Ask the Toyota mechanic!
Discussion in 'General Tundra Discussion' started by T-Rex266, Aug 15, 2015.
  1. Jun 26, 2017 at 7:12 AM
    #811
    RussellVaughan
    RussellVaughan New Member
    Houston
    2015 Gray TSS 5.7 CM SR5 4x4
    AMP Research PowerSteps; Katzkin leather seats (Nightrunner, all black, no perf/logo); TRD 18" BBS Forged rims; Nitto Terra Grappler G2 LT295/70R18) tires; LT295/70R18 spare tire; Rough Country speedo calibrator; Fox 2.0 IFP front & rear w/1" leaf blocks; TRD PRO black headlamps w/Headlight Revolution harness; TRD PRO grill w/color match hood bulge; RCI engine skid plate; BakFlip MX4 tonneau; Baja Design Squadron Sport fog lights w/clear wide lens; front/rear color match bumper covers; K&N CAI; Pedal Commander throttle controller w-trailer brake bezel; SE Toyota wireless charger tray; VLEDS interior and exterior LED lights; AJT Designs interior chrome delete; Sparks Parts driver side grab handle kit; Pop&Lock tailgate lock; ICS Fab dash mount w/support plate; ICS Fab center console mount; SNS Custom Design ABS sensor guards; TRD PRO shift knob; Undercover Swingcase bed storage; Rad Rubber Design engine splash guards; Bull Ring bed rail tie-downs; exterior debadge w/black & engine badge and black 4x4 badge; Charvonia Design billet bed tie-down anchors; rear console USB port; TRD rear sway bar; Fumoto Oil Pan Valve; Toyota metal oil filter assembly; Vexing R1 dash cam; X2Power 24F Battery.
    Anyone know where I can get a TSB list for my 2015?
  2. Jun 26, 2017 at 7:50 AM
    #812
    DVYota
    DVYota Super stock street truck
    2014 Sequoia 2021 Tacoma
    Basically stock
    I've got 155,000 miles on my truck. I bought it with about 145,000 miles for a good price about a year ago. Should I have them do the transmission fluid change now or is it too late? I don't see a record of it in the service history. They did throw in a drivetrain warranty when I bought it.
  3. Jun 27, 2017 at 6:33 AM
    #813
    LOTSOFTOYS
    LOTSOFTOYS Toyota Whisperer
    Jace
    Mile high
    2005 Tundra DBL cab
    Yeah why wouldn't u do the trans fluid?
  4. Jun 27, 2017 at 7:27 AM
    #814
    DVYota
    Basically stock
    After it going 150,000 mikes without being touched, I've been told that it should just be left alone otherwise I'd have to rebuild it due to whatever inside being worn out?
  5. Jun 27, 2017 at 11:02 AM
    #815
    LOTSOFTOYS
    Jace
    Mile high
    2005 Tundra DBL cab
    I would get that contaminated fluid out and put fresh fluid in.
    Abrams65 likes this.
  6. Jun 27, 2017 at 12:42 PM
    #816
    DVYota
    Basically stock
    Drain and fill or flush?
  7. Jun 27, 2017 at 5:24 PM
    #817
    LOTSOFTOYS
    Jace
    Mile high
    2005 Tundra DBL cab
    Since it hasn't been done probably a flush. But your choice. Dropping the pan and cleaning the magnets wouldnt hurt either. Next time don't buy a truck that hasn't been regularly services;)
  8. Jun 29, 2017 at 6:36 PM
    #818
    careyrob
    careyrob In the field
    Carey
    Massachusetts
    2008 Crewmax TRD 4x4 Silver
    LRO 3/1 leveling lift 35x12.50's on 20x9's Hellwig rear sway bar B&M 70264 SuperCooler Transmission Cooler Firestone airbags Daystar cradles Air Lift WirelessONE Compressor System
    I just pulled a *HEAVY* 22' enclosed car hauler from Seattle to Boston to move my family for a new job. I made several upgrades so I wouldn't destroy my 2008 Crewmax 4x4 (with the towing package). One of the best upgrades for crossing the Cascades and Rockies was to front and rear Stop Tech drilled and slotted rotors. The kit came with ceramic pads also which was nice.
    I played it safe on my downhill speeds, but still had to slow down quickly near the bottom of a few long steep grades when I rounded the curve and found 2 semi's practicing their rolling roadblock manuver. The Stop Tech's gave me lots of braking with no fade in a scenario that I'm sure the stock brakes would have been too hot for.
    NewImprovedRon likes this.
