 2022 at 6:04 PM
    Can we have the flaming shirt guy? I’ve done something similar with a nylon? Rope, I still have scars
  30. May 24, 2022 at 6:40 PM
    alb1k
    Left Coast
    It's good
    Here's a nice example of photography and post process, Randy over at TW has done this before.
    NUDRAT[OP], 5N0W808, bmf4069 and 4 others like this.
