Replacing stock amp 2020 SR5 Crewmax
Discussion in 'Audio & Video' started by Ben_Grimm, Apr 8, 2022.
  1. Apr 8, 2022 at 3:31 PM
    Ben_Grimm
    Ben_Grimm [OP] New Member
    Ben
    2020 SR5 Crewmax 4wd
    Hi all,
    I upgraded my Tacoma amp from a Sony XMS400d to a Kicker Key 200. I want to put the Sony in my wife’s Tundra. I have the harness from autoharness.com and have replaced the tweeters, front and rear door speakers. The doors are 4 ohm and the tweeters are probably 2 ohm. Can I just take the stock amp out and hook up the speakers to the Sony. Or do I need an LOC? The Sony has high level inputs. Thanks!
    Edit: I’m not an expert at audio but can do basic stuff.
  2. Apr 12, 2022 at 8:40 AM
    Ben_Grimm
    Ben
    Okay. I’ll let y’all know :fingerscrossed:
  3. Apr 13, 2022 at 7:50 AM
    OHnickIO
    OHnickIO New Member
    2020 TRD Sport Non JBL
    What did you replace the tweeters, front and rear door speakers with? I have a 2020 TRD Sport so i'm interested in what you find out! I almost bought that Sony amp too
  4. Apr 13, 2022 at 9:16 AM
    Ben_Grimm
    Ben
    I have some Hertz tweeters that I got from James/12 volts and Hertz X 170 for the front doors. I’m putting Kicker 46CSC674 in the rear doors. I got the speakers from Crutchfield. Got the amp straight from Sony. It’s not a bad amp but the Kicker Key is a little more adjustable. I’ll let you know when I get it done. May be a few weeks. Thanks.
  5. Apr 28, 2022 at 6:30 AM
    2WD
    2WD New Member
    21 Army Green CM SR5 TRD Off Road
  6. Apr 28, 2022 at 9:45 AM
    Ben_Grimm
    Ben
    Thanks for the link! The Sony amp is just an amp with no adjustments. The Kicker amp is in my Tacoma and I did use the microphone to adjust the sound. Fantastic little amp! I’ll definitely post my results if I ever get the time to swap out the stock Tundra amp. Thanks again!
  7. May 21, 2022 at 6:18 PM
    Ben_Grimm
    Ben
    I finally got the Sony amp in the Tundra. The hardest part for me was figuring out how to connect the 4438 harness (https://autoharnesshouse.com/41112.html) to the amp wires. This helped me a lot: (https://autoharnesshouse.com/entune_pinout.txt). In fact, I was ready to just leave the oem amp hooked up just so I wouldn’t screw up her truck! But it turned out okay. I zip-tied the Sony to the original amp’s bracket after removing the oem amp. Sounds great!