  9. Jun 29, 2017 at 7:46 PM
    #819
    LOTSOFTOYS
    Jace
    Mile high
    2005 Tundra DBL cab
    Good to hear! I've heard great things from them as well. Actual experience is worth alot tho, thanks for that
  10. Jun 29, 2017 at 8:56 PM
    #820
    TundraDan723
    TundraDan723 Not as new as I used to be...
    2023 Celestial Silver Tundra 1794 TRD CM
    2011 Tundra TRD Offroad with 5.7 4x4
    In the last month my Passenger side airbag light ALWAYS shows OFF. I know on the Gen1 there is a switch in the glove box that allowed you to turn on/off. There isn't any switch on my Gen2. I don't know why, even with an adult passenger in the seat, the air bag doesn't work. Any ideas?
    TIA
  11. Jun 29, 2017 at 9:28 PM
    #821
    T_dublecab14
    T_dublecab14 New Member
    RC
    2014 doublecab 4x4
    TRD
    Hi Jace. So I have been trying to upload the start up and off images to my 2014DC entune but it will not. I have followed the video to the T. The only other thing I can think of is the usb has to be empty besides the two images and it has to be no more than 2gig memory??? can you give me some help??
  12. Jul 1, 2017 at 10:47 AM
    #822
    LOTSOFTOYS
    Jace
    Mile high
    2005 Tundra DBL cab
    Dan ya you are right with everything you said. You have sensors under the seat that detects a passenger's weight. If the passenger weighs more then 60? Pds it's turns on the airbag. If less it leaves it off (children). If this is not working correctly, it will need to be looked at by a dealer with our scan tool to see what the sensors are reading for weights.
    I can't help u there man, no idea how to do that
    T-Rex266[OP] likes this.
  13. Jul 1, 2017 at 10:55 AM
    #823
    TundraDan723
    Very appreciative of your help! Thank you.
  14. Jul 1, 2017 at 5:30 PM
    #824
    Randy Morton
    Randy
    Deepinahearta, Texas
    2012 Tundra Double Cab, Beta Variant (I call it my Land Yacht)
    The fan motor in my '12 DC as started to make a rumbling/humming sound yesterday. it stops when I turn off the fan, but not when I turn off the compressor. It also varies with the fan speed. I changed the filter, but that didn't help. It did get quieter later that day, but it's still making the sound. It's barely noticeable on the lower speeds, but quite pronounced on the higher speeds. Am I looking at a trip to the dealer?
  15. Jul 1, 2017 at 6:52 PM
    #825
    LOTSOFTOYS
    Jace
    Mile high
    2005 Tundra DBL cab
    I bet there is a leaf in your blower motor. Take your filter back and reach down in there (fan off;)) and see if u feel anthing. Remove anything if needed
  16. Jul 1, 2017 at 7:25 PM
    #826
    Randy Morton
    Randy
    Many Thanks!
    One leaf, and a whole bunch of leaf bits later, and it's back to normal. I expected the fan to be on the clean side of the filter, but it doesn't appear that's the case.
    In case anyone else has this problem, the fan is just below the filter and lays flat. You can reach in and rotate it to get to all of the blades. All I could get in was my fingers, but my fingertips were enough to dig out the leaf shreds. Those of you with cooperative small children, or a cooperative wife with small hands, should have an easy time. :)
  17. Jul 2, 2017 at 8:10 AM
    #827
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    I think that it's just three easily accessible screws and one electrical connector to remove the blower motor, then you can just shake it out over the rubbish bin, or on the floor.
    NewImprovedRon and LOTSOFTOYS like this.
  18. Jul 2, 2017 at 6:51 PM
    #828
    Randy Morton
    Randy
    It would have to be a small hose, the opening's only a little over an inch tall.
  19. Jul 3, 2017 at 9:18 AM
    #829
    WyattEarp
    WyattEarp New Member
    2010 Black Tundra SR5
    Question for the Guys way smarter than I am!!! I have a 2010 Tundra SR5 5.7L 4X4 with 65,000. I've had it about 7 months now with no issues. All the sudden last week I go to leave work and when I turn the key it acts like the battery is completely dead, no lights on nothing. On the 3rd turn of the key she started up with no problem but the aftermarket radio was reset to factory just like having a dead battery. I had the battery checked it is good. Drove the truck for 3 days with no issues, it started fine every time. Then I went to get gas turned the truck off when I went to start it, dead. I popped the hood and pushed on the positive cables coming from the positive terminal and could here things start to click on and saw the interior lights turn on, it started right up. Had the issue happen 2 times this weekend and each time either after the 2nd crank it starts or pushing on mainly the wire that goes from the positive terminal to the fuse box it starts. I did notice a puff of smoke from that wire when it was started today. Does that wire need to be replaced or is there something in the fuse box? Any help would be greatly appreciated!!!! Happy 4th weekend everyone!!!
    Wyatt
    Randy Morton likes this.
  20. Jul 3, 2017 at 10:19 AM
    #830
    Randy Morton
    Randy
    Is the puff of smoke from the wire at the battery end, or at the fuse box end? You might just need to clean and tighten the connection. Corrosion can cause a bad contact between the metal pieces. Disconnect it, clean it carefully, and reconnect and re-tighten it. Be sure to disconnect the negative cable first, you don't want any nasty surprises.
  21. Jul 3, 2017 at 10:30 AM
    #831
    WyattEarp
    The smoke was from the cable end by the battery it was covered in electrical tape... I took everything off cleaned the little bit of corrosion that was on there took the tape off made sure everything looked good and put new tape around it. It started the first time but it acts like it's not getting all the power it needs... it just seemed to be running not as powerful as usual if that makes any sense
  22. Jul 3, 2017 at 4:51 PM
    #832
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    Are you able to tell how old the battery is? Sometimes there's a sticker, sometimes someone will carve or engrave the date into the plastic of the case. There may even be some "date dots" in the label where the month and last two numbers of the year are removed. Five years is a reasonable life span to expect from a battery. If the battery voltage checks okay, that does not necessarily mean that it can perform under the load of starting the engine and may be at the end of it's useful life. A new battery could be the hot tip.
  23. Jul 3, 2017 at 5:57 PM
    #833
    LOTSOFTOYS
    Jace
    Mile high
    2005 Tundra DBL cab
    Sure seems like cable ends and a battery would be a good start.
  24. Jul 3, 2017 at 6:32 PM
    #834
    Aurora CO
    Aren't you getting close to 1 year anniversary? Wait ..your H moon was during winter? Time to reprise your AK trip. Perfect time of year. Why not arrange going up to train Toyota techs how to properly install/align lifts at the Anchorage or Fairbanks dealer. Freebie vaycay. Just sayin
  25. Jul 5, 2017 at 11:50 AM
    #835
    LOTSOFTOYS
    Jace
    Mile high
    2005 Tundra DBL cab
    Lol it is man! 23rd... I'd live to go back. Actually take that back, I will go back someday;)
    T-Rex266[OP] and Black Wolf like this.
  26. Jul 5, 2017 at 11:55 AM
    #836
    Aurora CO
    It's hard not to go back once you have been there. Some people actually stay. I almost did.
    LOTSOFTOYS likes this.
  27. Jul 6, 2017 at 3:02 PM
    #837
    JMB
    Chesapeake, VA
    2013 Super White Tundra DC
    5100s all around, 295-70-18 Defenders, 1.25 Spidertrax spacers, BD reverse lights, de-badged, interior LEDs, footwell LEDs, reverse LEDs, ARE cap, front receiver hitch for cooler holder, cooler holder/rod rack, backup camera, Kenwood HU, Westin nerf bars, Husky floor liners, folding rear seats, remote battery posts, plastidip grill chrome, Powder coat bumpers.
    On Sunday(?) I was in really soft sand and heard the vsc kick in a couple of times. The vsc light stayed on. I found code c1234, yaw sensor with techstream and cleared it. No more problems until today. Getting on the beach this morning, when I parked I noticed the light on again. No other symptoms. When I started the truck to come back, the light was still on. By the time I got about two miles, off again. WTF? I guess is my question. Bad yaw rate sensor, or something else?
  28. Jul 7, 2017 at 6:54 AM
    #838
    LOTSOFTOYS
    Jace
    Mile high
    2005 Tundra DBL cab
    Huh that's weird.... very intermittent. Is the truck lifted? Maybe needs a zero point calibration
  29. Jul 7, 2017 at 10:57 AM
    #839
    JMB
    Chesapeake, VA
    Yeah, I hate intermittent. Truck is leveled, I never did the calibration, it's on my list now for when I get home. Seems weird that it would throw a code though, I would think it would just be more nuisance vsc activation. Too windy for the beach right now, if it drops off I'll go out later this afternoon and see what happens.
  30. Jul 7, 2017 at 8:41 PM
    #840
    JMB
    Chesapeake, VA
    Wind got worse, didn't go back off road, but did get this. Any ideas?
